Results 1 to 20 of 20
    Mar 20 2009
    Scotland
    K04-015, with otherwise stock engine.
    Trying to find the viability of running a K04 on an otherwise standard engine, wether anyones done it and what sort of power it made?
    I have two A4's, one the wife drives and i'd like to keep fairly stock in the engine department, and my own car that i like to fiddle with.
    The turbo on the wifes has had it, so i've picked up a K04 to go on in its place. Now i realise i could just bolt it on and run stock tune and stay on stock power, but now that extra headroom is there, i'm wondering how far we can take it, without getting into the world of starting to upgrade the exhaust/intercooler/etc etc etc.
    Furthermore, if you were to make one single modification to get more out of it, what would it be?
    I'm thinking it would be between an intercooler upgrade, and a bigger downpipe with sports cat.
    Dec 05 2007
    I would personally do the setup proper with supporting mods.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You can run a k04 with all sorts of upgrades no problem but you won't see much in the way of extra power until you get a tune
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Mar 20 2009
    Scotland
    Seerlah: If it were my own car then sure, but this is a car that rarely gets driven hard, and i'd find it hard to justify going all out and installing a big intercooler, test pipe, big MAF, big injectors etc etc etc.
    The car will be custom mapped anyway, i dont do off the shelf tunes.
    If it were a case of "you'll make 190hp unless you upgrade the intercooler, at which point you'll be good for 220" then i could justify an intercooler upgrade. At the end of the day though, the stock maf and injectors are flat out around 235hp, and i really dont want to get into replacing those, so that sets my upper bound. I suspect i'll be nearing the flow limits of the turbo at that point anyway.
    Senior Member Three Rings DeathKing's Avatar
    Feb 15 2012
    New York/Los Angeles
    Quote Originally Posted by Aragorn View Post
    Single best would be a tune which you already doing and I'd say second would be a test-pipe to bigger downpipe or in your case a HFC.
    Established Member Three Rings morzechowski's Avatar
    Jul 20 2011
    500whp 1.8t, 2500HD Duramax
    Minnesota
    You can get the injectors, MAF, and tune then call it a day.
    Required Hardware:
    380 cc injectors (real S3/225TT 380 or Deka 1 Siemens 380)
    225 TT 3inch OD MAF with real TT sensor not golf jetta (Part number: 06A906461EX)
    k04 turbo
    Recommended:
    2.5-3.0 inch. turbo back exhaust with a quality CAT.
    104 octane for best performance in Race mode. 100 Octane performs well if not blended with pump fuel.
    Turbo inlet hose to prevent collapse if a lot of power is attained.
    F - N75 valve works best
    Intake: long tube CAIs or stock air boxes, or short if velocity stacked properly.
    Green Coolant temp sensor.
    Upgraded intercooler with less than 2 psi boost drop and IATs less than 50 deg. C. sustained.
    Taken from GIACusa.com then edited a bit. Also, this is info for a 2001 awm. not sure what you have.
    I like George Michaels
    Dec 05 2007
    If you are going custom tune, max out that MAF, stock injectors, place in 5 bar fpr, etc just like the j-31 file. You won't be replacing much stuff. And the stock exhaust is just silly at less than 2" with a retarded call count cat converter (can't recall number, but it was up there). That is the first thing I ever upgraded, engine wise, on my vehicle. Basically, you can do all that stuff without making the vehicle like a "tuner" vehicle. Just choose your parts accordingly. And it can really be done with not much expense. For example, a cheap ebay intercooler will be just fine for the k04. Along with that, cheap ebay silicone turbo inlet pipe.
    Mar 20 2009
    Scotland
    I have an AJL, which is more or less an AEB engine but came factory tuned to 180hp
    No off the shelf tune exists for this ECU, hence it will be a custom job.
    I'll leave it up to the tuner to decide on MAF and injector choices as appropriate.
    Interesting that GIAC say that both the exhaust and intercooler is recommended but not required.
    So has anyone ever run something like that GIAC tune, with an otherwise standard engine ie exhaust/intercooler etc.
    Jul 20 2011
    Minnesota
    I edited that list for you. I think GIAC did have the IC listed as required, but really its not so i moved it. A local buddy of mine has been running his APR stage 3 kit on his stock side mount for almost 5 years now with no problems.
    Established Member Two Rings blackwat5r's Avatar
    Oct 21 2009
    '01 A4 1.8tqm, '95 Jeep Cherokee, ‘16 Nissan Altima
    West Chester, PA
    Of course you could run the k04 without an upgraded exhaust and intercooler, but there would be a noticeable difference in performance.
    A less restrictive exhaust (with high flow cat or catless) will give you a few hundred rpm quicker spool up time as well as added hp/tq.
    An upgraded intercooler will ensure you're not losing the power that you're already making by decreasing the chance of heatsoak (which would cause a lot of timing to be pulled)
    If you're still on the fence, you could always add an exhaust/intercooler later, but if you're going with a custom tune- it'd be beneficial to have those in place while being tuned.
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    If you are going to bother at all modding at all, even if you don't do the K04, I would still recommend an intercooler upgrade. You will still see decent gains even on a mild K03 tune.
    ...with a K04 I would upgrade it for sure. Just a simple Apikol SMIC would be fine.
    Veteran Member Three Rings B5 Quattro's Avatar
    Feb 10 2008
    2000Audi A4, '88 VW Jetta 2.0l16v, 2011 Golf....
    Hamilton.Ont, Canada
    Any Links to the stuff you guys are talking about ??
    (Pics)
    In need of a great Detailer, pm me !
    Thats what I do !!
    http://www.detailsrkey.com/index.html
    "A man who does not change his mind is a man who has no mind"-M. Carby
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    I ran my k04-015 for a long time with just a sport cat and the GIAC standard tune. They recommend the exhaust and intercooler because of the higher pressure, which creates more heat.
    It isnt required because your ECU can retard your timing to avoid detonation. The K04 with test pipe and tune will be a huge improvement over a stock motor.
    Senior Member Two Rings rockersteady's Avatar
    Apr 10 2011
    another 4x AEB B5 1.8t QM , a b6 QM and b5 S4
    Sydney Australia
    yes absolutely, but not entirely nessecary , there will be a slight bottle neck at upper rev WOT but how long are you at upper ev WOT? Egts will rise (momentarilly- shes not tracking it or street racing?)
    same goes with intercooler- not necessary for her car.
    Ive run k04, and FTurbo type hybrid on stock car (upgraded clutch) with k04 tunes no dramas for short bursts.
    wack a hybrid on, run a k04 file and youll be maxing out your maf (Thats how much power) in no time (short burst= no dramas) all on stock AJL.
    In summer, in Australia. youre in Scotland you dont need an intercooler.
    my stock play arounds getting a dose of maestro 7 (starting from stock stage 1 base file) in next few days, then im adding meth and will be dynoing both my AJL sig car and the stock AJL, both on Maestro 7 in the annual Sydney VAG dyno day, end of April.
    99.5 QM, 2.0 stroker EFR 6758 e85 at 7 bar, 413 Bosch fuel pump in 034 Surge tank. Miltek 2.75, CM 240mm fx400 x 6, koni CO's, Stoptech BB, stealth V8maf in stock airbox, VVT upgrade,
    Concept, build and tune by Quattro motorsport
    Jun 08 2011
    Stillwater, MN
    Is GIAC the only company to make the K04/5BAR tune on stock injectors? I've been reading so threads from 2005 mentioning that the older software versions had throttle cut issues. My software came from Speedtuning, however Oliver refuses to tell me who wrote the damn thing. He just said he gets his software from different places depending on what it is and for which type of vehicle. I'd like to know about the version I have an all of that in order to troubleshoot all the issues I'm having. Maybe I can just bring it to a local GIAC dealer and see if he can hook the ECU up and tell me more?
    2001 A4 1.8T Quattro Manual Brilliant Black-Motoza e85 K04 Tune on 550cc Bosch Injectors and 4BAR w/ Borg Warner K04-15 running 21PSI-FastWayRacer Ebay FMIC w/ 2.5 Piping-OEM N75-Axiom Performance 255LPH FP-3" Eurocode Tuning Test Pipe-2.5" XS-Power Exhaust-UPGR8 TIP-710N-Single Mass Valeo Clutch-Green Coolant Temp Sensor-Standard OEM Plugs-Standard-OEM MAF-Rare 17" Alloy Wheels From Romania
    Jan 22 2014
    Fairfield, Ca
    I would give the wife your k03 and slap the k04 on your A4 and let the modding begin!
    2005.5 A4 Avant; TSI cam follower conversion. Build Thread
    99.5 1.8TQM; Maestro, GTX2867R, and a ton more mods. RIP
    Build Thread
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by pichno View Post
    You two love necrobumping. Since you are AWM, your tuner probably gets the file s from nefarious. Check it out.
    http://www.nefariousmotorsports.com/forum/
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jun 08 2011
    Stillwater, MN
    Quote Originally Posted by Avant Nate View Post
    Whoa! Never heard of it, and it's confusing as heck to me when I browse.....
    Dec 23 2009
    Boulder, CO
    It's a community sourced tuning, where they share tunes. Much more popular with the S4 and B6 community, wHo share the same engine as you. It's a lot more complicated, but near free if you understand it, of which I do not.
    Jun 08 2011
    Stillwater, MN
    lol that makes two of us bud.....
