Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 409
  1. #121
    Nov 17 2009
    Quote Originally Posted by 0000 V8 View Post
    I guess Im lucky im putting mine on the inside floor board, next to the fire supression system.
    ...because race car.
    nice, that makes life a bit easier for you. wonder if there is any room in the dash behind the glove box.
    996 TT
    MKIV Supra TT
    LX570
  2. #122
    Veteran Member Three Rings Tropicgreena4's Avatar
    Oct 07 2004
    South Central, PA
    I'd like to hear some other spots people are thinking of putting this... I'm not super familiar with all of the nooks and crannies of the b6 yet...
    -Wes
    2023 A6 Allroad
    2019 S5 Sportback
    2011 A4 Avant
    2016 Scuba allroad - Sold
    2004 Nogaro Avant 6MT - Sold
    98.5 Audi A4 2.8 - Tropic Green - Sold
  3. #123
    Active Member Two Rings s2carlo's Avatar
    Jun 07 2012
    Netherlands
    Quote Originally Posted by Tropicgreena4 View Post
    Discussed the idea today with my mechanic. He sees the advantages and sees it wo(of the top of his head) thinking about wheelarch... but was convinced a location can be found. HE suggeseted hook up at the oilpressure sensor located at the back of the engine near the oilfilterhousing.
    He also suggested a small electrally driven oilpump as a way to increase oilpressure before starting. This idea also apeels to me, need to look into that together with him.
    He had only one concern for both solutions. He sees the (increase) in rattle as warning sign for the chain being stretched. If streched to far the chain could break or jump a tooth.
    The accumulator or extra pump takes away this warning sign.....
    Well, I will be doing something, but will wait on your findings wrt hookup, mounting location and result
  4. #124
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    Quote Originally Posted by s2carlo View Post
    It has already been discovered that the chain does not stretch enough, or at all really, to effect the timing. No one needs to buy a new chain when doing this service either, so I dont think this is an issue as he speaks.
  5. #125
    Feb 19 2010
    Sacramento, CA
    I hope youre talking about doing this INSTEAD of the sump, because thats exactly what the sump it does. You wouldnt need both, and personally, id rather use the sump.
  6. #126
    Jun 07 2012
    Netherlands
    Yes, obviously, either or, not both.
    The pump solution might be smaller and maybe cheaper
    The accumulator is earier, hope it becomes clear where to put it.
    If desertflyer & ALi show where it is and that it works I think this is how I want to go.
    Btw if the chain does not stretch, what causes the rattle? Do the springs relax, loose strentgh??
    I agree, that before it would be able to jump the wheels it would have to stretch very far and also there needs to be enough space.
    Just ideas and while waiting for pictures and DIY instructions
  7. #127
    Feb 19 2010
    Sacramento, CA
    Its the tensioners and guides not not tensioning the chain (because of the low oil pressure on startup) that cause the chain to "slap" against them. Its THOSE two peices that fail most often.
    I my self am going for the Accusump RACE setup, as y car is a deticated track car.
  8. #128
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    for reference. you can see the cam chain tensioners nicely in this pic.
  9. #129
    Active Member Two Rings Latosa's Avatar
    Jul 17 2011
    1986 scirroco 16v,1982 rabbit 16v turbo 543whp sold,s4 2004 6mt
    Aguadilla,P.R.
    well since all the interested people doing this mod are here an keeping it live , I did tackle some stuff in my car got the fitting were I am
    hooking my system, And is thru the were the oil pressure sender is, drill and tap the fitting so keeping the sender in the same position made a short AN6 flex line so the valve can be attached seperate from the accusump less space for the accumulator is needed.I did fit the accumulator on top of the Intake but it doesn't look nice , I still think it should be fit under the car ,battery well is to small,engine bay it tight,fender well is were I,m cheking this when i get some time ,if not behind front bumper .going slow on mine since work takes alot of time off.i got some crappy cell pictures i will try to post.
  10. #130
    Jun 07 2012
    Netherlands
    Quote Originally Posted by Latosa View Post
    Pictures would be great!
    So, did the solution also work for you, or is it not active yet?
  11. #131
    Veteran Member Three Rings howsyouraspen's Avatar
    Dec 06 2007
    Holladay, UT
    ^ I think the OP is the only one who is got this system completely installed and running. There's gotta be room behind the bumper, in front of the radiator to mount this thing.
    But yeah someone needs to be postin up some pics.
    -Alex
    A6 Avant 3.0T GIAC Stg 1
    *S4 SOLD*
    Buy my Rial Daytona Race II's
  12. #132
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Pull the passenger aux radiator, use the oil lines that fed the oil cooler circuit in there to go into the reservoir, and thereafter route to an added oil cooler in front of the radiator.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
  13. #133
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    bump for pics
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
  14. #134
    Jul 17 2011
    Aguadilla,P.R.
    posted some pics on my gallery , installation location for the tank is not permanent until i test this for couple weeks it will be behind the front bumper made a braket for it ,fitting is a custom made since I'm attaching were the oil sender is .will post more some time this week with the valve and wiring .this for testing only ones proves to work it will look better
  15. #135
    Jul 17 2011
    Aguadilla,P.R.
    [IMG][/IMG] oil galley were accusump will feed thru.
  16. #136
    Jul 17 2011
    Aguadilla,P.R.
    [IMG][/IMG]fitting were valve is tapped
    [IMG][/IMG]were accusump will be located temporary hood closes with no problem
    [IMG][/IMG]oil sender with out adapter fitting using AN 6 for valve conection
  17. #137
    Dec 06 2007
    Holladay, UT
    ^ Damn, is that the 2 QT. unit? That looks big when next to the engine. Behind the front bumper might be the best locaysh. So is that T fitting pieced together or a custom part?
    -Alex
    *S4 SOLD*
  18. #138
    Jun 07 2012
    Netherlands
    very important question. Does it work? No more rattle?
    I understand you moved the valve from the sump to the oilsensorfitting for space purposes, but it also looks very tight there!!
    How big is the sump you used? ISit 2 or 3 qt??
    Has a T-piece been fitted to put the sensor and oilsump on the block together??
    More pictures, also of parts would be great!
  19. #139
    Nov 17 2009
    That looks the same as 1qt one I have sitting in my garage waiting on an install also.
    I was thinking of going into the system after the oil cooler maybe at the fitting but would love more detial on yours and maybe the OP if he is still chekcing.
    996 TT
    MKIV Supra TT
    LX570
  20. #140
    Jul 17 2011
    Aguadilla,P.R.
    my unit is 1 qt ,the fitting is a custom made 45 angle AN6 to 1/2 npt out of stailess steel I drill and tap the side to 1/8 npt so the oil sender can be in the same location,the loction on top engine is temporary until it gets tested ,i have done a couple starts hot wiring it and yes no more rattle i,m working on the wiring hook up to the car .
  21. #141
    Veteran Member Three Rings Porschephd's Avatar
    Jul 11 2012
    2010 V10 R8; 1994 911 3.6 Turbo
    Lenexa, KS
    Is the group buy still going on? If so I am in for one.
  22. #142
    Nov 17 2009
    Quote Originally Posted by Porschephd View Post
    No group buy ever happened but the guy I ordered mine from made a note so if people refernce it he will keep track of the orders and if breakpoints are hit he will refund the difference to each. This is what he said but that was 6 weeks ago so whoe knows but if you want their info PM me and I can shoot it to you. Their price even without the discount was the most reasonable I found. He got everything (accumulator, electric valve, mounting brackets and universal install kit) to me shipped for about $380.
    996 TT
    MKIV Supra TT
    LX570
  23. #143
    Jul 11 2012
    Lenexa, KS
    PM sent!
  24. #144
    Nov 17 2009
    Hey guys, going to take a first stab at this tomorrow and was hoping someone may have or can point me to a schematic that shows the oil system on these engines. I plan on just following lines etc to poke around but would be nice if I had a map rather than flying blind. I have searched online but have not found anything very usefull.
    Thanks in advnace.
    996 TT
    MKIV Supra TT
    LX570
  25. #145
    Nov 17 2009
    After spending a few hours under and around the car taking of fender liners etc. the accumulator will not really fit anywhere except in the front bumper between the lower grill and radiator or on top as Latosa has done. Also as he did there does not seem to be anywhere to really easily access the oil system except the pressure sensor under the filter housing. It very tight and I dread having to try to get in there but there seems no alternative. I need to modify my T fitting or find or order a Y fitting to access the galley as he did.
    Latosa, just to double check the tread size of the hole in the block is 1/2" npt and for the sesor you drilled and tapped a 1/8 npt and used an apadter to M10 which is what I believe the sensor is?
    My kit came with a T that has 1/2" npt on one end and the other two end are both AN10, one which will go to the accusump, no issue there and then I will need a converter from the AN10 to M10 for the sensor. Does this sound about right?
    996 TT
    MKIV Supra TT
    LX570
  26. #146
    Jul 17 2011
    Aguadilla,P.R.
    No, the hole on the block is not a 1/2 inch I use that fitting but it is a custom fitting I made and is tig welded . as for the location tomorrow I,m removing the front bumper the see were i can custom place this thing since i took some measurement again and is very close to the hood about a 1 inch .and i don't ruin my hood .if you want you can pm your cell I can go with you thru this .
  27. #147
    Nov 17 2009
    Hey Latosa,
    Thanks for the conversation yesterday, cleared up a lot. I found a local shop that makes large M to NPT adapters. Did you by chance happen to take it back apart and see what the size of that fitting was or if anyone else knows the size of the opeing in the block where the adapter plate which the oil pressuer sender plugs into please chine in.
    This is the opening in question, under the oil filter housing:
    Thanks.
    996 TT
    MKIV Supra TT
    LX570
  28. #148
    Nov 28 2006
    bump
  29. #149
    Nov 17 2009
    My efforts have been back burnered at the moment as still trying to figure out what size hole that is in the back of the block without taking it all apart first. Talked to the local dealers parts and tech as I fiugred I would just buy a new one and use it as a guide but they seem to have no clue what I was talking about. They dont show any adapter and the parts person said it must come as part of the block. I remember when dealers actually used to try and help people, not so the case nowadays.
    996 TT
    MKIV Supra TT
    LX570
  30. #150
    Deactivated Two Rings
    Nov 27 2011
    2004 S4
    Italy/US
    Quote Originally Posted by Ali View Post
    I am not surprised. Good job looking up that info. I'm not skilled enough to help at this point but I am definitely looking into doing this when all is said and done.
    Also, I am in Italy and should be making a few trips to Germany while I am here. If it's an availability issue for any parts let me know and I'll see what I can do.
    Sent from my LG-P970 using Tapatalk 2
  31. #151
    Established Member Two Rings Silversrfa18T's Avatar
    Jan 31 2012
    Pluto
    I've had my 05 b6 s4 since march 2012 and this thing has had chain rattle since i bought it. Hate it but according to audi it's normal.
    Ps until your guides break.
  32. #152
    Jul 17 2011
    Aguadilla,P.R.
    So to bring this one back from the dead ,I have been running my accusump now for at least a month now and no more CHAIN RATTLE ON STARTS ,at the end I think is better for our V8 engines overall.
  33. #153
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Nice job son.
  34. #154
    Established Member Two Rings buck15's Avatar
    Aug 01 2011
    Twin Cities
    This is music to my ears! Will you be writing up DIY soon? Myself and sure others would really appreciate a write-up on how you installed and parts list required. Thanks for tackling this and testing you did, really appreciate it!!
  35. #155
    Nov 27 2011
    2004 S4
    Italy/US
    A DIY would be most appreciated.
    Sent from my GT-I9001 using Tapatalk 2
  36. #156
    Jun 07 2012
    Netherlands
    Hi,
    Some indication wrt the hookup to the block would be great, threat dimension and location of the sensor. (is it below oilfilter)
    I know the accusump has 1/2"NPT threat. I need to know what the other end of the oilline needs to be in order to have a line made that directly fits to both ends without extra adapter(s)
    Where did you put the accumulator in the end?
    I am thinking about boot, takes a longer line but no drilling needed.
    Thanks for info
  37. #157
    Jul 17 2011
    Aguadilla,P.R.
    [IMG][/IMG][IMG][/IMG] so at the end I relocted the accusump behind the lower grill ,did some mods to the ps oil cooler to make more space I put an after market one .ran lineto the fitting behind the engine were the oil sender is ,remember this fitting Is a custom made fitting an is tig welded but i,m running a # 6AN line I made all the bracket for holding unit ,fittings ,as for the wiring is simple ground and the other lead to a relay activated when the ignition is on ,building up 50psi while running and on start up got 50 psi to prime all chain tensioners and waallaaaa! no more rattle
    sorry for ther crappy pic but I did tackle this in 2 days did not have more time for more pics since is daily driver .
  38. #158
    Jul 17 2011
    Aguadilla,P.R.
    [IMG][/IMG]
  39. #159
    Dec 06 2007
    Holladay, UT
    Dude, nice work. It looks good. But sounds like a lot of little mods to get it to work.
    -Alex
    *S4 SOLD*
  40. #160
    Jun 07 2012
    Netherlands
    got my kit today. Got an extra sensor with adapter to be able to get the correct couplings without disassembling the sensor from the car. Going to get hose and couplings tomorrow. Try and fit it (in the trunk) asap.
    Will make picture and diy while working.
