Page 2 of 14 FirstFirst 123412 ... LastLast
Results 41 to 80 of 522
  1. #41
    Jul 19 2011
    Northern Minneapolis, MN
    Thanks Shane. I was waiting for you to chime in. I should throw you in to the OP too!
    EDIT: Done
  2. #42
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Bunch of good info! Best thing I learned is I have my catch can routed wrong lol. The port closest to the firewall goes on the top and the one closes to the grille goes to the side, so I definitely need to swap those around, then I will delete that rear pcv and avoid getting more oil into my new intercooler :) Thanks guys
  3. #43
    Oct 14 2009
    Okinawa Japan
    I think the Catch can routing is dependent mostly on design, like the vortex can and others differ from those with baffles?'
    And thanks Corey :)
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
  4. #44
    Veteran Member Four Rings jrtrainor's Avatar
    May 07 2011
    94 yj 88 bronco 15 fusion
    The mountains, CO
    OK so To recap for someone running an RAI Catch Can I would need to make the following changes to fully take care of my system.
    1. Make a plate out of a tin can to block the larger hose on the rear PCV.
    2. Vent the smaller hose on the rear PCV to atmosphere with a small filter.
    3. Disconnect the hose farthest from the front of my engine on the intake PCV and somehow block that hole on the billet plate and then put a filter on the end of that hose allowing it to vent to atmosphere.
    4. Finally can i leave the RAI CC to recirculate like it was originally designed? I can take a picture and label what im talking about but the GF took the car to work today so I would have to post it up in a couple hours.
    I lied here is my setup on the intake side. The rear side is completely stock so no need posting that image.
    B7 A4, GTX2867R 8.3:1 CR 2.149L motor Build
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    "Call him the Redneck mechanic with the beard of glory"
  5. #45
    Oct 14 2009
    Okinawa Japan
    JrT, if you eliminate the large Rear PCV. And vent anywhere in your catch can (preferably upstream) to atmosphere, that should be essentially everything you need.
    See you can leave all your catch can hoses intact, but because your eliminating the rear PCV you need someplace for that pressure to go (which means no longer into your intake!)
    So adding a "T" fitting and a small filter, or tapping the top of your catch can and adding something similar to this:
    ^BSH RACE CAN^
    Will net you a very good system that will be low maintenance, and almost no carbon build up
    -Shane Drake-
    >DRAKLOREs Build<
  6. #46
    May 07 2011
    The mountains, CO
    Quote Originally Posted by DRAKLORE View Post
    ^BSH RACE CAN^
    So blocking the back pcv causes extra pressure so leaving the piping as is now all i would have to do is put a vent on the top of my can. Why leave the piping back into the intake. and why leave the third connection (top connection in my picture) connected. Isnt that dumping oil into the intake? Causing the "almost" no carbon buildup.
    Edit: God i feel like such a noob still and ive learned so much but this simple f'ing solution seems complicated to me wtf
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  7. #47
    Oct 14 2009
    Okinawa Japan
    that top connection, doesnt come from or go to the intake... it comes from the block, and routes the pressure to the head.
    In normal operations that pressure is then routed back into the intake, carrying oil vapor with it and causing carbon buildup..
    So by blocking the rear PCV you eliminate its path to the intake tract, but now you have a pressure builup issue with the potential for blowing seals.
    to eliminate this from happening, you need to at some upstream point (a point where the vapor/pressure is cleanest) put an atmospheric vent.
    My vote would be the top of the catch can, but it could be a T anywhere in that system, you could even run a rubber hose from the rear pcv port with a tiny filter attached.
    I hope thats easier to understand.
    Shane Drake
    -Shane Drake-
    >DRAKLOREs Build<
  8. #48
    May 07 2011
    The mountains, CO
    PCV Modification and Education Thread
    Shane Drake
    Ah now it makes sense. So I leave my catch can as is routing wise.
    I put a filter on top of the catch can.
    Block off the larger rear Pcv with a plate
    Run a small filter on the port next to the larger rear Pcv hose. And I'm done. No more oil gunk is entering my intake.
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  9. #49
    Jul 19 2011
    Quote Originally Posted by jrtrainor View Post
    Yup, and you are going to want to unhook your intercooler hosing and spray a ton of brake cleaner in there!
  10. #50
    May 07 2011
    The mountains, CO
    Quote Originally Posted by CorneliusRox View Post
    to clean out oil residue?
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  11. #51
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Yep, drain the IC's then clean them well. Make sure you let everything dry out well before hooking them back up.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
  12. #52
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 15 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Nice! Reminds me of what I did...it doesn't jism oil too bad but if you're running an oiled filter it will turn black after about 2 weeks.
    Just a little fun fact, PCVs were actually introduced for tanks so that when crossing bodies of water, they wouldn't suck in water damaging the engine. They were later required on all cars as it does prevent pollution to the environment (by polluting your valves lol)
    A friend is building a factory five Cobra with the new 32v 5.0 and while it's catless, he said he's going to keep the PCV because it's illegal without it? I'm pretty sure a catless 5.0 v8 does more damage than a little hose squeezing out oil...
  13. #53
    Jul 17 2012
    2003 toycamse w/150kmiles
    Bowie/Maryland
    You should use carb cleaner instead of brake cleaner
  14. #54
    Jul 19 2011
    Quote Originally Posted by davvinchi View Post
    What's the difference other than the fact that one is already in my garage ;-)
  15. #55
    May 07 2011
    The mountains, CO
    x2
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
  16. #56
    Jul 17 2012
    Bowie/Maryland
    Brake cleaner is a little more volitile and can do bad things to sensors.
  17. #57
    Jul 19 2011
    Brake cleaner is a little more volatile and can do bad things to sensors.
    Good point, avoid the MAP! With either.
  18. #58
    Oct 14 2009
    Okinawa Japan
    I wasn't supposed to clean my MAP with brakleen?!
    JFK lol
    Anyways I'm glad that some people are actually going to benefit from this information
    -Shane Drake-
    >DRAKLOREs Build<
  19. #59
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Finished product
    Finished my carbon clean and full PCV rebuild/delete this weekend.
    Breakdown:
    - IE valve cover
    - 034 catch can (modified)
    - rear pcv blockoff
    - crankcase pcv routed to catch can
    - vc pcv tied into catch can
    Block off of large, rear pcv with small hose re-routed.
    Valve cover, -10an fitting, large hose routed down to catch and small hose on right from turbo
    Catch can and large hose from crank case with T-fitting connected to the VC.
    Close up of crank case hose, T-fitting and vc hose
  20. #60
    Jul 19 2011
    looks good! welcome to the clean intake group ;-)
  21. #61
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Thanks. Hopefully this second design is a full fix, not another bandaid. I was running the full 034 system before, never blocked rear pcv and still had tons of oil in the intake and smoking under hard pulls.
    As of today, no oil in new tb hose, no smoke from exhaust all the way up to 24psi. Vacuum seems to be holding steadier and car runs much smoother.
  22. #62
    Jul 19 2011
    Quote Originally Posted by Flexcj5 View Post
    It's pretty full proof. It just doesnt meet the emissions that Audi needed to in order to originally sell the car.
  23. #63
    Oct 14 2009
    Okinawa Japan
    looks good Brad, could we get a better description of the routing for the Catch can. like where the second port is routed to
    -Shane Drake-
    >DRAKLOREs Build<
  24. #64
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    No second port. I capped it off with the breather. I can't see a reason to route another hose the way I did it.
    The main (large hose) comes off the block/oil separator (used to be the corrugated hose that went to vc from block) and attaches to the CC. I've then T'd the hose from the VC into this main hose running to the CC.
    Basically, with all the crankcase pressure headed to one spot and then vented to atmosphere its setup like the old style chevy motors.
  25. #65
    Jul 19 2011
    Basically, with all the crankcase pressure headed to one spot and then vented to atmosphere its setup like every old style motor.
    You are going to lose the benefit of your catch can this way. You might want to plug that hole you put in the catch can and then put the filter coming off the exit port of it, that way it still catches as much as it can. If not, no big deal. It will still catch a lot because of gravity and the air filter breaking up the oil vapor.
  26. #66
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    So please correct me if I'm wrong, with respects to the rear PCV, you can:
    1 -block off.
    2 - install catch can
    3 - remove check valve.
    What are the +/-'s of each (obviously shane covered the catch can). Thanks.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
  27. #67
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    This looks perfect, I am going to do exactly the same.
    - Eric
    Epy
  28. #68
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    The large, over-molded end of this hose fits the oil separator perfectly. It then necks down to a useable size. Autozone keeps them in stock. Dayco part# 86079. This is what I cut to use for the main hose to the CC.
  29. #69
    Jul 17 2012
    Bowie/Maryland
    Quote Originally Posted by LoKisSpYdR View Post
    1 -block off.
    Blocking it off prevents air flow to or from the air track going into the turbo. This I turn prevents oil filled air fromthe crank case
    On the neg it prevents pressure from escaping through that exit
    Catch can catches oil, but not all oil is removed. Most catch can set ups block off the intake manifold to allow recycle of air without the need for check valves or pcv valves. On the neg the stock pcv allows some air to bypass the turbo under low vacuum. This functionality is lost.
    Removing the check valve only makes sense if you are blocking it off or if you are running a hose to feed the intake manifold with a check valve and pcv further up. In other words the check valve would be removed only in certain situations.
    Ideal would be: no oil in intake, and some way to remove oil from air being vented from the crank case, and some way to send air around the turbo into the intake manifold that is metered and controlled, and to never have boost leaks
  30. #70
    Feb 18 2011
    the turbo intake and charged air outlet are not in the correct places.
  31. #71
    Jul 19 2011
    I might need this. This fits the same clipping as the OEM oil separator?
  32. #72
    Oct 14 2009
    Okinawa Japan
    Well I don't see you needing to modify your oil separator hose if you have the stock VC...
    Brad and I are working on a complete Rear Pcv Delete kit that will be put on my site most likely, I don't know all the details, but knowing Brad it will be top notch and a great deal...
    I just want to see how much interest there is out there for such a kit, as it will include the Plate, and a few twists Nd surprises for a really professional look in your bay.
    On top of that, you can pair it with Any catch can, no modification of you catch can, or any of the existing front PCV will be required. So as long as you have our Rear PCV Delete Kit, and a Catch can setup, you will have effectively eliminated 99% of the oil escaping into the Intake tract.
    Don't quote me 100% as We are still ironing out the details.
    I'm glad he talked to me about this as I think last year I mentioned to Corey about selling the block off plates, just never figured anyone cared or realized that a catch can was only 50% of the solution.
    -Shane Drake-
    >DRAKLOREs Build<
  33. #73
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    A PCV delete kit that vents to atmosphere is a great product idea.
    - Eric
    Epy
  34. #74
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Shane - you need to come up with an emblem for your company.
    Epy
  35. #75
    Oct 14 2009
    Okinawa Japan
    Dude the fact I have a website and that Taylor Cope (one of my BAT B5S4 customers) was awesome enough to make a logo thing for me is crazy haha
    I can't believe my site still works, and honestly it's been tough as hell to get a reach out there, not enough people spreading the word.
    -Shane Drake-
    >DRAKLOREs Build<
  36. #76
    Jul 19 2011
    I made this thread not knowing how people would react because a year ago when I first joined this forum and I mentioned I wanted to vent to air and asked if anyone had done it, AZ came down on me telling me I was dumb, and that's terrible for the environment. I am glad that people are using this and not wasting money thinking a catch can will solve everything. I mean they could, but you would need two of them (one for front, one for rear).
    Get moving on the delete kit and let me know if you need any help. I can model and even write software that you plug into a CNC mill, you throw in the tool, home it, and it will do the rest.
    My suggestion would be to make it similar to a mirror block off plate for a motorcycle.
  37. #77
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    I looked at it at the parts store, knew the molded rubber end would be perfect and hoped the clipped end might fit, it doesn't. So I cut the clipped end off and cut the hose to the length I needed after attaching it to the separator.
    Takes years to build a small business. Don't get ahead of yourself. It will work if you stick to a plan.
    I made this thread not knowing how people would react because a year ago when I first joined this forum and I mentioned I wanted to vent to air and asked if anyone had done it...
    I've had my CC vent to atmosphere for 3yrs. If you don't have inspections it doesn't matter.
    Block off kit is in the works. I drew everything up in Solid Works yesterday. Test plates are being water jetted next week.
  38. #78
    Aug 29 2012
    United States
    I'm interested in that PCV delete kit
  39. #79
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Brad, make them the same blue as your Rifle I like so much.
    Eric
    Epy
  40. #80
    Jul 19 2011
    Nice! Take a Snip of it on solid works so we can see it!
