Originally Posted by
CardFan
I just did it a couple weeks ago. Very unlikely that you will have to replace the banjo bolts, and rack doctor provided replacement washers that go with the banjo bolts. Definitely replace the washers.
Use the same banjo bolts - as CardFan said, just ensure you use the new crush washers that are provided.
This really isn't a hard job ***IF*** you can gets your driver side control arm pinch bolt out easily - mine took me 7 hrs and finally came out after I decided to try using my snowmobile clutch puller ( essentially a ~ 2 ft long heavy duty punch ). Also, if you have the 1.8, utilize the extra space you have in the engine compartment and reach down through it after you've loosened the banjo bolts. As soon as they're loose, you should just be able to take them all the way off in a couple of minutes with only your fingers.
You WILL need help to reinstall.
Oh, and get new tie-rod ends while you're at it. You'll need an alignment when all is said and done so just replace them now. They're cheap.
