Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 409
  1. #201
    Apr 15 2012
    Chambly, QC
    s2carlo,
    The aluminum part you see IS a piston. I have opened my sump and the only part inside is that piston. Before opening I have been able to push it with my finger after purging all air pressure.
    If you are interested I can post pictures of the unit dismantled.
  2. #202
    Jul 25 2012
    New Zealand
    For gods sake can someone explain to a noob if this is works and if I was to get a shop to do it how much they would charge? Is it a major to install??
  3. #203
    Active Member Two Rings s2carlo's Avatar
    Jun 07 2012
    Netherlands
    Quote Originally Posted by CoolHeadS4 View Post
    s2carlo,
    Very interested, as that was my expectation.
    I tried to push it back aswell (with the airvalve open) in order to prefill it but no luck.
    I put this in to the supplier as I was afraid my unit was not working OK. They tried with a unit which they had in stock, same result as mine....
    That is why I suspectet something to be inbetween....
  4. #204
    Jun 07 2012
    Netherlands
    Works, for 4 forum member.
    Can be done yourself if your not afraid to get your hands dirty and have some tooling available.
    Needs some preperation but can be done i 1 or maybe two days, pending on preperations
    Costs, (for me) approx 700 euro's including materials & labour.
    I will make a DIY during, or just after the wekend
  5. #205
    Mar 18 2011
    Chicago SW Suburbs
    Wrong. There's a piston inside separating the air from the liquid.
    Anybody have an idea on expected flow then? Just trying to work out what an acceptable line size and length would be...
    2013 S6 Estoril, Innovation, LED, Carbon, Roc-Euro, EPL Stg 1
  6. #206
    Jun 07 2012
    Netherlands
    I have 5m hose with o12mm with some curves & corners, the sump was @20psi. This seems to work.
    I will monitor starting now.
  7. #207
    Jun 07 2012
    Netherlands
    Sad news.
    An oilleak occured @ the fitting in the block.
    A new, better, easier, standard hydraulics fitting was placed but the leak was not gone.
    So I had to take the fittings out, uncouple the accusump and put the original sensor configuration back in
    I will have the fittings fitted by the hydraulics guys (who also do carmaintenance) as the sump was working fine.
    It just again takes time.......
  8. #208
    Active Member Two Rings Latosa's Avatar
    Jul 17 2011
    1986 scirroco 16v,1982 rabbit 16v turbo 543whp sold,s4 2004 6mt
    Aguadilla,P.R.
    Quote Originally Posted by s2carlo View Post
    Sad news.
    threads on the block is not the problem and the fitting ,like I mentioned before the factory plug seals because the bronze washer on it when a straight fitting is put on the block the only way to seal is to put teflon or go with a N.P.T fitting wich I don't recomend doing that since the N.P.T . fitting tapered and you can crack the threads on the block if not put with caution but it can be done .Thats why when I did mine I welded the fitting to the plug and still uses the bronze crush washer to seal that area .s2carlo let me know if it was clear what I'm trying to say.My grammar isn't good.lol By the way guys update my sump running strong no rattle at all!!!!!!since day one that it was put on service.
  9. #209
    Established Member Two Rings siren's Avatar
    Sep 18 2012
    Quote Originally Posted by Silversrfa18T View Post
    I've had my 05 b6 s4 since march 2012 and this thing has had chain rattle since i bought it. Hate it but according to audi it's normal.
    Ps until your guides break.
    Im in the same boat as you.... i just recently bought a 2005 b6... and the chain rattles every first cold morning start up. But after that... i can turn on the car throughout the entire day and night Without any noise... i spoke with a mechanic who works on audi's.... and to my surprise... he said not to worry about it, as his own personal audi does the same.
    But that doesn't sound like an acceptable answer.... if i dont get this extra oil pump, am i gonna be royally screwed with this slight chain rattle at start up?
  10. #210
    Apr 15 2012
    Chambly, QC
    Anyone knows how high the oil pressure can reach in our engine? I have a 3 quarts accusump that we have cutted to make it 1 quart (One of my client use those 3 quarts on is aircraft refueller and he gave me one). I want to test it at 1.5 the maximum oil pressure to be sure the threads we cutted at the end are up to the task.
    2005 S4 cabriolet, sprint blue, TIP, 4 cat gutted on OEM dp's.
  11. #211
    Veteran Member Four Rings ilko's Avatar
    Oct 20 2007
    997TT, 993, W211 E55 AMG Wagon
    Upstate Manhattan
    Don't know about this engine but my air-cooled 911 has a an oil pressure gauge that shows 2-3bar at idle and 4.5-5bar when on throttle. Hope this helps.
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Previous: 993 Carrera 4S / 964 RS America / 964 Carrera 4 / 944 Turbo / MK4 Golf R32 / C5 allroad / B6 USP Avant
  12. #212
    Apr 15 2012
    Chambly, QC
    here's the promised pictures. It took me long because the sump was at the machine shop being cut to make it a 1 quart from a 3 quarts.
    On that picture you see it opened. The piston is the only part inside.
    [IMG][/IMG]
    On this one it's all assembled
    [IMG][/IMG]
  13. #213
    Jun 07 2012
    Netherlands
    interesting. Where are you going to put it??
    I am waiting to find time for a new hookup, after the first tries being unsuccesfull (oilleakage)
    Anyone else did something?
  14. #214
    Veteran Member Three Rings Brettannica's Avatar
    Oct 14 2012
    2010 Audi A4 Avant
    Perth, Western Australia
    My S4 has done 78,000kms has had oil changes roughly every 8-10,000kms. Previous owner owned 4 gas stations and a mechanical workshop and ONLY used M1 0w40. Although low miles (or kms) this car does not make a peep of noise. I think I'm kinda lucky!
    That said, I will be watching this thread.... Prevention is better than cure
  15. #215
    Apr 15 2012
    Chambly, QC
    Winter project. I will have plenty of time figuring that out once the car is stored for winter.
    I was thinking installing the sump in the battery compartment after moving the battery to the trunk.
  16. #216
    Oct 22 2012
    2000 Jeep Grand Cherokee Limited
    Turlock CA
    Hello everyone. I've been keeping up with this thread since I purchased a 2004 S4 about 8 weeks ago. It has cold start chain rattle that 2 seperate dealerships told me not to worry about too much. The car is going to JHM on Friday to have several items upgraded. While on the phone I asked the tech for a quote to install the Accusump unit and was basically told not to even bother with it. He said they've seen it tried on several S4s with virtually no benifits. I was basically told that I should just bite the bullet and schedule it for a timiming chain service (actually was told to bring it so they could hear it but it was implied that a service was the only way to go). I didn't feel like arguing with the guy who obviously knows more about my car than I do based only on info I've obtained from online strangers, but I still asked him for an install quote. Has anyone installed this system on a car that also has a slight warm start rattle? Just curious as to how bad the rattle can be and still have the Accusump be benificial.
  17. #217
    Jul 17 2011
    Aguadilla,P.R.
    Well from my experience the accusump is good to your engine in diffrent ways 1. prime your system prevent dry start on all your mayor components 2.prime all oil related pressure sensing componets (example) cam tensioners ,timming tesioners ,oil pumps ect.3.compensate oil pressure loads durings hard accelerations and high revolutions 4.keep oil system to its demands were pressure is need it at all time even with engine off.The theory of accusump comes from the word accumulator and is been around since WWII it was used in aircraft in any system that I know starting with engine ,hydraulic,pneumatics and still up to date all modern a/c have accumulators with the same principle as the accusump system.For example my car 2004 s4 has 38000 when I got it ,I did put the accusump as soon I started reading about the rattle and getting it in my car since the system was put on service no more rattle at ALL !!!!!!!does this saves me from the chain and timming componets time will tell .Also I have been using accusump not only in this car also all other cars I have own like drag,roadracing and motorcycles all with same effect in reliability.So is your call if you bite the bullet !!!!!! on this.
  18. #218
    Active Member One Ring JoeD.'s Avatar
    Dec 23 2011
    2000 Porsche Boxster S
    Round Lake, NY
    Re: The solution to chain rattle
    I think this is a fix for chain slap not for the chain guides. Anytime you have metal on plastic you will have wear. This solution only prolongs the inevitable you will have to pull that engine at some point.
    I do still like the idea of prelubing anything before start up.
    That's what she said!
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
  19. #219
    Jul 17 2011
    Aguadilla,P.R.
    Correct you will still need to address this down the road with high mileage but the fact your charging the tensioners you are preventing the guide been hit by the chain and breaking it or cracking it will prevent a failure at start up wich is the rattle.
  20. #220
    Dec 26 2008
    STL
    I've been reading this thread from the beginning and i was wondering has anyone mounted this vertically? I mean there is a some space next to battery and in front of the car to just mount it like an overflow tank bottle..
    Wish the OP would chime in and provide some feedback, as it's been a long time since he's had it..
  21. #221
    Jun 07 2012
    Netherlands
    finally got around to hooking the accusump up to the block (again)
    Using the new fittings & sealrings it now seems oiltight and the sump seems to work, no more rattle..
    First few days succesfull.
    Keep you posted!
  22. #222
    Oct 20 2007
    Upstate Manhattan
    Awesome! Can't wait to see the full install procedure.
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
  23. #223
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    I made my own accusump system with various parts i conjured up . It eliminates my start-up rattle completely. It's temporary until I can tackle the timing rebuild.
  24. #224
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    Quote Originally Posted by Dirtracer603 View Post
    Why wouldn't you leave it in place to help guard against future problems?
    Current:
    2018 RS3 Florett Silver
    Previous:
    2005 S4, 99.5 A4 2.8 w/PES G2
  25. #225
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    So I think someone mentioned this earlier, but I didn't see anyone reply. Seems like when you first turn the ignition on (if that triggers the oil release switch) you would end up with too much oil in your engine. For example with the 3 quart version, your dumping 3 quarts of oil into what is hopefully an engine that is topped off with oil. Once the engine starts, and the oil pressure goes up, this 'extra oil' will be pumped back into the sump and your oil level would be back to normal. But there for a bit, between releasing the sump oil, and oil pressure coming up to normal, your engine is potentially over-filled. Any ramifications of this?
  26. #226
    Aug 15 2012
    Fredericksburg, Va
    Quote Originally Posted by IslandHydro View Post
    I have about a 1 quart system on a button switch so no worries with over filling. I press the button for 3-4 seconds prior to tuning the key and I hold it until the motor fires up. No chain slap. Whats cool is, the way the solenoid valve I used is designed (piston stop valve designed like a check valve) I don't have to hold the button in, in order to recharge the accumulator....it does it automatically. The only problem I have is I have to occasionally drain the oil from the accumulator tank because it loses a bit of air into the oil stream and it eventually fills up with oil-no air left to pressurize the tank. Even with being installed in a vertical position so that the hose feeds from the bottom so the air stays at the top.. The Accusump kit has a sliding sealed piston to separate the oil from the air for this very reason.
  27. #227
    Jun 07 2012
    Netherlands
    hi latosa,
    this is the procedure where you open the valve, put the airpressure to 60psi, back to 10psi and then put the unit back to normal operation??
    What pressures do you set it to?
  28. #228
    Aug 25 2012
    Columbus, Ohio
    I saw this information somewhere else in this thread, just wanted to add to it.
    I have been working part time at a Vw/Audi dealership and just recently picked up my B6. It's got 96k on it at the moment and yes, when the car is dead cold, the chains make that jingle/rattle for less than a second on startup.
    I brought the idea of pressurizing the tensioners to a couple of the other techs and the answer was a simple "why?". This issue of chain rattle would not fix the problem of the tensioner wear. In their opinion, this would just limit the sound. Wear would still take place.
    Again, I know this has already been mentioned. I just wanted to add to it.
    I am not saying you guys should avoid doing this because we could be wrong. I would like to see long term results
  29. #229
    Sep 13 2008
    Western Chicago Burbs
    Yeah as I said earlier on in the thread, the rattle is purely a sound affect. This may be the solution to chain rattle but it has nothing to do with the longevity of the guides and since half of the failures are related to the adjusters going bad, this isn't fixing any problems.
    Give it up. Service the chains at 80K or so.
  30. #230
    Aug 25 2012
    Columbus, Ohio
    Quote Originally Posted by B6JoeS4 View Post
    Haha I'm at 96k. I'll be putting off a chain service for as long as possible. Or at least until I can afford some headers and other go fast goodies
  31. #231
    Jun 07 2012
    Netherlands
    well, the sound is a symptom. The chain is slamming to something else because the tensioners don't work (as they should) whithout pressure. This causes wear to the chain, the tensioners and the guides.
    The pre pressurizing puts the tensioners in it's place, therefore no slapping chain and no noise.
    It makes sure the tensioners do their work (with a little help) and therefore the chain doesn't hit other parts that are not ment to be hit by a loose chain..
    SO I don't agree to the solution not helping.
    I feel it is a design issue and think it's very stupid that Audi doesn't step up and takes (part) of the cost.
    The chain was put in and ment to be OK for the life of the engine.....
  32. #232
    Sep 13 2008
    The guides will still wear down with our without the chain rattling on them. Heat cycling the nylon is a big part of what causes them to become brittle. And still, more than half the time, the guides aren't the issue. The adjusters are.
    Put the money into new timing gear and do everything once the right way and you will have another 80k years, maybe more because the newest revision are better than old 04-05 gear
  33. #233
    Aug 15 2012
    Fredericksburg, Va
    Every car is different. Some chew up guides, some don't. Some have adjusters that wear out, some don't. Some get chain slap to the point it cracks a guide, many don't. I have seen high mileage S4's that had the timing chain service done and the guides/adjusters had hardly any wear. My car had one of the rarest forms of a timing system related incident-the solenoid valve on the electronic controller went bad and stopped working. I would up replacing it myself with the motor in the car. With all that said many people have cars where the guides, adjusters and cam controllers are fine, they are just experiencing cold start rattle because the oil system does not stay primed. Just think: If you never shut your car off, you wouldn't have cold start rattle. I know that wont happen and it's quite the analogy but it puts things in perspective. I have my accumulator pressure system on my car to extend the life of my motor till I can figure out how I want to tackle my timing components because I damn sure don't have extra time or money laying around to just snap my fingers and make it right.
  34. #234
    Jan 28 2013
    North Branford/CT
    Hey guys,
    I work for Canton Racing Products. We are the manufacturer of the Accusump. I've tried to read through the thread to see if I could help in any way. I figure the best I can do is simply open it up to questions. I've had two separate guys guys contact us about this so I figured I would dig a little deeper. My first question to the guys that have done this is how they have plumbed the Accusump. Usually we use spin on filter adapters to run oil lines for our Accusumps. However, as a lot of other german cars the S4 uses a canister style filter as opposed to a regular spin on style filter. We have yet to design a canister style adapter to remedy this issue but are working on it.
  35. #235
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Canton Racing View Post
    Hey guys,
    Good to hear.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
  36. #236
    Jun 07 2012
    Netherlands
    From the guys i spoke to I know that the oilpressure sensor was used to plumb in to the block.
    The oilsensor (m10x1) is standard screwed in to an adapter (M24x1.4-> M10x1) that is screwed in to the block
    The way was different. What I know;
    Latosa had a fitting welded to the original adapter to accomodate the sensor and the hose coupling.
    I used an adapter (M24x1.5 - 3/8") in which a swivelling (banjo) fitting was screwed. The swiveling end was used to accomodate the hose fitting and an M10x1 thread was machined in the top of the fitting to accomodate the sensor.
    Pretty straight forward.
    Hey guys,
  37. #237
    Veteran Member Four Rings 0000 V8's Avatar
    Feb 19 2010
    Porsche Cayenne Turbo, B6 S4, C5 Allroad, B5 A4, Prius C
    Sacramento, CA
    S4carlo, where on the block did you do this?
  38. #238
    Jun 07 2012
    Netherlands
    It's on the backside of the block (latosa sent pictures) between the block and the "firepanel" just below the EGR.
    I am preparing a write up on what I did. Will post in a few days
  39. #239
    Feb 19 2010
    Sacramento, CA
    I don't see any photos.
  40. #240
    Jan 28 2013
    North Branford/CT
    Would you guys use a different oil filter canister cover if it allowed plumbing of an accusump? I'm going to try to source a canister cover so our machine shop can figure out how easy it would be.
    I'm also curious as to how many of you guys bring these to the track with any frequency.
