Results 1 to 9 of 9
    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    P0688 code ecu relay
    Picked up a car cheap as a donor, the guy said it ran but needs a starter solenoid now, so I got it home scanned it and got that code. Vag com says that the ecu relay is an open circuit or the relay isn’t there.
    So I was wondering where is that relay and how could I jump it.
    I wanted to at least hear it run before I part it out
    09 Prestige Package
    Veteran Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    2004 s4 Avant, 2005.5 S4 Manual swapped, 2002 A4 3.0 6 speed, 2004 A4 1.8 5 speed
    Oregon
    2 places to check:
    Under the drivers dash and in the ecu box under the Ecu
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S42011 Dieselgate Q7 TDI..... patiently waiting for my warranty to expire!!
    My build log
    "Everyone is An expert when they make their own category."
    Aug 11 2010
    Agawam Ma
    2 places to check:
    Yes I found all of those relays, just not sure which one is for the ecu it also looks like some water got under the ecu hmmmmm
    09 Prestige Package
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    looks like you found your issue. common. now stop thinking the answer is a part out.
    Nov 12 2015
    Oregon
    There’s your problem. The “main” relay I believe is the one In your hand. Either way, you Need to clean the relay sockets and probably replace the relays. Then you need to replace the ECU seal on the box or this will happen again. Once you get this taken care of, you should be good to go.
    My build log
    Aug 11 2010
    Agawam Ma
    Quote Originally Posted by q_dubz View Post
    Well I just bought the car for $1000 to part it out and fund my other build but when I started asking a few questions when I put it on the trailer I could tell he had no idea what he was talking about so I figured I’d try to get it running it’s got 222k
    09 Prestige Package
    Aug 11 2010
    Agawam Ma
    Anyone know what terminals to jump to verify that’s the issue? I made a jumper and tried jumping the two larger connections, and no dice. Like so...
    09 Prestige Package
    Nov 12 2015
    Oregon
    Relays use terminal 30 for power in and 87/87a for power out(depending on NO and NC circuits)
    My build log
    Aug 11 2010
    Agawam Ma
    Update: I jumped that relay that I was holding in my hand in the photo and the SAI pump powered on and I had no luck so I jumped a couple others and had no luck, I tried all the relays in the driver knee bolster and had no luck it looks like none of those are actually for the ecu or that is not the issue
    It appears by the codes that the ecu is not getting power. Does anyone have access to bentley or Chilton a where I can find the relay that’s for the ecu cause I don’t think those are, or where I can find a wiring diagram to find which wires power the ecu
    09 Prestige Package
