I'm really confused. I just did a motor swap and I got to 800km on the break in, still havent hit more than 5 psi of boost, still getting used to her.
.... but now she wont start. I keep getting this cam position sensor code - Implausible signal.
I checked the wires and they seemed pretty chewed. So I cut the wires and spliced in a fuel rail harness with one i got from the wreckers.
Voltage checks out the whole way though, Pins 1 and 3 on the CPS plug read 4.9V at key in the accessory position as per the bentley.
Even the Cam chain tensioner shows upwards of 7v at ACC.
I thought this would fix my problem. but Still nothing.
So I have my old motor sitting here and I figure what the hey, why not swap the CPS's and see if that makes a difference... Still nothing!
When it does finally fire after numerous cranks, vacuum sits at 18inhg as if I have a vac leak and runs like shit.
So I once over'd all my vac lines and tightened all my intercooler couplings a little more. Still no help.
I also have an oil pressure sender for my VEI/podi gauge that I just installed not to long ago. It reads 30psi at warm idle. Never any less. and shoots past 99 up around 5k rpm this seems to high imo. Is this regular or am I crazy.
Whats goin on here. (using 5w30 non synth as a break in oil for a bit before switching to 5w40 full synth)
For the record its a
1.8t with brand new forged rods, new bearings and rings, new oil pump, head gasket, timing pump and water belt
Been wrenching all day trying to figure it out, now I'm just frustrated and my back hurts and I've given up and come inside to complain and ask for help.
any info pointing me in the right direction would be most appreciated.
