Results 1 to 40 of 700
    Deactivated Three Rings NOFEARCT's Avatar
    Feb 25 2013
    Philly
    Quote Originally Posted by marzz View Post
    haha we got to do some try fits ... see what happens
    was interested in 315/30/19
    Front and rear? Or staggered? Haha
    Veteran Member Three Rings marzz's Avatar
    Sep 19 2012
    Sydney
    Quote Originally Posted by NOFEARCT View Post
    don't think 315 at the front would be too healthy ...
    Veteran Member Four Rings Not A Good Idea's Avatar
    Apr 26 2012
    Hmmmm...
    Li. Ny
    looking great so far.
    max in the rear would be 11"et25 with a 305. same in the front but your max turning radius will suffer.
    Feb 25 2013
    Philly
    Quote Originally Posted by Not A Good Idea View Post
    At ride height or lowered?
    Apr 26 2012
    Hmmmm...
    Li. Ny
    lowered.
    i run 11" with 295 only because im on air. there is literally 1mm space between my fender and rim in the rear. no rub.
    http://www.audizine.com/classifieds/...107_082252.jpg
    Feb 25 2013
    Philly
    lowered.
    Nice, looks good
    Sep 19 2012
    Sydney
    lowered.
    cheers, the RS5 hubs are thicker then S5 so the offset would have to be different ...
    Feb 04 2010
    Jeddah, Saudi Arabia
    only this guy would do it lmao
    i used to have 305's on my old set in the rear
    Instagram: @TheDapperDriver
    Sep 19 2012
    Sydney
    I have 20x10.5 all around on 295/30... They fit perfectly, but I'm not lowered. I have a friend who wedged 305 in the back of an S5 so it should be no problem on your RS. I would venture to say you could even make 315's work. I know that 325's are available from Michelin in a much smaller overall diameter, so even those might be work-able. Who knows. If anyone can do it, I would pick you.
    295/30/20 increases the diameter vs stock, how accurate is your speedo if you don't mind me asking?
    305, what offset?
    the minimum will be 305 but has to work when very low, as this my be the track only setup, so semi or slicks have to be available in that size ...
    Honestly, even the 295's are a bit much at times to have in the front. I mean a lowly Veyron only has 265's in the front. I just worry that staggered setups will only contribute to additional under steer.
    happy with 275 at the front but thinking of 255-265, understeer not necessary, if you setup your suspension properly, R8 runs staggered as stock ...
    Quote Originally Posted by bader.abbas View Post
    305, what offset?
    Feb 25 2013
    Philly
    295/30 vs 275/30 is less than a 2% increase in overall diameter, the speedometer for the most part is still pretty accurate.
    The Veyron comment on might part was a joke, you can't compare the RS5 with the massive engine way out front to an R8 or a Veyron... Of course those cars run staggered setups but they won't understeer like ours because the engine won't be pulling the car off of the proper line through the corners. Understeer really only occurs when the front tires lose grip before the backs do, putting on smaller tires in the front (relative to the back) won't help that.
    Sep 19 2012
    Sydney
    in for check up recently ...
    Established Member Two Rings Jsivadas's Avatar
    Sep 27 2013
    Sooooo sexyy!!! Awesome job man!!
    Instagram: jsivadas
    Sep 19 2012
    Sydney
    Quote Originally Posted by Jsivadas View Post
    thanks mate,
    Feb 04 2010
    305, what offset?
    was during when i had my concave dpe set, DPE does not reveal their offsets so no clue really
    Sep 19 2012
    Sydney
    think I'm done with the exhaust, unless something brakes, the initial sound in combination with the SC wine is just awesome , best I've had so far, mind due the Kline setup is bigger in diameter 2.75" vs 2.5" stock, clips to follow when sound settles in ...
