Results 1 to 21 of 21
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Air Bag code 01221 Crash Sensor Driver side
    I searched the forum and can not find an answer to this air bag code. Several people have had it but in reviewing the threads no one actually said how to fix it.
    01221 - Crash Sensor Side air bag Driver side.
    011 Open circuit intermittent
    Last year i replaced the faulty clip that is under the seat on the driver side. The wires are still tightly held together with wire nuts, so i do not think that is the problem again.
    Also the code is different.
    Dec 05 2008
    bump
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The G179 airbag crash sensor isn't the one that you corrected earlier. The G179 is for the front side airbag. If your car was built prior to 10/2004 it will be located in the bottom of the B pillar and you will have to remove the lower B pillar trim to get to it. If the car was produced after 10/2004 the sensor is located in the center of the drivers door and you will need to remove the door panel to get to it. I believe the reason it was moved from the lower B pillar location was because that location was prone to water damage.
    Edit: Duhhhh.....I guess if I read your sig I would have know that yours was an '03 ;-) Your problem may be a corroded connection or a wet sensor since yours in located in the lower B pillar. Martini had the same issue with the G180 sensor which is located in the riders side B pillar. Clicky click
    Dec 05 2008
    Hey old guy,
    I was able to check on this today. The Foam around the sensor was completely dry, the sensor was dry. I didn't mess with the sensor to much trying to remove it so i could set it in front of a fan in case moisture was in it .
    Dec 28 2006
    Western Maryland
    Good luck with it!
    Dec 05 2008
    how can i clear this with vag com so that i can at least get the car inspected
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by 03 silverbullet View Post
    If there is an open circuit I don't think you can clear it without repairing the circuit.
    Maybe someone here knows a "work around"??
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    If these is an open circuit I don't think you can clear it without repairing the circuit.
    only two options are the audi spec sensor tester which you plug in place of the sensor, or you plug the connecter with a resistance, but i wouldnt be able to tell you how much resistance you need to avoid setting the code. I just use the audi tool.
    As for moisture I had the same issue happen to me on both the driver and passenger side sensors. The driver side was all corroded from moisture but passenger side was still looking good as new. I tried drying both up at the time but that never worked. Maybe you'll get lucky!
    I got both sensors off ebay for about 30$ a pop , which is much cheaper than what the dealer wanted for them!
    good luck!
    I'm just here for the free coffee
    Dec 28 2006
    Western Maryland
    I wouldn't recommend messing around with a resister unless you were really sure what you needed. Get it wrong and you could set off the air bag. That would truly suck.
    Dec 05 2008
    how does this sensor come out ? i cannot get my big head close enough to see whats holding it on the car. Is it to little alen head bolt or a regular bolt
    i will check ebay for the part
    Not gone to mess with the resistor
    Dec 28 2006
    Western Maryland
    It is attached with two Allen head bolts. There is a yellow tab on the sensor that you disengage and then just unplug the sensor.
    Dec 05 2008
    I checked the sensor to see if it was wet and did not get the part number off of it before putting all the trim back on.
    Does anyone have the part number ?
    Dec 05 2008
    Does anyone have the part number for this sensor ?
    Also can i use a B- pillar air bag sensor out of a car that has had the air bags go off ?
    Dec 28 2006
    Western Maryland
    I believe this is the one you need. Does it look like yours? Clicky click
    Dec 05 2008
    thanks Old Guy, Hope this fixes the problem.
    Things only seem to break when the state emissions inspection is due ...
    Dec 05 2008
    Hey Old guy,
    Bought a used sensor from wolfparts on ebay.
    All i had to do was plug it in and the light went off.
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    Hey silverbullet. Buying this part took your (g179) code and airbag light away for good? I did the wire clip harness delete under the seat and am still getting the code.
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Jun 07 2012
    Lansing Michigan
    Also where is this sensor located in the b pillar exactly? Thanks again in advance
    Jun 07 2012
    Lansing Michigan
    Where exactly in the lower part of the b pillar is it? I had that all ripped out not that long ago to change my ccm and don't remember seeing anything when I had the floor up to air dry? Maybe I just over looked it? I have an 2003 a4.
    Dec 28 2006
    Western Maryland
    Jun 07 2012
    Lansing Michigan
    Awesome diagram! Thanks a lot! I appreciate it! Once again, Old guy saves the day.
