Results 1 to 40 of 44
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    replacing wastegate lines: diy? or anything?
    Pretty darn certain my waste gate lines are torn somewhere. Im overboosting and its not the N75.
    Is there any sort of DIY, pictures, or inspiring words anyone can share? I have no idea how Im going to get my hands down there. I still need to blow on each hose to determine which side is borked.
    Im planning on taking the downpipes off anyways, to replace them with catless ones, any chance this will give me a better shot at this task, like going in from the rear maybe?
    What size silicone hose should I get to replace the a torn one?
    Not looking forward to this.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Senior Member Two Rings hutchb2's Avatar
    Sep 25 2011
    N/A
    Driver's side is easy enough to access once you drop the motor mount bracket. Passenger side is whole different story. Typically, I think the answer is pull the motor...
    Sep 18 2006
    Colorado
    #twosevenproblems
    Fuckkkkk
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Quote Originally Posted by hutchb2 View Post
    Not true. I just did the passenger side. I didn't route into the metal tube though.
    I dropped the sway bar took the old line off. Ran a new line up the inlet pipe and under the fuel rail. Took me a little under 2 hours.
    Sent from my SCH-I535 using Tapatalk 2
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Aug 05 2011
    Memphis, TN for now!
    I'm putting off this as well. I can hear something leaking on my passenger side...not sure if it is line or actuator. I feel like removing the inlet and motor mount would help access from the engine bay side. I am going to remove as much stuff as I can to give me the room to work. Till then I've decided to run off wastegate pressure(I've connected the wastegate line to the reference line directly at my N75). It leaks obviously still but boost is staying at 13psi for now until I get motivated and the weather cooperates....I still haven't done my trans mount either. I'll attack them at the same time when I have the car up.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    Corona, SOCAL
    Remove Belly Pan
    Remove Sway Bar
    Remove Airbox
    Remove Inlet Pipe
    Remove Motor mount support
    Loosen Motor Mount bracket to Engine Block
    Remove Motor mount
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    Aug 05 2011
    Quote Originally Posted by jballou View Post
    Remove Belly Pan
    Remove Sway Bar
    Remove Airbox
    Remove Inlet Pipe
    Remove Motor mount
    Can the inlet pipe come out with front end still in place? I think I remember not being able to take the inlet off. Did you access from the bottom of the car while on jackstands?
    Sep 18 2006
    Colorado
    When I did my motor mounts, I was able to get my PS inlet pipe out, but not the drivers side. Frankeninlets, so bigger than stock. that said even the PS was a major pain in the ass. And of course car was in service mode. The again this is an allroad so I have ever so slightly more space than a B5.
    GD this will the the 3rd time in like 1 month car will be in service mode. Replaced the motor mounts in October, then i put intercoolers in last week, now this of course.
    Worst case I guess Ill pull the motor hahahahha
    Veteran Member Three Rings Halfbreed's Avatar
    May 13 2010
    Jax, FL
    I did the pass side with removing just airbox and inlet. It sure was a pain in the ass but it's possible.
    Aug 05 2011
    Quote Originally Posted by Halfbreed View Post
    I think I'm going to do just this....probably undo my engine motor mounts on the bottom and jack the engine up to give my hands more room to work. I'm hoping this helps clear the frame some more on the engine bay side.
    May 13 2010
    Jax, FL
    Quote Originally Posted by airjawed View Post
    If your comfortable undoing mounts go for it. The more room the better. Just saying it is possible with removing the inlet. I managed to get my fingers in the turbo as well to check for shaft play while I was at it. Having small hands helps.
    Jan 31 2008
    Did you run a separate line, or did you put it into the factory metal line?
    May 13 2010
    Jax, FL
    Quote Originally Posted by 01audia4 View Post
    Mine tore down by the wastegate so I ran a new line from the wastegate to a metal "T" up top. I have a MBC in parallel with N75. It is really cramped in there so I used a box cutter to split the hose off the wastegate nipple and the pulled it off with a pare of pliers. Getting the new hose on the wastegate is the hardest part.
    Sep 18 2006
    Colorado
    What size/type silicone replacement lines should I used
    Jan 31 2008
    I used 1/4" fuel injection hose I wrapped it in muffler repair tape.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by 4ringAR View Post
    I had looked into products @ MCmaster car,
    closest I could find was 3/16 (4.7mm) in high temperature hose, but you have to buy the really expensive stuff ($30 for 5 feet) that can both withstand high heat (350F) and high pressure (165psi)
    http://www.mcmaster.com/#standard-pl...tubing/=pj72y8
    the 165 PSI rating obviously isn't strictly necessary, but the 'regular' hose only is rated for 15PSI @ 72F, which when the hose heats up to 150 degrees or so, isn't going to be sufficient for the nominal pressure on those hose, and it will burst.
    I ended up buying -4 an steel braided hose from Summit before doing a bunch of research as other's had said that using 1/4" was fine. It's at my hose here now, so I'll end up using it, but it's .5mm too big(the OEM size is 5mm), and it's just plain loose over the wategate line after the built-in lip.
    The silicone hose up above is actually the better choice over the steel braided if I had to pick again. It hast a higher temperature resistance and it'll ensure a tighter seal given it's just a little bit smaller than the OEM size.
    Although, you're probably only going to get that on the wastegate line if you have it out of the car.
    Aug 05 2011
    I just finished my wastegate line replacement. What a pain...no seriously...literally the worse thing to do ever! I have frankeninlets so getting them out was the hardest part. I ended up jacking the engine up with engine mounts undone from the bottom. Then pulled it out while spinning. Had to remove headlights and all the bracketing for the inlet. Even with it out I was working blind. It tore at first but I got a small open end wrench and put it behind the hose clamp and popped it off. I put the new one on with a clamp that tensions itself..no way I could get a screwdriver in the right angle. Didn't bother putting the lines back in the bracket on the back of the cylinder head....but it isn't going anywhere anyway.
    Most of my time was just trying to figure out how I was going to do it. In the end I removed pretty much everything on the passenger side of the engine bay! If I had a better angle on the motor mount rear bolt(to the block) then I would definitely take that out and work from the bottom.
    Anyway, it is back together and airtight now. I'm ready for the next autocross!
    Feb 18 2013
    Silicon Valley, CA
    Remove Belly Pan
    Remove Sway Bar
    Remove Airbox
    Remove Inlet Pipe
    Remove Motor mount
    How does one Remove the motor mounts with the engine in the car?
    The engine needs to be supported I assume?
    Mar 19 2005
    Corona, SOCAL
    Quote Originally Posted by Tumbler510 View Post
    One side at a time.
    Jan 31 2008
    You do not need to remove the motor mounts.
    I've now done the passenger side twice(on two separate cars)
    Just drop the sway bar and move the inlet out of the way. Having two people helps one down low the other support uptop.
    On my first car I used 1/4 fuel injector hose. That worked fine. On this one I used -4 an stainless steel hose from summit. I could have gotten away with 3ft, but purchased 6 to be safe.
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    You sure its not the N75? Have you leak checked the lines going to the Actuators and verified actuator arm movement or lack of? Would suck to get balls deep in line replacement if theres a possibility its not the lines.
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
    Jan 31 2008
    Quote Originally Posted by NYEuroTuner View Post
    Judging by the age of the thread. I'd assume he already went balls deep.
    Oct 24 2008
    haha On mobile didn't see the OPs thread date.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Feb 18 2013
    Silicon Valley, CA
    How the hell do you get the new hose clamp tightened on? Did you use a worm-type clamp instead of Oetiker-style?
    Overboost with N75 disconnected.
    actuator lines can not hold any pressure at all.
    Jan 31 2008
    Just a regular worm type clamp and a long screw driver. Although it is easier to use a socket with a long extension.
    It's possible ;)
    Feb 18 2013
    Silicon Valley, CA
    It's possible ;)
    And to get the current clamp off?
    Jan 31 2008
    Push with a screw driver. Its a bitch but can be done. I never had to work with a k03 line though, both times were on replaced turbos. IE k04 and F21
    Feb 18 2013
    Silicon Valley, CA
    I am on K04's. I'll try this and report back.
    I anticipate a lot of swearing.
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    This. And I had my gf actually connect the line from underneath :). Small hands are the special tool ;)
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Jan 31 2008
    Shouldn't be to difficult. Much easier with two people(I had an extra set of hands this most recent time)
    Put the worm clamp on the new hose, it will help the person on the bottom guide it in with a screw driver while the person uptop fancies it on(tight squeeze with the exhaust mani there, be forewarned)
    A little finesse and BOOM its on there, just tighten her up and be done with the damn thing.
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    I attempted to do this once on the passenger side.. I wound up needing to pull the motor anyway for other things. If I had to do it again I would almost think it's easier to lower to the entire subframe down and pull off the inlets. That way you can reach from the side
    As far as vacuum line I wound up reusing Oem lines because my friend gave me a mint set from a part out. Whatever you decide to replace it with make sure it's high heat silicone. The downfall of the Oem stuff is the compression fittings.
    Feb 18 2013
    Silicon Valley, CA
    I don't want to come off as smug or anything, but I don't get the fuss about this.
    I changed out both sides by only dropping the sway bar, and it took me about 2 hours from jack to jack.
    The hardest part is routing the hose exactly where you wanted it to go, especially on the passenger side.
    Aug 05 2011
    How did you do it? A little more detail please.
    Feb 18 2013
    Silicon Valley, CA
    I was using 1/4" silicon hose from McMaster.
    Jack up car
    Remove skid plate
    Drop sway bar
    Locate actuator fittings visually
    Remove rubber hose from actuator using long thing (hand, screwdriver, crowbar)
    Remove hose from Tee (top/behind engine)
    Route replacement line from Tee down
    Put hose clamp over end of line before attaching to actuator fitting
    Fit hose over fitting using hands (will not be able to see what you're doing)
    Secure clamp with screwdriver/nut driver/ratchet
    Secure line at top using clamp
    Secure line along route down with zip ties
    Pretty straight forward.
    Like most things on these cars, its a simple thing, but simple doesn't equal easy.
    Aug 05 2011
    Jack up car
    Remove skid plate
    Drop sway bar
    I removed original line that has hard sections with an entire piece. I thought about just using hose but I was concerned about hose being that close to the exhaust. I'm sure just using hose for the entire thing would be easier but like I said..... that is a lot of heat inches away.
    Did you only remove sway bar at the frame or also at the wheels?
    Veteran Member Four Rings RedB5S4's Avatar
    Dec 06 2010
    BfiveSfour
    I'd like to keep my car.
    The nice thing about replacing the entire line with silicon is that you can pretty much route it however you want. The factory lines are hardly in optimal locations to begin with... Yes it's a lot of heat inches but there's nothing saying that you can't avoid them if you pull out the hard lines. Same deal with the oil feeds. Route them around high(er) heat zones, problem solved.
    Stg. III+ K24 CaS4
    Feb 18 2013
    Silicon Valley, CA
    Yes, the swaybar was still connected at the wheels. I only unbolted the frame supports to let it hang down.
    I used silicon hose with a high heat resistance and high pressure rating. I think the only way to 100% verify proper routing is to pull the motor. But i've done about an hour of driving wiht it, and no leaks or melted rubber smell, so I think it's ok for now.
    Aug 05 2011
    Quote Originally Posted by RedB5S4 View Post
    I definitely considered using hose and rerouting. I even thought about bringing it on the turbo intake side. In the end I replaced with one I found on ebay in good condition. In my case I think the original hose failed due to the FT's actuator nozzle being slightly off in position compared to stock. Also if valve cover gasket is leaking a little like mine then the oil eats the silicone. Anyway, keep us posted on how long it lasts.
    Senior Member Two Rings corneliusmixon's Avatar
    Oct 11 2012
    Jacksonville/FL
    Was the -4 AN too big?
    Veteran Member Three Rings HomeSlice's Avatar
    BUMP
    Can anyone help me choose the correct hose?! TIA
    Quote Originally Posted by blmlozz View Post
