https://docs.google.com/spreadsheets...it?usp=sharing
I will update the spreadsheet with new information and everyone will be able to see it from here.
I'm not sure if this will be beneficial but who knows, I figured I would see how it goes. I had already started making it for myself and figured why not share it.
If you have already made a post similar to this in one of the other consolidation threads, copy and paste it in a post below.
Other Consolidation Threads
Single Turbo:
http://www.audizine.com/forum/showth...=consolidation
Frankenturbos:
http://www.audizine.com/forum/showth...-frankenturbos
RS6:
RP K04:
K24 (ish)
http://www.audizine.com/forum/showth...05-Srm-k24-whp
Tial 770R (ish):
ATTENTION: IF YOU WANT YOUR INFORMATION ON THE SPREADSHEET YOU MUST HAVE USEFUL DATA
THIS MEANS FATS TIMES, DYNO NUMBERS, or TRACK TIMES. PREFERABLY ALL THREE.
Car (Year/Color/Type) :
Dyno Type :
Dyno Temperature:
Fuel Used:
Tune/Tuner:
QM Time:
Trap Speed:
60' time:
AWHP:
RPM at Max WHP:
WTQ RPM at Max WTQ:
FATS:
Fuel Economy (city/highway/combo):
PSI Max/Redline :
Turbo:
Turbo Details:
MAF Type/Size:
Block :
Block Details:
Rods:
Rod Details:
Pistons:
Heads:
Cams:
Valvetrain:
Intercooler(s):
Diverter Valves:
Bi-pipes:
Y-pipe:
Intake Manifold:
Phenolic Spacer:
Throttle Body:
Air intake:
Fuel Injectors:
Fuel Rail / Regulator:
Fuel Pump(s):
Exhaust Manifolds:
Clutch/flywheel:
Downpipes:
Cats:
Cat-back:
Motor Mounts:
Suspension:
Trans Mounts:
DTS:
Suspension other details:
Transmission info:
Other Information:
