Background- Previously had misfires over the summer which fired the CEL and codes. So I replaced all spark plugs and regapped them, and everything was good for a while. A couple weeks later, I started getting mild stumbling during hard acceleration, so next I replaced the Coils with the new F versions. This did nothing, and I still got mild stumbling during hard acceleration, but it did not fire any codes. So, finally I took it in to Audi to have the recall parts replaced (PCV, IMRC, and something else), which they did free of charge. Thinking it was the PCV gone bad (which was bad...it had some severe suction on the oil cap while running) causing the stumbling, I started the drive home. Once on the highway, I accelerated relatively hard, and found the same stumbling was still there. I continued to push it harder and harder trying hoping it would fire a code or CEL and to further diagnose it. Well, it did, gave me a blinking CEL and severe stumbling under any acceleration. I immediately pulled off and waited a bit. I started it up after a few minutes, had a solid CEL and found severe stumbling at idle and when trying to drive even in first gear. So I had it towed home, where I VAG-COMed it and got the following codes:
00280-Differential Lock Valve 2 (N126). Sporadic. Lower limit exceeded
00256-A/C Pressure/Temperature Sensor (G395) Sporadic. No signal/communication
00768-Rear Heater Core Temperature Sensor (G154) Sporadic. Upper limtit exceeded
00770-Coolant Temperature Sensor at Radiator Outlet (G83) Sporadic. Upper limit exceeded.
BUT NO MISFIRE CODES
So for the past two weeks, the car has been undriveable. It takes about 5 seconds to start up, idles rough, and the engine cooling fans run as soon as I turn the car on now, and increase in intensity after a few seconds. I've heard a bad thermostat can cause this (though I didn't get a code for it), so I went ahead and ordered a new one.
I went ahead and replaced the ECT/CTS immediately since it was so cheap and easy. However, I didn't think that little sensor going bad could cause this big of a problem, so I wasn't too disappointed after I replaced it and still had a car that can't get on the highway. My thermostat should be here in the next couple of days, but I have doubts about it solving the problem as well.
I searched high and low about the differential lock valve code, but could find nothing about it on forums or google. I'm not sure if it could cause these problems either, it doesn't sound like it should be directly to these problems. Does anyone have any idea what could be going on? I haven't checked the Cam Follower for wear, but it doesn't sound like that's the problem either. I'm just lost now after searching for weeks and still have no good leads to diagnose this ENORMOUS HEADACHE.
Thanks in advance guys, sorry for the novel^
