Results 1 to 6 of 6
    Established Member Two Rings kiznarsh's Avatar
    Apr 10 2012
    City of Angels
    Need opinions on wheel/tire damage
    Yesterday I was behind an SUV about to turn right when the guy suddenly stopped and made me turn sooner than I wanted, and I ended up hitting the rear right on the curb, as seen below.
    I plan on getting the wheel repaired by Wheel America as I've heard good things about them and I can't imagine the cost being higher than $100.
    But what do you guys think about the tire? For now I plan on keeping an eye one it. There's definitely sidewall damage but it's just the very outer strip. There was a piece that was dangling and I cut it off, it was bout 1/8" thick.
    The only silver lining is that it happened to the wheel that was already repaired once by the PO, the powdercoating on it isn't the same as the others so it was already my least favorite wheel.
    The tire is Hankook V12 Evo (19").
    Thanks.
    Nov 28 2012
    2011 BMW 335i, 2006 Jeep Wrangler, 2003 HD Dyna Defender
    Germany
    if it was me, I'd fix the wheel and keep the tire. Based on where the tire damage is, I don't think it will have issues maintaining a seal.
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    Tire seems fine. What wheels are those?
    The tire is fine. That part of the tire is made thicker specifically for cases like yours.
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Apr 10 2012
    City of Angels
    Quote Originally Posted by pDubs View Post
    The PO put them on and they're iForged wheels, but not sure which model. Here's a better shot:
    Quote Originally Posted by Tireguy View Post
    Yeah that was my thinking too, this stuff happens all the time. I'll just have the wheel fixed as that'll bug me less than the tire. When I get back home, it'll be 3 weeks that it's been sitting there and a good check to see if the seal has been compromised, but I doubt it.
    Apr 10 2012
    City of Angels
    Just wanted to close this out...
    I dropped off the wheel at Wheels America last Wednesday and picked it up on Friday. It's usually a 24-hr turn around but since it's a 3-piece wheel, they needed an extra day to let the silicone between the pieces cure before mounting and balance the tire.
    Overall I'm very satisfied with the result (total cost was about $130).
    Of course now the "problem" is that it doesn't match the others since it's so shiny!
