So I'm bored at work and I thought I'd start posting my crazy build.
My build consists of swapping from a 2.7T engine to a stroker 2.0T engine and using the 6spd manual from the S4. I'm doing all this on a 2001 Audi S4
Here's where the craziness come in. I’m going to put a 2.0T 058/AEB engine, but I’m going to use an AWM wiring harness and ECU, so it’ll be wideband vs narrowband. I’m also going to relocate the a/c compressor because I’m using a Fluidampr Damper and I can't be without a/c.
First I have to figure out how to move the a/c to the other side. I bought the ABA bracket that holds the alternator and a VR6 water pump pulley and after installing it. The bracket doesn't really work for me, since I also have to buy an alternator and I'd also have to buy an a/c compressor. So, first I'm going to try to work with what I have first. I'm going to cut the AEB bracket right where the manual fan goes, since I'm going to switch with an electric fan. Then I'm going to modify the power steering bracket to go right underneath the AEB bracket that I cut and after that I'm going to use the S4 a/c compressor bracket to go underneath the power steering. It's a bit hard to explain, but once I get working I'll post pictures. I hope this will help any person using a Fluidamper on an 058 block.
The next step, I have to see if all the connections from the AWM/06A wiring harness I can connect it to the AEB/058 engine. I think I saw somewhere that it’s better to use the AWM wiring harness from the Passat, because it doesn't have as much connection as the one that comes from an A4. Like the connection that plugs into the oil pan on an 06A. I’m going to check on this because I already bought the wiring harness from an A4 already. Maybe it won’t cause an issue if I don’t have to plug it in and maybe I can delete that sensor in the ECU.
Before people start saying you’re crazy to swap the 2.7T. So I’ll be clear, If I don’t sell this engine, in the future I’m going to build a 3.0T with it. I spent a lot of money building the 2.0T and for those that seen my other post of my build, this engine has been a décor in my house for a long, long time. I feel like a kid looking at a candy, but not being able to eat it. So.. it’s time to do the swap.
Engine
82.5 Supertech Pistons
IE I-Beam Rods
Single Groove Supertech Valves
Cat Cam Springs
Titanium Retainers
QED - Purple Cat Cams
Mechanical Timing Belt Kit
SPA Manifold
034 SPA Downpipe
ATP Fuel Rail
Fuel Pressure Gauge
44mm MVS Tial External Wastegate
50mm Tial BOV
SEM Intake Manifold
RS4 Throttle Body
044 Fuel Pump
ARP Head Studs Kit 058
ARP Main Studs 058
ARP Crank Bolt
Crank Rear Seal
Crank Gear Pulley
ARP Fly Wheel Bolts
Head Gasket set-(Big bore head gasket)
Main Bearing Caps Billet
Main Bearings w/Thrust Washer S
Rod Bearings +.001" ACL calico coated
Fluidampr Harmonic Dampner
Fuel Injectors 1000cc – Not sure which brand yet, I'm researching if I can use maybe a little bigger injectors. Like 1100cc or 1200cc
Eurodyne – Maestro - As I stated I'd like to use 1100cc or 1200cc. I need to do some research, but if anyone can help it'd be greatly appreciated
Comp Turbo CT4-6262
Turbo Cover
044 Fuel Pump
Steel Flywheel
Clutch Master FX400
3" Custom Exhaust
All Mounts - 034
Treadstone TR1035 FMIC
After my build I'm going to work on the body, since I bought the car painted with plasidip.
Here's a few random pics of my S4.
Here are some random pics of my parts
Thanks for watching!!
