Results 1 to 14 of 14
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    Oil Level Sensor Fault Code
    I had an "Oil Level Sensor Failure" error pop up on my dash tonight. It also no longer gives me the option of checking the oil level in the MMI. Scanned for fault codes and it came back with:
    4635 - Engine Oil Temp. Sensor (G8)
    P0196 00 [047] - Implausible Signal
    Confirmed - Tested Since Memory Clear
    and
    4640 - Engine Oil Temp. Sensor (G8)
    P0197 00 [032] - Signal too Low
    Intermittent - Not Confirmed - Tested Since Memory Clear
    I cleared the codes and started the car. The error came back about 10-15 seconds after starting the car.
    A few questions:
    1. Does the oil level sensor also do oil temperature? I'm assuming it is the one installed in the bottom of the oil pan and found here: click
    2. Would the failure of this sensor cause the radiator fan to run full speed after the car is shut off? I just noticed my car doing this and it seems to coincide with the oil level sensor fault code.
    3. Is there anything else I should look for before I change the sensor?
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Oil level sensor is also the oil temp sensor.
    Does the wiring to it look OK?
    Oil temp sensor has nothing to do with radiator fan operation.
    Change the sensor (drain the oil first!)
    Feb 07 2012
    Thanks. After looking around more online it looks like I should take a peek at the relays inside the ECU box as well. Hoping it's not a lot of electrical problems. Picking up an oil level sensor from the dealership today and will assess everything when I'm installing my ECS aluminum belly pan on friday.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Keep us posted hope everything works out.
    Feb 07 2012
    Looks like I have a rodent problem in my parking garage at home or in the parking lot at work......
    Feb 07 2012
    Spliced everything back together and it fixed the problem, including the radiator fans running at full speed when I shut off the car.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    That sucks but at least you were able to fix it. What's your plan to stop them from coming back?
    Sent from my iPhone 6 using Tapatalk
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Feb 07 2012
    Quote Originally Posted by booost View Post
    I just pissed all over the engine bay
    No I dont know. I read putting drops of peppermint oil around the area helps keep them away. Might try that.
    Sent from my SAMSUNG-SGH-I747
    Jul 17 2008
    Hahaha what a pain in the ass. Try the peppermint and if that doesn't work go with something stronger I guess.
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    Peppermint oil is good for headaches too.
    Just sayin.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Dec 31 2018
    Iowa
    I have the same fault come up on my 2015 A3 TDI.
    Originally it was just the oil level sensor system fault warning and then the check engine light started shortly after, w/ the code P0197.
    So am I correct on that the oil level sensor reads level and temperature and the A3 TDI's do not have independent EOT sensors?
    Feb 15 2016
    Cambridge,Ontario
    What is that white crap wrapped around the wires ? Does not look factory
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    Damn. Old post.
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    Well this is an a4 forum so i would go to a3 snd ask
    1976 Yamaha XS 360
