Results 561 to 600 of 790
Threaded View
    Sep 09 2010
    Destin, FL
    Post The Infiltrators Build Thread
    2010 Ice Silver A4 P+ Quattro
    Mod List:
    Engine:
    APR K04
    APR V3.1+ Tune Running 93 Octane
    ECS R8 Coil Packs
    NGK Iridium IX BKR8EIX Spark Plugs Gapped @ .024
    APR Carbonio Intake
    ECS Intake Pipe
    EuroCode FMIC Kit
    034 HFC
    Stratmosphere 90 Degree O2 Spacer
    STaSIS Cat Back Exhaust
    CTS Catch-Can
    ECS R8 Oil Cap
    ECS Black Washer Fluid Reservoir Cap
    ECS Black Coolant Cap
    ECS Oil Dip Stick
    Wheels, Suspension & Brakes:
    Velocity Motoring V708 RS4 19x8.5 ET38
    ECS Audi OEM Wheel Center Caps
    Continental Extreme DW Tires 255/35/19
    ECS Tuning Spacers 5mm F&R
    Eibach Pro Kit Springs 1.4"F & 1.2"R
    Koni Sport Shocks
    Ultra Racing Upper Strut Bar
    H&R F&R Sway Bars
    034 Transmission Mount Bracket
    Apikol Differential Front Mount (Red)
    ESC Differential Rear Mounts
    ECS Q5 Brembo 4-Piston Big Brake Kit (Front)
    ECS 345x30 Slotted Rotors (Front)
    Posi Quiet/Centric Ceramic Brake Pads (Front)
    S4/RS Calipers & Carriers (Rear)
    ECS 330x22 Slotted Rotors (Rear)
    Akebono Ceramic Brake Pads (Rear)
    Stoptech Brake Lines
    Interior:
    3G MMI Retrofit
    Color DIS Retrofit
    B8.5 Climate Control Retrofit
    Podi Boost Gauge
    RS5 Pedals
    Face Lift S-Tronic Shift Knob
    Face Lift S-Line FBSW w/Paddle Shifters
    Face Lift Seat & Door Switches
    3M Brushed Black Metallic Trim Wrap
    LED Interior Bulb Swap
    Trunk Lid Warning Triangle & Bracket Kit
    30% Front & 20% Rear Tint
    Exterior:
    S-Line Front & Rear Bumper
    S-Line Side Blades
    S-Line Rear Valance
    S4 Grille
    ABT Trunk Spoiler
    ECS Plate Filler
    S-Line Scuff Plates
    S-Line Badges
    Trunk Lid De-Badged
    LED License Plate Bulbs
    VAG-COM Coding:
    Ross-Tech HEX-USB+CAN Interface Cable
    Disabled Turn Signal Winking
    Gauge Needle Sweep
    MMI 3G Hidden Menu
    Remote Window Roll Up/Down
    Battery Level Display On MMI
    Enabled DVD MMI Movie Playback
    Oil Consumption:
    Stage I - Completed June 2016
    Stage II - Completed October 2016
    Germany May 2010 - USA July 2015
    **I am not responsible for anything you do to your car by following this thread. If you do not feel comfortable doing mods yourself then I strongly recommend you have a shop perform this for you.**
    If you can't see all of the pictures, just install the hotfix for photobucket into Firefox or Chrome:
    Firefox: https://addons.mozilla.org/en-US/fir...otobucket-fix/
    Chrome: https://chrome.google.com/webstore/d...=1525177480008
