Results 1 to 7 of 7
    Veteran Member Three Rings leftovers's Avatar
    Apr 14 2009
    ottawa, il
    Double check my alignment results
    After finishing up the air ride install and adjustable upper control arms, I went in for an alignment. I asked them for this:
    Front
    Camber: -2.5 deg (per side)
    Toe: 0 (or up 0.10 deg total toe in)
    Rear
    Camber: -1.5 to -2 deg (per side)
    Toe: 0.20 total toe in (IIRC this is 1/8" total toe in)
    I had that done in August. The picture below shows how it turned out.
    I just put new rotors and calipers on the front. And in the process of doing that, I noticed that I have 0 tread left on my rear tires. They are evenly worn across the surface, but they are completely done. The front tires look great.
    I bought the tires used and I knew that 2 of them were a little lower in tread than the others, but it wasn't that far off. It is certainly possible that they just wore out, but I didn't think it was going to happen quite that fast. It caught me a little off guard. I just want to make sure that my alignment numbers are ok before I switch to winter tires and have an issue with them, too.
    2004 A4 Ultrasport, 1.8T, 6MT
    Instagram: audi_ute_build
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    That's pretty freaking good. You can get your fronts more dialed in with adjustable UCA's or seeing if they can loosen and tap the subframe IIRC; But honestly that doesn't look too bad at all.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Apr 14 2009
    ottawa, il
    I do have adjustable UCA's. It says so in the first line of my post.
    Thanks for the double check. I just wanted to make sure my rear tire wear wasn't a direct result of the alignment.
    Jun 26 2012
    Reading, PA Area
    Quote Originally Posted by leftovers View Post
    Sorry, must've missed it.
    You don't have excessive camber/toe so I doubt that that is your issue. Post up your pre-adjustment results and that should give a better idea, although I doubt they were the same prior to the bags.
    Apr 14 2009
    ottawa, il
    They didn't take a measurement before they started. I'm sure it was way off. I only drove it about 100 miles like that though.
    Before bags, this is what it looked like. I see there was a fair amount of additional toe in the rear, but I don't think it was excessive enough to cause tire wear.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I saw a post somewhere about the perfect alignment, i think cornelius made it.
    what are the oem specs supposed to be and why change it for another one? Do you guys have a proven better alignment specs?
    UPDATE: nevermind, found it http://www.audizine.com/forum/showth...ight=alignment
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Apr 14 2009
    ottawa, il
    That's the thread I used.
