Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 154
  1. #41
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    Quote Originally Posted by jibberjive View Post
    This has got me curious on how you are going about doing the different boost maps. Are you essentially putting your module in-line between the ECU and the N75, and attenuating the duty cycle signal by multiplying it by a scalar (essentially scaling the KFLDRL map)?
    I haven't done anything with the PPD's boost control mapping. Running Eurodyne allows me that within the ECU. The shortcoming of boost control within the ECU is PID control is lost above 22.6psi. For a while I tinkered with the boost control functionality in BoostManager (I mean, the name kind of dictates I at least try). But I couldn't get my head around the PID instructions and went back to good ole Maestro.
  2. #42
    Oct 19 2009
    Portlandish
    After I discovered the Eurodyne BoostManager's fuel pump "bug", C.Tapp changed the program to remedy it. So with the PPD now able to monitor fuel pressure, I tested the pump control via BoostManager. Here's what I saw:
    I was interested to see that the bigger pump flows a bit too much for the fpr to, well, regulate. At least at idle that's the case. I need to log the car WOT to see what's happening at increased fuel flow.
  3. #43
    Oct 19 2009
    Portlandish
    Well, with the in-line pump engaged it appears that the pressure delta persists throughout the power range. I'd had no idea this was happening. But it explains the fuel trims always pulling back the injectors at top end.
  4. #44
    Sep 18 2012
    State College PA
    I just want to give this thread a bump by saying that I think I'm going to buy one in the new year...
    I think the logging ability will be very useful and the boost control sounds very tempting.
  5. #45
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    STE Performance Parameters Display (PPD) installation and use
    You can check it out in my car at the end of the month! I didn't get the boost controller though.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
  6. #46
    Sep 18 2012
    State College PA
    Quote Originally Posted by MileMan402 View Post
    Sweet!
  7. #47
    Oct 19 2009
    Portlandish
    After getting the buggy fuel pump sorted, the PPD logger can now show how well the fuel pressure mirrors boost. In this graph I have the two vertical axes scaled so that the two curves overlay one another. Also, the data points are marked, which shows the nicely fast refresh rate.
  8. #48
    Veteran Member Four Rings tjb616's Avatar
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Really intrigued by this product. Does anyone have an idea if an ethenol content analyzer can be hooked up to display via this device?
    Has anyone played with the live adjustable boost settings yet?
  9. #49
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I would thnk so, should be able to hook anything with a 0-5v output to it.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
  10. #50
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Admittedly Im not very savy when it comes to the details of how these gauges work. But its my understanding that products like the zeitronix eca hooks up to any sensor and gives the readout on its display. Would I need to buy their display (does it have any function that allows it to decode the reading, in other words) or will a gm sensor set straight to this unit give me a readout? Sorry for the primitive and semi-ot questions, dont want to clutter this thread too much but it would be a huge selling point for me.
    B7 RS4 - Mugello, Wingbacks & Jackal
    B7 Avant S Line Ti 6mt - 2.7t & 770R
    B5 S4 - Santorin, EPL Stage III
    993 C2 "RS CS" Track Car
    964 C2 Coupe
  11. #51
    Oct 19 2009
    Portlandish
    Quote Originally Posted by tjb616 View Post
    On the contrary to being clutter, these are really good questions. Until now I didn't even know such a thing existed. Can you give us a link or two for research? Because this is just the kind of capability the PPD should incorporate.
    Thanks for the idea.
  12. #52
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
  13. #53
    Nov 16 2010
    WetSide, WA
    I havent played with the PPD software yet but would be nice to have a custom sensor calibration dialog for running custom sensors.
    Guessing you have some demo units out to a few select individuals who could prob set this up pretty easily.
    This is how motec does it. Pretty simple, just give it a name, transfer the voltage/values from the sensors data sheet, and off to the races!
  14. #54
    Jan 11 2007
    Salt Lake City, Utah
    As is, without it being custom set up to do the 'translation' of the ethanol content sensor, it won't work with those sensors. The ethanol sensors don't have a simple 0-5v output like the auxiliary inputs of the ppd require, rather the sensor outputs a PWM signal that tells both the ethanol content and the fuel temperature. I agree, would be awesome to have this functionality built in.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
  15. #55
    Sep 18 2012
    State College PA
    So we just need to make a conversion board that outputs 0-5V ;-)
  16. #56
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    http://www.zeitronix.com/Products/ECA/ECA.shtml
    That translation is exactly what I was afraid of / talking about. Its a bummer that it wont save me a couple hundred bucks to help justify the purchase of this but I will probably try to make it work just for cleanliness.
    Is the conversion board a replacement for the translator or to go between the translator and this product to make it read on the dash? Next question, who knows how to make one!?
    964 C2 Coupe
  17. #57
    Oct 19 2009
    Portlandish
    Holy cow. I hadn't realized what you were talking about until you posted that link. What a terrific data-collection idea this is! I notice it's got an output to a gauge, which makes me think it will do a 0-5v output. That gauge probably works on that basis. I am very interested in testing for this.
  18. #58
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    If you need a car try it with, Im going to try this after the holidays are wrapped up. Already have my E85 parts and a tuner lined up. Just need to pick up this tool and the ECA.
    964 C2 Coupe
  19. #59
    Sep 18 2012
    State College PA
    I could probably make a board that would take the signal from the Ethanol sensor and output a 0-5V signal... Now if only I had a unit to play with :-P
  20. #60
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Do you just need the sensor?
    964 C2 Coupe
  21. #61
    Sep 18 2012
    State College PA
    Well I was thinking a PPD unit too but yes I'd need a sensor lol ;-)
  22. #62
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    I meant would you need the Zeitronix unit to reference as well.
    964 C2 Coupe
  23. #63
    Sep 18 2012
    State College PA
    That would probably be a good idea yes
  24. #64
    Oct 19 2009
    Portlandish
    At first blush it looks as though you'd need both the sensor and the gauge. The latter component outputs "analog 0-5v" which is the ticket to getting the PPD to log and report. Judging by their scaling map, it's just a straightforward linear output. So it looks doable...if a bit pricey.
  25. #65
    Sep 18 2012
    State College PA
    Quote Originally Posted by Doug@FrankenTurbo View Post
    I'm going to look into making a board that would convert the square wave from the sensor into a 0-5V output... :-)
  26. #66
    Sep 18 2012
    State College PA
    If I'm right it will only take about $5 or $10 worth of parts to convert the signal... I'll work on it at work tomorrow :-)
  27. #67
    Mar 18 2010
    Ottawa
    Shhh, don't tell "work" you aren't working on work....JK
    But I am looking forward to what you find.
  28. #68
    Sep 18 2012
    State College PA
    Quote Originally Posted by Ribbie View Post
    That's what they make lunch breaks for :-P
  29. #69
    Jan 11 2007
    Here's a post I made a while ago, when I was just going to use a digital O-scope in place of the Zeitronix E85 gauge (I've since acquired the Zeitronix E85 gauge, as I'm now a distributor for them).
    http://www.audizine.com/forum/showth...-to-know/page2
    I plan on getting my car running E85 and the ECA gauge within likely the next few weeks. Would be nice if there were another option for the PPD that didn't require the standalone Zeitronix ECA, so that you're not essentially double spending on that. I look forward to what you come up with britishturbo.
    LOOKING FOR:
  30. #70
    Sep 18 2006
    Colorado
    New oscilloscopes are small and compact like that? The oscilloscopes we used in college looked similar to this(big grey box, monotone screen, floppy drive)
    The sad part is I just graduated last year #brokestatus
  31. #71
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Britishturbo that would be amazing, if you have luck and need a sensor, Ill see what I can do about getting one to you. Im currently back in Philly with the car so hopefully we can get one up and working.
    And yes jibberjive it would be a bummer to have to buy both only to tuck the Zeitronix behind the dash and wire the gauge output to the PPD.
    964 C2 Coupe
  32. #72
    Sep 18 2012
    State College PA
    Once I'm ready to actually work on it, I'll let you know... I'm 99% certain it can be done easily and cheaply.
  33. #73
    Oct 19 2009
    Portlandish
    Assuming the data-logger would be making use of the linear analog output from that gauge, I don't see why you couldn't substitute an inexpensive Auber 1813 gauge to generate the 5v signal to the sensor. The return signal could then be routed to the PPD's secondary input.
  34. #74
    Senior Member Two Rings 01xSilverS4's Avatar
    Oct 06 2010
    LIKE
    Build phase: '01 B5 S4 - Silver
    PARTS NEEDED (contact me via pm if you have these): Euro rear bumper (Sedan), B5 RS4 gauge cluster, AWE boost gauge kit (v2 30psi), RS4 intake parts.
  35. #75
    Jan 11 2007
    I'm not familiar with the Auburn 1813, but if this is it, I can't see anywhere where it talks about being compatible with a PWM signal:
    http://www.auberins.com/index.php?ma...products_id=19
    Also, I just got the crazy idea that one may be able to put the ethanol sensor's PWM signal in place of one of the EGT's, and be able to log ethanol content and fuel temperature from the factory ECU, just like you would the EGT. Here's a link to where I posted a couple of preliminary thoughts, and if this does prove feasible, it will still take a good amount of hacking/software changes, so it won't be plug-n-play by any means.
    http://nefariousmotorsports.com/foru...c=2955.0title=
    LOOKING FOR:
  36. #76
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Cool idea, but personally Id rather leave the ECU alone.
    What exactly would you be datalogging from the ECA? You really only need to know the ethanol content when when you fill up correct?
    Im also unfamiliar with the Auber. My goal is simply to buy the sensor, and be able to convert the signal without purchasing a Zeitronix unit to read out the ethanol content of my fuel via the PPD. Not concerned about the fuel temperature. Your saying you could use the Auber in place of the Zeitronix ECA to do just that? And *britishturbo your thinking you could put something together to do it, but you would need the Zeitronix unit for reference? (which would be fine, I would just sell it to a friend afterwards)
    964 C2 Coupe
  37. #77
    Jan 11 2007
    I don't know if you clicked that link I posted above, but it's not just about knowing the ethanol content. I'm going to make my ME7 ecu a true 'flex-fuel' setup, and have it automatically change between a bunch of different fueling/timing/boost maps, based on ethanol content. And the reason why I care about fuel temperature is because I'm going to be running 2 fuel pumps that have the capacity to supply enough fuel for 1200+hp, though I'll only be around 600hp, so I will be experimenting with different ways to avoid heating up the fuel and overworking the fuel return system.
    And Jibber your thinking you could put something together to do it, but you would need the Zeitronix unit for reference? (which would be fine, I would just sell it to a friend afterwards)
    I'm not putting anything together to market it. Sounds like Britishturbo might be. I personally already have and sell the Zeitronix ECA.
    LOOKING FOR:
  38. #78
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    My mistake, I was referring too Britishturbo. I didn't realize you were using the ME7, that sounds awesome.
    964 C2 Coupe
  39. #79
    Oct 19 2009
    Portlandish
    STE has released new firmware and user interface for the PPD, so I took the laptop out to the FrankenTT for a try with it:
    The new software allows a bit more customization to the display, e.g. units of measurement. I am particularly happy to have the option of displaying Lambda versus air/fuel.
    The secondary analog input is currently "open", which allows me to configure the PPD to log air temperatures at the compressor outlet. This necessitated setting up an Auber Instruments analog-output gauge for a compatible output. This gauge's analog signal is 0-20mA, so that needs to be converted to 0-5v with a resistor. I know this sounds intimidating, but it basically involves little more than hooking up either end of the $2 resistor to the outputs of the Auber gauge. Here's a reading of the gauge's un-converted output:
    And here is the multimeter's reading with the resistor in place:
    With the gauge outputting voltage, I set about calibrating the gamut to match the PPD's mapping. Sean at STE provided me with this voltage scale:
    With that info in hand it was simply a matter of dialing in the high/low parameters on the Auber gauge. With a bit of experimentation, the voltages were in sync with the PPD's calibrations.
    Next step is to install the temperature probe at the compressor outlet and wire up the gauge and PPD. My guess is that can happen tomorrow.
  40. #80
    Feb 17 2010
    964 C2 Coupe
    Philadelphia
    Awesome writeup Doug. The new software looks great. Is that in a B6 though?
    Curious as to if they would ever consider an input from a V1 radar for a remote display option also...
    964 C2 Coupe
