Results 1 to 23 of 23
Hybrid View
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Help, Help, Help
    Driving home today car lost total power and engine light came on, the car turns on but has a very rough idle, rough! Anybody have any guesses?
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    P030x would be the first thing that comes to mind. You need to read your codes to find out which cylinder is misfiring....then change out that coil.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Sep 18 2012
    long beach
    About a month ago I replaced my spark plugs, so I think that is a good start. What do you recommend to get a read out? Never done it before.
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    yeah sounds like a coil then, that or a really bad fueling issue.
    Kris
    Dec 28 2011
    North Texas
    see if someone in the local area can scan it for you i'm sure i am not the only one on here with a vagcom or obd2 tool
    Kris
    Feb 13 2004
    Silicon Valley, CA
    You, you have aboard oil pack
    Kevin - Moderator, Audizine
    Dec 28 2011
    North Texas
    look and see if oil is coming out of the oil fill cap could be a pcv problem. Is it making any noises other then feeling the rough idle? If i wasn't busy this week i would help you out by scaning your car, but if you can wait till after xmas i could help ya.
    Kris
    Sep 18 2012
    long beach
    I have an upgraded PVC valve solution, with a catch can, so I don't think that is it. The car is not making any weird noises, but it idle rough enough that it feels like is going to turn off.
    Dec 28 2011
    North Texas
    unless the coil completely failed it shouln't have killed it. do you feel a loss of power meaning you would be in limp mode?
    Kris
    Sep 18 2012
    long beach
    There is definitively a lost of power, I tried to engage the first gear and the car started kind of shaking and felt like it was going to turn off. Thanks for offering your help, but I wouldn't want to put you out your way, plus I will be in Utah riding. What do you use to do the read out? Would this work?
    http://www.autozone.com/autozone/acc..._&target=shelf
    Quote Originally Posted by slvrb7 View Post
    Dec 28 2011
    North Texas
    yes that scanner would work as well but its sort of a waste to buy just a scanner that reads CELs and nothing more, but if you do get just read and post what code it popped out.
    Kris
    Sep 18 2012
    long beach
    I think I will give this a try, I can always return it. What do you mean by only CEL? I know the good scanner is crazy money, do you recommend anything else?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Quote Originally Posted by Krusty View Post
    VCDS
    Dec 28 2011
    North Texas
    well perfect wait till you get back from utah and then i should be back in the area like i said after xmas. Wouldn't bother me to help a fellow audi enthusiast.
    Kris
    Sep 18 2012
    long beach
    I will hit you up for sure if I can't get this worked out, thanks.
    Oct 14 2009
    Okinawa Japan
    probably a coil, but also could be a large vacuum leak
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: Help, Help, Help
    Quote Originally Posted by DRAKLORE View Post
    This. I had a stock intercooler hose blow off while driving on my jetta. It was like a blown coil pack x 10. Same thing when I lost my intake manifold plug on this car.
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
    Oct 14 2011
    Lots of options being thrown out....but knowing the code would save you the time required to work through all the suggestions.
    Sep 18 2012
    long beach
    Hello guys,
    I replaced all coil packs and the car looks back to normal and idles good, but will know for sure once I scan it. Let me know if this scanner is any good, had good reviews on Amazon. Will post the codes as soon as I get them.
    http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
    Sep 18 2012
    long beach
    I replaced the coil packs and the car looks and sounds normal, I scammed the computer and found out that there was a misfired on cylinder one. Is there anything else I should replace? I wanna make sure everything is perfect.
    Oct 14 2009
    Okinawa Japan
    you scammed the computer!
    -Shane Drake-
    >DRAKLOREs Build<
    Oct 14 2011
    one letter off on the keyboard is all it takes...
    So you got P0301. keep the other coils as backups, they're still good (well useable)...throw one in your trunk (next to that quart of oil we all keep in there) so its handy next time one gives out.
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    Quote Originally Posted by mcpcartier View Post
    ^so true lol
