Results 1 to 40 of 71
Threaded View
    May 13 2008
    MQBs
    San Francisco
    Wheel / Tire Setup and Offset Guide
    The guys in the B7 RS4 section just started this thread, and since there's always a bit of a looming cloud over what can actually fit.. I think it would be good for us too. Please post a pic if possible!
    TONS MORE INFO HERE FROM THE B7A4 GUYS
    Brand/Name:
    Size:
    Weight:
    Offset:
    Spacer(s):
    Camber:
    Tires:
    Suspension:
    Spring Rates:
    Ride height:
    Fender mods:
    Rubbing:
    Brake Spec:
    Other:
    Brand/Name: Ground Force GF06 FOR SALE
    Weight: Approx 27lbs each
    Offset: ET32
    Spacer(s): N/A
    Camber: OEM Specs, 034 Upper Control Arms
    Tires: Michelin Pilot SuperSport 255/35/19
    Suspension: KONI's | H&R springs
    Spring Rates: N/A
    Ride height: Will Measure
    Fender mods: Rolled/Pulled Fronts - Pulled Rears
    Rubbing: Fully loaded on VERY severe bumps, I hear a slight split second brushing sound
    Brake Spec: OEM Calipers / JHM LW Rotors
    Other:
    Brand/Name: Fifteen52
    Weight: 21lbs
    Offset: ET32
    Spacer(s): N/A
    Camber: -1.8 F OEM Rear
    Tires: Bridgestone Potenza RE-11
    Suspension: SAME
    Spring Rates:
    Ride height:
    Fender mods: Rolled Front - Pulled Rears
    Rubbing: Zero
    Brake Spec: OEM with JHM LW Rotors
    Other:
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
