Results 1 to 5 of 5
    Apr 20 2012
    newport nc
    Help!!!!!!!!!!!!!! need 2ndaryair injection system
    PLease let me know if anyone knows where I can get a complete secondary air injection system..the dealer wants almost $2000 for it and I really don't want to pay that much for it...can anyone out there help me?
    Apr 20 2012
    newport nc
    vehicle is a 2001 audi TT with 1.8L 225hp AMU motor
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    what exactly do u need ? the evap canister in the back ? ldp pump ?
    Dec 05 2007
    Secondary air injection only operates on sending extra air to the catalytic converter on cold start warm ups for like 30 seconds. That is it. You are confusing that with your evap system, or thinking they are part of the same system. They are not. The SAI only consists of the SAI bracket, SAI unit, SAI snorkel to air box, combination valve on the cylinder head, some vacuum line, rubber tubing to n112, hose, and n112 valve.
    xphactor, that $2,000 quote is a joke. With brand new parts that price is fair, but you can get it used for cheaper and replace it yourself. I personally sold my pump along with combination valve with adapter for $75. Also, you can just remove it out of your system and have it coded out of your ECU. A forum member on here named k0mpresd does it for a small fee (like $50). Another thing, how do you know the dealer is not just trying to get over on you?
    What DTC (diagnostic trouble code) do you have? This is what would be pulled when you scan your vehicle because you have a CEL (check engine light).
    Does your SAI pump make a noise, yet still function?
    What are the symptoms?
    Why did you bring it to the dealership in the first place?
    Jul 03 2010
    QUEENS, NY
    twas past my bedtime. my apologies. newbz
