Hi all, I'm new to Audizine, but have been following this thread with interest for a while.
I have a '04 4.2L Allroad (BAS engine) with the startup rattle, which to me sounds like it is coming from both the chains and one of the cam adjusters. It's been there for a while, and after doing a bunch of reading on the problem, I only recently started to get concerned. The engine in my car is virtually identical to the setup in the BBK engine, which is what is in the S4.
I did a mod to the car recently that seems to have made a difference. Some may be interested. While I don't think it is as good as the oil accumulator solution, it's a lot cheaper, and will take you about an hour to do.
Before doing any reading on the problem, I did a bit of testing. I removed the fuel pump fuse and cranked over the engine for about 10 seconds, replaced the fuse, and then cranked the engine over. Started perfectly. No noise and sounded like a brand new engine.
I live in Australia (right hand drive cars), so the fuse panel and driver are on the same side. I'm not sure if this is the case for left hand drive cars. If it is on the opposite side, this mod is going to be a little more involved.
I removed the panel below the steering wheel, removed the fuse panel, and identified the wires going to each side of the fuel pump fuse (visually and from the wiring diagram). One is yellow (goes from the fuse to the pump), and the other is red/green (from the fuel pump relay to the fuse). Basically I just cut into one of these wires and put a simple switch in here. It doesn't matter which wire you cut into, I cut into the red/green wire because it was the most convenient. I just added wiring length to each side, and then put the switch to the lower left of the steering column.
When starting the car, now I just turn the switch off, so the fuel pump gets no power. I crank over the engine for about 8 secs then stop cranking. I then turn on my installed switch, which allows the fuel pump to work, and then crank the engine. Starts with no rattle at all.
Is this the perfect solution. No. What are the problems?
1. This solution requires there to be no residual fuel pressure in the fuel rail. After being left overnight, this is going to be the case. However if the car has recently been driven, there will be some residual pressure, and the engine will want to start even with the fuel pump switch off. Depending on the severity of your rattle, this may be no problem, as you may only get it when you do a start up first thing in the morning.
2. I'm sure this is putting more wear on the starter, and may lead to premature failure. That being said, I'm prepared to deal with this over the possible alternative.
3. You can't start the car as quickly.
Advantages:
1. Rattle gone.
2. Even without the rattle, when the car started first thing in the morning, it had a real raw sound about it. As an enthusiast, this always made me cringe a bit. After doing this mod, this no longer happens either. Priming the engine with oil prior to start is clearly a good thing to do.
Personally I think the oil pre-charge accumulator is a great idea, and I plan to do this in the future. Fitting it is clearly an issue. I spoke to Paul at Gruven parts that makes the aluminium oil filter housing cover that would fit the engine (I saw a picture earlier in the thread). I wanted to know what thickness it was at the top of it to see if a thread could be put in here. He replied that it was more than 1/2 inch, and they would tap the hole for me for a small cost. To me this sounds like a great solution.
A bit of background info on the tensioners in the engine. Not having seen one before, I chased down an Audi "master technician" as they are called, and got into his head about it. They are very different to what I imagined. I've stripped to individual parts and rebuilt an engine the same as what is in my other car, a BMW. The tensioners in the BMW have a spring that applies pressure until oil pressure is built up. A simple solution that works very well. The Audi setup is apparently very different. Instead of a spring, there is a ratchet mechanism. When the engine is going, the oil applies pressure to the tensioner. When the car is shutoff, this ratchet mechanism holds the tensioner in place until the next start. The problem is this ratchet fails, and when the engine stops, it allows the chain to go loose, rather than hold the tension. Interestingly, its the guides that fail eventually, causing major engine damage, but its the tensioners that create the slack chain, that then slaps against the guide and eventually makes it break.
I know there are people on the thread who don't believe this is the cause, but personally, guides are made nylon in loads of engines, and few have problems like this. A tensioner that doesn't tension and allows a chain to slap against a guide in my opinion will break a guide earlier than one that doesn't have the chain slapping against it, even if it is just for a short time on startup. Stopping the chain slapping is I think the best thing you can do to stop the guide breaking.
