Results 481 to 520 of 773
Threaded View
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    2.0 EFR 7670 Build
    Hi Guys,
    I am in the middle of a pretty large build and wanted to post what I plan on doing and the steps it takes to get there, along with the results. This is mainly about the engine build but I have some other goodies going on the car (RS4 Cluster, ECS Stage 4 BBK Fronts, ECS Stage 3 BBK on the rears (designing and making my own brackets) and some other custom parts) and I will post them once they are installed.
    I am working with Redline Speed Worx to do an awesome build and here is what I am doing. My ultimate goal is 600 AWHP and I think with this setup I can get there.
    Engine and Exhaust:
    Integrated Engineering Custom 2.0 Stoker Short Block (IE Race 1000 model)
    Integrated Engineering AEB Stage 1 Head
    Integrated Engineering Street Cams
    Integrated Engineering Manifold w/ Hemi 80mm Throttle Body
    Integrated Engineering Oil Pump Kit
    Integrated Engineering Billet Timing Belt Gear
    Integrated Engineering Catch Can
    Integrated Engineering Stage 3.5 Timing Belt Kit
    Integrated Engineering Billet Pulleys
    Integrated Engineering FSI Coil Adapters
    Full-Race Twinscroll Tubular Manifold
    Borg Warner EFR 7670 .92AR IWG
    Full-Race Billet Wastgate Actuator
    RSW Custom FMIC (PT Core)
    RSW Custom Down Pipe
    Tial 50mm QR BOV (Recirc)
    Accusump 2QT Accumulator
    Accusump Turbo Cooler
    ARP Everything
    RSW Custom Turbo Lines
    PreciseD Custom 3" exhaust with 3" boost dump valve
    OEM R8 Coil Packs
    Transmission :
    RSW Custom 8 Puck Southbend Stage 3 Clutch w/ Flywheel
    JHM 4:1 Center Diff
    JHM Trio Shifter
    034 Track Mount
    Fuel and Tune:
    Integrated Engineering Fuel Rail
    034 "044" Surge Tank
    Custom Return Fueling
    "040" In Tank Pump
    1200cc Bosch Injectors (UM Spec'd)
    Custom United Motorsports Tune
    UM 4" Pro-MAF
    Snow Performance Stage 2 Meth Kit w/ 2.5 Gallon Tank
    Braking and Suspension :
    ECS Stage 4 BBK w/ 2 Piece Rotors (Front)
    ECS Stage 3 BBK w/ 2 Piece Rotors (Rear)
    KW V1 or V2 Coil Overs (Still Deciding)
    H&R Sway Bar (Front)
    034 Sway Bar (Rear)
    034 Adjustable Upper Control Arm Kit
    Interior Mods
    OEM RS4 Gauge Cluster
    Symphony II+
    Euro RS3 wheel with Single Stage Airbag
    ECS Boost Gauge
    Euro RS4 Seats
    If you have not checked out Redline Speed Worx they are doing some pretty crazy stuff and have one of the fastest TTRS's around.
    Thanks to ECS, Full-Race, United Motorsports and Integrated Engineering for all of the help and great products you have supplied me with.
