Results 1 to 27 of 27
Thread: 80k service?
    Mar 10 2013
    Nor*Cal
    80k service?
    what ALL needs to be done at 80k miles?
    want to keep this car running tip top.
    i did a search, it doesnt bring up much besides spark plugs (already done) and control arms (going to do them soon)
    Established Member Two Rings Mr-Next's Avatar
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    Timing Belt
    Idler Roller
    Tensioner Roller
    Hydraulic Tensioner
    Relay Lever for Hydraulic Tensioner
    Water Pump
    Cam Seal
    Crankshaft Seal
    Thermostat
    Thermostat O-Ring
    Accessory Drive Belt
    transmission fluid ATF1
    Fuel filter
    Fuel Pump (option)
    coolant sensor and 1.5 Liter Bottle of G13 Coolant (two)
    Mar 18 2013
    States
    Quote Originally Posted by Mr-Next View Post
    Timing Belt
    Idler Roller
    Tensioner Roller
    Hydraulic Tensioner
    Water Pump
    Cam Seal
    Crankshaft Seal
    Thermostat
    Thermostat O-Ring
    Fuel filter
    Fuel Pump (option)
    add up it would be over $2000...
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    Quote Originally Posted by lucio_liu View Post
    Full kit of TB Includes
    Kit comes with the following:
    Gates Racing High Strength Timing Belt
    Idler Roller
    Tensioner Roller
    Hydraulic Tensioner
    Water Pump
    Cam Seal - Two
    Crankshaft Seal
    Thermostat
    Thermostat O-Ring
    1.5 Liter Bottle of G13 Coolant - Two
    Link ~> http://www.ecstuning.com/Audi-All_Ro...ing/ES2569851/
    Transmission fluid 6 qt, filter, and gasket 300 something from VW dealer cheapest that Audi dealer. Also you can get that online.
    Coolant sensor ~>
    http://www.ecstuning.com/Audi-All_Ro...nsor/ES264174/
    fuel filter ~> http://www.ecstuning.com/Audi-All_Ro...lter/ES258818/
    I got mine AR done 3 days ago with all these list except injectors and fuel pump. + shop work = cost me 1200$ .
    Mar 18 2013
    States
    [QUOTE=Mr-Next;8552886]Full kit of TB Includes
    Coolant sensor ~>
    QUOTE]
    audi c5 a6 Coolant sensor is prone to fail? my dash coolant temp gauge was point to center. do I still need to replace it?
    Nov 22 2010
    Stockholm Sweden
    Tiptronic gearboxes doesn't have oil change as a service point.
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    [QUOTE=lucio_liu;8552990]
    Coolant sensor ~>
    QUOTE]
    I suggest to save the time as well as you have time to work on your car its up to you but you can check on the coolant sensor if its not leaking thats fine also look at the temperature how long takes to get on normal position? if it take more than 10-12 minutes then replace it
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Do you have a 3.0 or 2.7T? You probably have a 3.0 but if you have a 2.7T then you need camshaft tensioner/adjuster seals and rear exhaust camshaft caps.
    Automatic or manual? If Automatic than you should change the fluid, filter, pan gasket, and all the pan bolts. Manuals can get away with just a fluid change.
    Either way you should get a new engine air filter, valve cover gaskets, serp belt tensioner, and change the rear diff fluid in addition to the stuff that Mr-Next mentioned. I think the fuel pump and coolant temp sensor are a bit overkill though.
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    You can change the tip fluid on low miles but its risky at high mileage. The transmission "relies" on the grit and metal in the fluid. Without the "crap" it is prone to slipping. It defies logic, but thats the way it is.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    Quote Originally Posted by 4ringAR View Post
    That's what I meant. you are right
    Mar 18 2013
    States
    Plan to change ATF soon,I am hoping 80k is not too late to change the ATF. the good side is my tranny still working smoothly.
    Mar 10 2013
    Nor*Cal
    hey im so sorry guys, i totally forgot to put what engine it is.
    its the 2.8 30v engine. the car is a quattro awd.
    wow @MR NEXT. that is a long list of things that needs to be done.
    how hard is a timing belt and water pump to replace on this car? i can try it myself and save a thousand bucks from what it looks to be.
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    Quote Originally Posted by euromob View Post
    Well Its not really easy to work with you have to get all the stuff out this is the DIY from ECStuning With pictures.
    http://bd8ba3c866c8cbc330ab-7b26c6f3...34-10-2012.pdf
    I did changed mine TB , ATF , and Fuel filter only 550$
    So if you know someone can get that done cheap for you. or you can do that buy yourself if you do have space enough at your house .
    Mar 10 2013
    Nor*Cal
    that belt you guys are posting is for the 2.7 twin turbo.
    i have a 2.8
    Sep 30 2012
    Allroad 2.7T
    salt lake city utah
    i have a 2.8
    http://www.ecstuning.com/Audi-C5_A6-...Timing/ES6198/
    Mar 10 2013
    Nor*Cal
    thank you!
