Results 1 to 14 of 14
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Trans in limp mode again, insight please
    So a few weeks ago, I replaced the F125 sensor after the trans went into limp mode. Today, at low speed while accelerating the trans went into limp. Ran vagcom and came up with the following
    18032 - MIL Request Signal Active (Check TCM for errors too!)
    P1624 - 35-00 -
    Readiness: 0010 0001
    How do I check the TCM? Sorry if this a stupid question, I searched some. I am a relative noob with VAG Com.
    Thanks
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Jan 06 2010
    Bueller...Bueller?
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    p1624 is the 6speed swap request not met code.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Apr 18 2007
    ny
    I would have sold my Audi if I didn't do the 6 speed swap.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Re: Trans in limp mode again, insight please
    Quote Originally Posted by sjmelling View Post
    P1624 - 35-00 -
    Thanks
    You can check the TCM by scanning the transmission. Should be next yo the engine Box on vcds
    Sent from my HTC One V
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Jan 06 2010
    Well i feel like a moron now. I thought that would just pull up the same codes as in the autoscan. Ill give that a shot today
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Aug 30 2007
    nyc
    ive replaced the transmisson range switch on my transmission... I beleive 517 is the place to go locally for built.... or scotty...
    c5 A6 tip
    this n that
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by CELison View Post
    hahaha
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Jan 06 2010
    18159 - Supply Voltage
    P1751 - 35-00 - too High
    Any info on this? All the search results had multiple/issues as well.
    And I am indeed an idiot. This code was up on the original list of codes I pulled, I just overlooked it somehow. If my trans is shot, I will do a 6 speed swap.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Mar 13 2012
    Houston
    That looks minor. Clear it and see if it comes back.
    Jan 06 2010
    Quote Originally Posted by 4ringsa6 View Post
    Last night, I cleared the codes, went out of limp for a brief second. Pull out of parking space and immediately went back into limp. Same code came back. It is currently sitting accross the street from my friends house.
    I went over today on my lunch break, car wouldn't start as the battery is very low on power. The batt symbol is lit up on the dash. The battery has less than 1000 miles on it and is less than a month and a half old.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Jan 06 2010
    I jumped the car after work this evening. Battery was dead enough that radio was in safe mode. Trans was in limp mode still. Odd occurence, once car was started, the entire dash blackd out for 45 seconds to a minute. Once car was started, it stayed running even after the jumper cables were disconnevted, and restarted on its own after i turned it off. Are all these issues connected?
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Jan 06 2010
    So I talked to a local S4 friend of mine, and he suggested it may be a voltage regulator issue. So I got the car started over my lunch break today and put a voltage meter to the battery. At idle it was reading 13.1 and as I revved the engine slightly it crept up to just under 15. Looks like I will be swapping out an alternator over the weekend.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Jan 06 2010
    It appears that the voltage regulator was the issue. Swapping the alternator was not a big deal at all.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
