Page 2 of 41 FirstFirst 123412 ... LastLast
Results 41 to 80 of 1623
  1. #41
    Oct 14 2009
    Okinawa Japan
    Wheels: Hartmann Euromesh 3s (Italy) 19X8.5 ET48
    Rear: +20mm spacers
    Front: No Spacer :(
    Tires: 235/35/19 (iirc)
    Suspension: FKs, bottomed and broken 23.5" FTG
    No fender liners, some rubbing
    Wheels:stock split 5s
    Spacers: rear +20mm
    Suspension: FKs 23" FTG
    Rear fender liners trimmed, no rubbing
    Wheels: Flik Artics 18X8 ET38
    Spacers: Rear +20mm
    Suspension: Koni SS 24.5" FTG
    Tires: Potenzas (iirc) 245/45/18
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
  2. #42
    Jul 19 2011
    Northern Minneapolis, MN
    Quote Originally Posted by derrek View Post
    awesome picture
  3. #43
    Mar 26 2007
    Colorado
    And awesome looking car!
    CURRENT:
    2021 Atlas
  4. #44
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by Geoffafa View Post
    Rotiform INDs
    Wheels and Offset 18x10 et19 front 18x11 et26 rear
    Spacer Size NA
    Tire Size and Make Nankang 215/40/18 front falken 245/35/18 rear
    Suspension Setup Customized KWv2
    Camber Settings -2.9 front -3.2 rear
    Toe Settings front set to OE spec, rear set to dead 0
    You just saved me some time on the wheel specs. Differences:
    Front tire is now 225/40
    Camber: no idea, going to mess around with it after winter
    Suspension: Airlift Struts, Autopilot V2 digital management
    Fenders: Pulled and rolled, but not enough
    Does it rub: When the bags aren't filled up enough, yahp.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
  5. #45
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    Wheels and Offset: OEM Mercedes Benz S550 22 spokes and OEM MB lugs 5x112 66.6 center bore 19x8.5 et43 (front) 19x9.5 et43
    Spacer Size: 11mm Forge spacer in rear w/ extended lugs
    Tire Size and Make: Falken FK452 215/35/19 (front) 225/35/19 (rear)
    Suspension Setup: K-Sport Knotrol Pros @ 23.5 FTG with room to go down
    Camber Settings: -2 all around
    Toe Settings: All fucked up
    The Fronts rubbed id the wheel was at full lock...like while making a u-turn
    The rears rubbed going into driveways and big dips but it wasn't the tire...the outer most edge of the rim would rub on the inside of the fender giving it a sweet polished time attack stripe lol
  6. #46
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    Beautiful cars above. Love Nicks avant.
    Wish I had some pics before putting the stockers on for winter.
  7. #47
    Sep 26 2012
    Ulster County, NY
    Damn, these are the threads that make me want to mod my B7, but I need this car stock
  8. #48
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    All stock
    Stock 17's on Vogtland Jr suspension. Arctic Claw Winter Txi M+S 225/45R17
    18"et35 USP Reps on Vogtland Jr suspension. Falken Ziex ZE512's 245/40Z R18 93w
    19" et32 Front et35 Rear Denaro B2's Same suspension as above Fullway HP168 235/35 fronts and 275/30 rears.
    18" et33 Flik Justice's 245 Dunlop SP Winter Sport M3
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  9. #49
    Senior Member Three Rings SPB.2127's Avatar
    Nov 28 2010
    Michigan
    sand-blasted and rattle-canned copper S5 reps on ST coilovers at the winter height
  10. #50
    Jul 11 2012
    Nottingham, UK
    Wheels and Offset: BBS CH Reps, 19" 8.5j, ET45
    Spacer Size: 12mm Spacers all round
    Tire Size and Make: Vredestine Ultrac Sessantas 235/35/19
    Suspension Setup: H&R 30mm Springs & S-line Shocks
    Camber Settings: Standard
    Toe Settings: Standard
    No rubbing, including track use
  11. #51
    Established Member Two Rings redfury's Avatar
    Oct 16 2012
    1968 plymouth fury 7mgte swap
    Modesto/California/Central
    how wide are the denaros operator they are sweet
    05.5 2.0T 6MT quattro/JHM Stage 1 Tune/JHM Solid Shifter/JHM 4:1Center Differential/JHM Stage 1 LWFW and Clutch Kit/JHM FMIC/034 Motor Mounts and Trans Mount/APR Turbo Back Exhaust/APR Carbonio Intake/Enkei RPF1 18x9 et35
  12. #52
    Feb 06 2009
    328d, Tacoma
    Quote Originally Posted by redfury View Post
    Front 19x8.5 Rear 19x9.5.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  13. #53
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Cause of you I am doing a staggered stance this summer. Hopefully new rims in February
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  14. #54
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    Updated on page 3
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
  15. #55
    Aug 03 2012
    '11 Touareg
    SEPA
    ^ looks good.
  16. #56
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Re: ..::The Official B7 Stance Thread::..
    ^^ love how it looks from the rear. Those tires look fat!
  17. #57
    Nov 08 2010
    Thanks guys! Wish I had some better HQ pictures of it with the carbon fiber rear valiance I now have installed. Looks even better.
    DTM_B7_S4
  18. #58
    Veteran Member Four Rings TMurt's Avatar
    Feb 01 2011
    Indianapolis, IN
    nothing special at all
    Wheels: OZ Superturismo LM ET43
    Rear: No Spacer
    Front: No Spacer
    Tires: 235/40/18
    Suspension: Eibach springs, Koni sport shocks (25" more or less)
    Current: 2010 Imola S4 Prestige 6MT
    Past: 2007 Audi A4 3.2 Quattro
  19. #59
    Senior Member Three Rings Sharper_Image's Avatar
    Mar 21 2013
    Warwick, RI
    quick question for you guys that are staggered, are you guys quatro or fwd ?
  20. #60
    Oct 14 2009
    Okinawa Japan
    Quattro
    -Shane Drake-
    >DRAKLOREs Build<
  21. #61
    Veteran Member Four Rings Checho's Avatar
    Dec 25 2009
    Miami
    fwd, all for show lmao
  22. #62
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by Checho View Post
    I can't imagine how Badass my car would look if I never put money into the motor!
    Envy you :)
    -Shane Drake-
    >DRAKLOREs Build<
  23. #63
    Dec 25 2012
    ft laudey
    18x9.5 all around
    et20 all around
    215/40 all around
    airlift struts, accuair elevel management
  24. #64
    Mar 21 2013
    Warwick, RI
    kool thanks keep the pics coming some sexy b7 up in here
  25. #65
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    KW ST Coilovers
    034 RSB
    24" FTG all around
    Stock front toe
    -2.1 front camber
    Stock rear toe
    Stock rear camber
    B7 Sline Ti wheels
    Stock sized tires (my winter setup)
    Doesn't rub
    KW ST Coilovers
    034 RSB
    24" FTG all around
    Stock front toe
    -2.1 front camber
    Stock rear toe
    Stock rear camber
    19X8.5" VMR 710 ET35
    235/35/19 on all four corners (my summer setup)
    Doesn't rub....at least not until I throw passengers in the back seat and/or a cooler full of beer/ice in the trunk.
    I hate the whole "stance" thing so much that I typically hate talking about it.
    -Dan
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
  26. #66
    Jan 11 2011
    UK
    kw adjustable spring kit -45 mm
    10mm spacers rear 8mm front
  27. #67
    Feb 20 2004
    Quote Originally Posted by Rick_RS4 View Post
    That looks super sharp Rick! OEM+ is my favorite.
    -Dan
    Previously:
  28. #68
    Jan 11 2011
    UK
    Quote Originally Posted by Lensch09 View Post
    -Dan
    thanks, really want some rolling shots taken from a decent camera and not like these from my phone.
  29. #69
    Veteran Member Three Rings Clown4's Avatar
    Aug 29 2008
    '08 Quartz Gray S-Line B7 2.0T
    Rainbows and Unicorns
    have we got more running on 9.5 all around?! This thread is too good to be missed!
    Quote Originally Posted by livinthelowlife View Post
    18x9.5 all around
    et20 all around
    215/40 all around
    2008 B7 A4 Quartz Gray 2.0T Quattro 6-spd MT.
    Full S-Line | Special Edition | Technology Package | HomeLink
    ____The Last of B7._
  30. #70
    Apr 22 2013
    Mill Creek, WA
    Here is my s4
    Miro 111 19x9.5 8mm spacers up front 15mm rear
    <img src=http://farm9.staticflickr.com/8400/8694826117_bc5dd7fb87_z.jpg>
  31. #71
    Veteran Member Three Rings Audi_'s Avatar
    Sep 07 2012
    1984 533i S52 on 2 bar boost
    Seattle, Washington
    Quote Originally Posted by Mr.Minchuk View Post
    Here is my s4
    | 25th Quattro S4 |
    Not low enough, not fast enough
  32. #72
    Established Member Two Rings soleam87's Avatar
    Apr 07 2011
    Slow ass B7 on Land Rover Wheels
    Florida
    I've been meaning to do this...
    Current
    Wheels and Offset: Land Rover Sport 19x9 et53 (final et33f et28r) Powder Coated Gloss White
    Adapter Size: 20mm front, 25mm rear
    Tire Size and Make: 215/35 Falken FK452
    Suspension Setup: KW V1, 24.5" fender to ground
    Camber Settings: -1 front, -2rear
    Toe: Unaligned
    Old
    Wheels and Offset: Mercedes S550 22 Spoke 19x8.5 et43f, 19x9.5 et43r
    Adapter Size: 15mm front, 8mm rear
    Tire Size and Make: Falken FK452 215/35f 225/35r
    F.T.W.L.T.B.D.W.I.C.T.W.
  33. #73
    Veteran Member Four Rings crazytex21's Avatar
    Jan 31 2010
    Georgia
    i really wanted to run those land rover wheels a while back. there was a set on ebay for a good price, but i never pulled the trigger. they look great on your car man.
    tex lee
    A lot of people think you want to race, when in reality, you just have to motor home because Chipotle.
    ~Shicky~
  34. #74
    Apr 07 2011
    Florida
    Quote Originally Posted by crazytex21 View Post
    Thank your Sir
    Going up for sale soon too! Not too far from you
  35. #75
    Jan 31 2010
    Georgia
    Quote Originally Posted by soleam87 View Post
    Thank your Sir
    o rly? might have to check that out. i think you know my roommate...
    tex lee
    ~Shicky~
  36. #76
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    Wheels and Offset - 19x8.5 Work Varianza t1s, et32
    Spacer Size - none
    Tire Size and Make - Achilles Sport atr tires 235/25/19
    Suspension Setup - Eibach Pro Street-S coilovers
    Camber Settings -
    Front
    Camber : -1.5 deg
    Toe: idk
    Rear
    Camber: -2.2 deg
    Toe: idk
    no rubbing
  37. #77
    Veteran Member Four Rings glissoar's Avatar
    Oct 16 2010
    2010 Jk Unlimited
    virginia beach
    Wheels Merc s550 Wheels 19x8.5 19x9.5 et 43 all round in Porsche Lime Gold, No spacers, straight up
    Tires Hankook Ventus V12 Evo 225/35/19 F 235/35/19 R
    2008 A4 *For Sale*
    CTS K04, United Motorsports Tune, Brute Rods, CP pistons, 9:1 compression, Autotech Fuel pump rebuild, ARP head and main bolts, RS4 injectors, Custom built FMIC, 034 cat (gutted), AWE Exhaust, Stasis SS Coilovers, Stack boost gauge, Hydrographic dip trim, Ti Front Grill
  38. #78
    Active Member Two Rings IX Equilibrium's Avatar
    Apr 08 2013
    2008 Honda CRV (hey, I'm a family man!)
    Phoenix
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  39. #79
    Nov 08 2010
    ^Any wheel/tire/suspension specs? Helps folks get an idea of what they're looking at.
    DTM_B7_S4
  40. #80
    Apr 08 2013
    Phoenix
    TSW tremblent matte black 19X8.5 et 32
    No spacers
    Continental sport contact 245/35/19
    H&r sport springs
    Have some rubbing in the front when making turns
