Results 1 to 40 of 56
    Active Member Two Rings BoostNeggs's Avatar
    Aug 10 2015
    Co
    Twin Turbo LSX b6 s4
    almost done with my build, so i figured id post the link to my build thread on ls1tech.
    4.8 lsx (lr4)
    twin hx40s
    http://ls1tech.com/forums/forced-induction/1582523-audi-s4-getting-american-blood-some-pics-4.html
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    you have my full attention
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Aug 10 2015
    Co
    yea.... im not playing around ;) no hypothetical builds here
    Established Member Two Rings brianup's Avatar
    Sep 04 2008
    B6 S4 6MT
    Millbury, MA
    The link you shared is bad. I'd like to see what we're looking at here :)
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    I approve of this!
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    What hotsides did you run with?
    Aug 10 2015
    Co
    ~18cm t3 internal wg's
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    #Lsswapallthethings
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Cool idea, but how are you to be able to get a bumper support and cover around it?
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Aug 10 2015
    Co
    the intercooler will stick out/forward of the bumper a tad
    Aug 10 2015
    Co
    i figured 700+whp was worth a few chops in the front bumper & hood
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by BoostNeggs View Post
    Should be a good time then. Port those wastegates tho
    Sep 04 2008
    B6 S4 6MT
    Millbury, MA
    This is sweet! How does the new engine impact weight distribution? These are nose heavy cars with the 4.2. More pics man. That thing is a beast!
    Aug 10 2015
    Co
    the weight distribution isnt too far off of stock imo. the iron longblock 4.8 is around the same weight as the 4.2, but the th400 is much lighter than the 6spd tip. i figure its around the same weight. not 100% on that yet tho
    '04 B6 S4 Dolphin Grey: twin turbo LSX swap
    4.8 lr4, twin hx40's, th400, e85, a/c, cruise.
    '06 G35 sport coupe
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Awesome!
    Oct 02 2005
    The Moon
    Awesomeness. Anyway to move the engine back for a clean install or just not possible?
    Aug 10 2015
    Co
    nah, steering rack hits the back of the heads if its moved 2" back
    '06 G35 sport coupe
    Jun 04 2015
    Southeastern MA
    Subscribed to this thread on LS1 Tech. Awesome! I am planning the same idea but using an LS4 as it is slightly smaller and mating it to the audi trans to keep AWD. No turbos for me though. At first Why did you end up keeping the audi ECU??
    Aug 10 2015
    Co
    i didnt keep the audi ecu. its a gone-r. its actually the ecu out of my wife's 01 silverado (shhhhh!!).
    The ls4 is a great option. the block itself is geometrically the same as the other lsx' but it has the 'corporate' fwd bellhousing bolt pattern. iirc, the crankshaft's snout is 10mm shorter and the flywheel mating surface is like 5 or 8mm shorter than a traditional ls. The ls4 accessories are much shorter as well. If you use the ls4, you shouldnt have an issue keeping the front end & hood intact
    '06 G35 sport coupe
    Jun 04 2015
    Southeastern MA
    Sorry totally misread your thread on ls1tech about the ecu. I would be interested in having a chat with you about all the wiring to make everything work, as I am trying to lay most of that out before I take anything apart. In my research that is exactly what I found also about block/engine wise. I ended up with an entire Impala SS when the tranny blew.
    Veteran Member Three Rings dolphin B6 S4's Avatar
    Dec 05 2011
    Powerstrokes, LS' and VAG
    Chicago surburbs
    This is awesome, I took the easy route a few months ago. I can't wait to see it in action!
    2013 White Diamond 6M CTS-V Sedan - Would be easier to name the stock parts left
    1993 Emerald Green URS4
    1992 Tornado Red Corrado SLC
    -SOLD- 2004 Dolphin Grey S4 - Stern motor mounts | JHM IM spacers w/K&N | FI Non Res CB | Trexturk Downpipes | JHM 93 Tune | Apikol Snub | RS4 Pedals |
    Aug 10 2015
    Co
    ha! yes. I was wanting a ctsv.... so a built an Audi Ctsv-tt ;)
    '06 G35 sport coupe
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    please keep us updated over here, not all of us cruise ls1 tech anymore :)
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    Beyond the bumper a tad? It looks like to be about a foot past the headlights lol. What front end will you use?
    Veteran Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    god damn thats insane looking, was thinking the same thing about the front end. Other then that this is absolutely amazing.
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front & Cupra lip, S4 rear bumper, 18" BBS CH, OBX exhaust, PSI concepts test pipe, Genesis 380cc injectors, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, B6 S4 BBK, etc...
    Aug 10 2015
    Co
    id upload pics here, but the pics are too large. im using the stock s4 front
    '06 G35 sport coupe
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Try using Photobucket or imgur and then just embedding the link for the pictures
    Perused the whole thread. Really awesome build! Glad to see someone taking on a challenging technical swap like this
    Nov 12 2012
    hologram R8
    boston
    Quote Originally Posted by pwest15 View Post
    Agreed. This is how our audis get traction for swap kits like everyone else so we can Lego all the engines!
    Aug 10 2015
    Co
    '06 G35 sport coupe
    Aug 09 2012
    Bay Area
    Quote Originally Posted by jakeoboy67 View Post
    #Lsswapallthethings
    I approve this message.
    Lets try to LS a hamster!!!
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Omg this is insane! Although I do want to see the fitment of the bumper
    Sent from my SM-G920V using Audizine mobile app
    Jan 25 2012
    Fort Collins, CO
    Where in CO are you? Congrats on getting it running.
    Aug 10 2015
    Co
    western co
    '06 G35 sport coupe
    Oct 02 2005
    The Moon
    That thing sounds nasty!
    From the video the engine sticks out much further than the stock Motor. What are your plans for a front end?
    Aug 10 2015
    Co
    will have to wait and see ;) should have the bumper on hopefully this week or next
    '06 G35 sport coupe
    Oct 02 2005
    The Moon
    Sounds good. If youre ever in the Springs let me know. I'd love to see it.
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Cool to see one running in these but no way the bumper is fitting over all of that haha
    Aug 10 2015
    Co
    as stated before, the intercooler will stick past the bumper...
    '06 G35 sport coupe
    Jan 11 2009
    CANADA
    Can't wait to see the finished product!
