Results 1 to 38 of 38
Thread: Community Help
    Oct 16 2008
    South Florida - Ft Lauderdale
    Community Help
    Hey Guys,
    I need your help here: Got some pretty heavy maintenance coming up, 140K, and I am preparing all my stuff
    2nd timing belt with all the bell and whistles
    Carbon cleaning and I will do a DIY
    Injectors cleaning and DIY as well
    Shane's valve cover with DIY
    Can someone map me the position of the intake manifold holes and as well as the port size
    I would greatly appreciate
    Phil
    Jul 19 2011
    Northern Minneapolis, MN
    I am not sure what you mean? like the runner area?
    Or all the bolts that you need to remove? I think those are all t27's except for two 10mm nuts (I think those are the right sizes).
    Then there is one rod that goes down and connects to the block (support rod) and that is a triple square.
    Oct 16 2008
    Sorry for not being clear
    I am looking for the distance between each bolt, horizontally and vertically
    I am looking for the length and width of the port
    Phil
    Jul 19 2011
    I see. I dont think I can help you there. I doubt the calipers will fit there. I would post this in the thread where everyone is group buying the S3 injectors and someone can measure when they have it off.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Just had mine off yesterday. darn.
    Give EPY a PM, I sent him a spare manifold a while ago.
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Ya I got a spare one from Martin for doing melt repair :) I can measure it tonight!
    Epy
    Oct 16 2008
    Quote Originally Posted by ericpaulyoung View Post
    Thank you for the help Guys
    Eric, looking forward to the data. If you caliper has milimeter capability, that will be even better
    Phil
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Nope, only measures in ft-s/fortnight :)
    Ah just kidding, I got a really nice mitutoyo caliper. Love the thing, had it since an engineering internship 15 years ago.
    Eric
    Epy
    Oct 16 2008
    Eric
    Perfect !!
    Phil
    Oct 16 2008
    Eric,
    You have PM
    phil
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    i can;t help you, but i am curious....why do you need the measurements? you always have cool shit a brewing
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Oct 16 2008
    Quote Originally Posted by mr shickadance View Post
    Surprise but you will know soon once I post the upcoming DIY's
    Phil
    Aug 09 2007
    Mount Airy, MD
    ...are you 3-D printing a manifold?
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by SykoraA4 View Post
    He's onto us Phil!
    Jun 27 2011
    Maybe a spacer? Or a billet flange for a custom mani?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 16 2008
    No, no intend to modify that
    Much simple
    phil
    Oct 16 2008
    Nope
    I am just being anal and want to make a tool
    Phil
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    For some reason I scanned that fast and read you want to make an anal tool.
    Got your number, will call you tonight so you can walk through any specifics of the measurements you need.
    Epy
    Oct 16 2008
    And I just invested in the tool kit to remove the injectors and replace the Teflon rings.
    Once done, I might just rent the kit
    Phil
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Phil
    wow, I always just wiggle them out, cut off the old teflon ring with a razor, use a tapered punch to stretch and put the new ring on, and (this is the important part) wrap tightly with paper then tape to get the teflon compressed again, then re-install with a rubber mallet.
    Geeze I feel like an Oakie saying that. :/
    Epy
    Jul 19 2011
    Nice! Can you take a couple pics and explain that better?
    I just wiggle mine out by hand, clean the tips with a rag hit with brake clean, then reinstall. The teflon hasnt been an issue on mine.
    One came out with the manifold!
    All out
    Before (90k)
    After
    No leaks or anything after reinstall. Or before for that matter.
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Audi used to require (or recommend) that you replaced the teflon every time. Now that is changed to "change if needed". Bman was the one that pointed this out, and he can probably cite the change. I have only changed my teflon on 3 sets. One of those sets I didn't wrap and compress the seals and they ended up getting destroyed. Basically it looks like the teflon ring slipped up when being installed because it was too loose, and it got cut on the edge of the slot.
    Epy
    Jul 19 2011
    nice fancy metal clips! My plastic ones broke so I run without. They stay in and dont leak just from the pressure of the manifold/fuel rail.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Wo hoo! New DIY's coming! Get your popcorn and pull up a chair! Love to see this stuff.
    Dreading the day of reckoning with carbon cleaning ---but I want to keep my car for the long haul---so--eventually.
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by CorneliusRox View Post
    Damn man, I think I got a couple extra if you need them.
    Epy
    Jul 19 2011
    Nah, I'm good. Thanks though!
    Honestly, I did my carbon cleaning when it was extremely cold outside and my garage wasnt much better (had ice on my boots by the end of it). I kinda rigged up the manifold and started the car to see if it would leak. It didnt at all, so I buttoned it up, and about 1000 miles after, I checked again and she is good.
    Not worth it to me to tear that off just to toss clips in at this point.
    If for some reason I decide to keep the car and make it a little more like yours, then I will get some.
    Oct 16 2008
    Stupid question:
    Do you know if there is an OEM tool to release all the stupid plastic connectors? Injector connector for example
    Phil
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Don't think there is :/
    Epy
    Jun 27 2011
    VAG Tool ID10T. Aka the flat head screwdriver. Costs $209.99 from you'r local VAG tool specialist.
    But seriously, someone should make a tool that opens those damn plug connectors. I mean I've got the technique down mostly, but still, if there was a tool to do it that guaranteed you wouldn't break them, I'd buy it in a heartbeat.
    -CP
    2017 Q7 3.0t
    Jul 19 2011
    The plastic ones just break! If you spin the metal thing a little and pull, you can get lucky
    Oct 16 2008
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    For the ANAL TOOL???
    Jk. Can't wait to see what Phil has in store for us this time...love your DIYs. Couldn't / wouldn't do this shit without them.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Jul 19 2011
    light switch connector? I dont think so.
    Oct 16 2008
    Gear box connector
    Google the Pn
    Phil
    Jul 19 2011
    Hmm. It is too bad that You didnt make this sooner. At about 8am I was on the SnapOn truck and our guy is great. Used to be a BMW tech so he like stuff like our cars and he is pretty young. Maybe 30 and has his own truck.
    He's off next Tuesday too... lol
    Jul 08 2010
    tucson
    danbury
    1) push in
    2) push down
    3) slide out
    troubleshoot
    1) can't push in
    answer: pahpush it real good
    2) can't push down
    answer: try a flat head
    3) can't pull out
    answer: 1) hahaha 'pull-out' 2) problem lies in small vacumn created by the connection, use a flathead or pick to disrupt the seal, then pull out 3)omgisaidpulloutagain
    [CENTER]Scott
    2011 S4
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Phil's onto building a tool for carbon cleaning is my guess
    - Chip
    034 Stage 2 ECU | 034 Stage 2 TCU | Wagner IC | IE Downpipe | ECS CAI Intake | Fuel-it e85 | Mishimoto Catch Can
    Oct 16 2008
    Quote Originally Posted by shiro1745 View Post
    Getting closer
    Phil
