Results 1 to 4 of 4
    Active Member Two Rings 02avant's Avatar
    Feb 05 2008
    pacifica, ca
    weird engine noise?
    hey guys, ive recently noticed a interesting noise when my car is at in 2nd at around 3000 rpm and same thing in 3rd.... its a sorta similar noise to a regular rev but slightly more high pitched . This noise doesnt always happen , but ive pin pointed it happening between the two gears mentioned earlier. My check engine light isnt on . I just replaced my cat last week and my car is running great besides this noise ( whatever it is) so i dont know what it could be. if you have any clue as to what please share. thank you
    Dec 05 2007
    Pinpointing where the noise is coming from is helpful. Could be a number of things.
    Apr 01 2011
    B5 on jack stands
    charlotte
    clutch fan maybe?
    Veteran Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    turbo spooling, now that your cat is un-clogged.
    98 Passat Var,2L,IE/JE,ARP,034,SPA,50tr,3tbe,FX400,BigREDs,Uni440,Fuel ab,Sterns,Mocal,Bils,JHM
    LINKS:2L Build,Further PerformanceHausOfHarnessD2 S8 40vQM
