Results 1,641 to 1,680 of 1943
Threaded View
    Oct 27 2011
    TOYS
    Philly Suburbs
    Monty’s Single Turbo -> Back to Twins (Compound)
    Index:
    01/08/2013 (PG 05) – STK First Start https://www.audizine.com/forum/showt...=1#post8326431
    02/02/2013 (PG 07) – STK vs. Turbo Miata https://www.audizine.com/forum/showt...=1#post8408878
    02/11/2013 (PG 08) – HPX MAF Wiring and 4 Bar MAP P/N https://www.audizine.com/forum/showt...=1#post8437743
    04/14/2013 (PG 11) – 034 billet diff brace and STK launch! https://www.audizine.com/forum/showt...=1#post8641927
    04/25/2013 (PG 12) – AEM Meth Kit https://www.audizine.com/forum/showt...=1#post8677885
    05/02/2013 (PG 13) – STK vs. PJK04 https://www.audizine.com/forum/showt...=1#post8699829
    05/06/2013 (PG 14) – ATCO Dragway https://www.audizine.com/forum/showt...=1#post8710014
    05/10/2013 (PG 14) – First broken flex pipe https://www.audizine.com/forum/showt...=1#post8723811
    06/06/2013 (PG 16) – PT5858 vs PT6262 comparison https://www.audizine.com/forum/showt...=1#post8797636
    12/30/2013 (PG 19) – Single pump fuel system upgrade + built head install https://www.audizine.com/forum/showt...=1#post9337608
    01/30/2014 (PG 21) – TR10 intercooler and 3inch IC piping https://www.audizine.com/forum/showt...=1#post9426246
    04/17/2014 (PG 22) – Atco pump gas/meth – 11.799 @ 124 mph https://www.audizine.com/forum/showt...=1#post9670124
    04/26/2014 (PG 25) – RT Tuning Dyno Day – 671 whp / 604 wtq – single bosch 044 https://www.audizine.com/forum/showt...=1#post9699570
    05/12/2014 (PG 26) – Second Bosch 044 pump (external with pickup tube) https://www.audizine.com/forum/showt...=1#post9746177
    06/03/2014 (PG 27) – S4 Racewars https://www.audizine.com/forum/showt...=1#post9803418
    06/20/2014 (PG 27) – 01E Rebuild https://www.audizine.com/forum/showt...=1#post9850824
    11/27/2014 (PG 29) – “Gauged” Cluster upgraded – one of my favorite mods!!! https://www.audizine.com/forum/showt...1#post10290699
    02/02/2015 (PG 30) – Multiple Cutch Failures https://www.audizine.com/forum/showt...1#post10456276
    03/26/2015 (PG 33) – Clutch Stop https://www.audizine.com/forum/showt...1#post10602791
    04/12/2015 (PG 33) – Vibrant E-VAC Scavenger Kit – didn’t work… https://www.audizine.com/forum/showt...1#post10651287/
    05/06/2015 (PG 34) – Twin exhaust tips https://www.audizine.com/forum/showt...1#post10716803
    09/04/2015 (PG 35) – Blow thru flow conditioner https://www.audizine.com/forum/showt...1#post11019455
    09/22/2015 (PG 35) – Back to Draw thru MAF with flow conditioner https://www.audizine.com/forum/showt...1#post11062654
    01/22/2016 (PG 36) – 2nd Flex pipe failure https://www.audizine.com/forum/showt...1#post11346042
    02/18/2016 (PG 37) – Upgraded up pipe with turbo flex bellows and brace https://www.audizine.com/forum/showt...1#post11411434
    03/08/2016 (PG 38) – Oil Pressure data log with graph https://www.audizine.com/forum/showt...1#post11460348
    04/06/2016 (PG 39) – Custom Fuel HAT and SS PTFE fuel line https://www.audizine.com/forum/showt...1#post11529792
    04/25/2016 (PG 39) – 2.33 FATS https://www.audizine.com/forum/showt...1#post11578334
    05/03/2016 (PG 39) – STK vs. B8 Stage 2 race gas (e30 mix) https://www.audizine.com/forum/showt...1#post11597676
    05/09/2016 (PG 39) – PSI Proformance Dyno Day – 711 whp https://www.audizine.com/forum/showt...1#post11610017
    05/16/2016 (PG 39) – STK vs. 2015 GSXR 750 https://www.audizine.com/forum/showt...1#post11624807
    07/06/2016 (PG 40) – 3.5” VAREX valved muffler install https://www.audizine.com/forum/showt...1#post11735182
    07/11/2016 (PG 40) – Fuel System Upgrade Parts List and Diagram https://www.audizine.com/forum/showt...1#post11746680
    10/17/2016 (PG 40) – 2.0 Coil Conversion Troubleshooting/Solution https://www.audizine.com/forum/showt...1#post11953060
    04/28/2017 (PG 41) – Exhaust Back Pressure Log/Graph https://www.audizine.com/forum/showt...1#post12383291
    05/30/2017 (PG 42) – 034 up pipe fixed for the 3rd time – weld crack https://www.audizine.com/forum/showt...1#post12450966
    11/12/2017 (PG 43) – Freshly built 2.8 heads installed https://www.audizine.com/forum/showt...1#post12785477
    05/10/2019 (PG 44) – ATCO dragway – E85 11.59 @ 130.75 mph https://www.audizine.com/forum/showt...1#post13664608
    03/18/2020 (PG 44) – CM850 clutch install https://www.audizine.com/forum/showt...1#post14061307
    03/24/2021 (PG 45) – Aftermarket close ratio 1-2 gearset install – failed after 500mi https://www.audizine.com/forum/showt...1#post14474405
    04/23/2021 (PG 45) – ATI Crank Pulley https://www.audizine.com/forum/showt...1#post14502470
    09/20/2021 (PG 45) – H&R coilovers replaced with BC Racing https://www.audizine.com/forum/showt...1#post14616528
    03/29/2022 (PG 46) – Welded Main Web in Block – 1000whp build https://www.audizine.com/forum/showt...1#post14732626
    06/13/2022 (PG 46) – Secondary Firewall Removal + Tubular Manifold Mockup https://www.audizine.com/forum/showt...1#post14773811
    06/27/2022 (PG 46) – Compound hot side creation – Teaching myself TIG Welding https://www.audizine.com/forum/showt...1#post14781125
    09/18/2022 (PG 47) – Compound intercooler piping https://www.audizine.com/forum/showt...1#post14823816
    10/25/2022 (PG 47) - Compound B5 S4 2.7T is running https://www.audizine.com/forum/showt...1#post14841913
    01/29/2023 (PG48) - Kenne Bell BAP installed https://www.audizine.com/forum/showt...1#post14887430
    Original 1st post below:
    Hi everyone,
    I am going to document my build as best I can (WITH LOTS OF PICTURES) since I am sure there are many people that are curious how my setup is going to perform. I also will update with videos of the car once I get her running. I also plan to hit the track and see what kinds of Ľ times I can throw down.
    Mods before 034 STK:
    Stock downpipes w/gutted pre-cats
    UUC VM3 catback
    Metal diverters
    K/N filter
    Jfonz stage 2 tune
    H/R street coilovers
    Podi mechanical boost gauge
    Iforged Flux 2-piece wheels
    Everything else stock
    On my previous GIAC 93 pump stage 2 tune (w/stock DPs) that I was having over boost/throttle cut issues with (due to failing egts), I put down 295wtq, 265whp on AWE’s dyno.
    Upgrade list:
    - Precision PT5858 Ball Bearing Turbo, .64AR turbine housing
    - Precision 8” x 24” x 3.5” intercooler, rated at 600hp
    - 2.5” intercooler piping
    - Tial MVR 44mm wastegate
    - Tial QR recirc valve, 10psi spring
    - 2.8L V6 exhaust manifolds – ceramic coated
    - 034 up pipe/downpipe – ceramic coated
    - Custom 3.5” 304 SS exhaust, 1 or 2 – 3.5” magnaflow mufflers (rear is removable via V-band)
    - Southbend stage 3 drag clutch kit, Fidanza LWFW
    - Custom 90mm intake/MAF assembly, OEM Hitachi MAF
    - EV14 72lb injectors
    - Bosch 044 fuel pump
    - Zeitronix wideband/5.0 Bar MAP/EGT multi-gauge and data logging setup
    - 034 Motorsport race engine mounts
    - 034 Street density transmission mounts
    - 034 billet diff carrier and street diff mounts
    - USP metal clutch slave w/braided line
    - MK3 golf coolant tank
    - Custom catch can setup
    - DM forged rods, stock pistons/heads/intake manifold/TB for now
    Onto the Pictures:
    And it was my son's 4th birthday on Friday so he has his birthday hat on :)
    Success!
    The motor is currently waiting for me to install rods, but that will have to wait till Tuesday after Christmas.... Plan is to have the first start by next weekend! And turns out I need two of the smaller oil pan turbo drain fittings, so Max will need to swap out my larger fitting for a smaller one. Hopefully that doesn't delay me too much....
