"Once the bolts are out we need to break the seal from the shaft and the transmission. To do so, grab a rubber mallet. Gently tap the outer section of the gold mount. Continue to do so while spinning the drive shaft to break the seal all the way around (leave the e-brake off to allow it to spin freely). This will break the seal. Use some force if gentle taps do not work."
Well I finished step 1 and got the seal open, but the shaft doesn't come out. I tried breaking loose the rear as well as removing the center bearing support thinking it just needed some space to move, but it still does not come out. I have tried pulling it out at both the front and rear and it moves a bit but hits what feels like a hard stop and will not go any further. How do you get past this point?
I feel retarded, this has to be something simple.
