Page 1783 of 1786 FirstFirst ... 783128316831733177317811782178317841785 ... LastLast
Results 71,281 to 71,320 of 71422
  1. #71281
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Billet VC UPDATE...
    So I did smoke test it yesterday, and unfortunately, its not fully sealed..
    I contacted the company to see what they have to say, but wont hear anything till prob Mon or Tues.
    So for solutions.. The plate needs some sort of sealing surface. Could use some RTV but I want the cover to still be removable, and not make a mess of it. So it am making a copy of the cover, in a rubber/fiber gasket material. Little more work than using rtv/anerobic sealant, but will still be removable.
    The PCV plate they include in case you wanna go the catch can route, includes a plastic layer to help seal. So the plate needs something similar. I mentioned all this in my email, so we'll see what they say. Would be easy for them too revise this to seal properly.
    Incuded some pics..
    Will update after testing again.0323241926a.jpg0323241926b.jpg0323241655.jpg0323241933_HDR.jpg0323242042_HDR.jpg
    Sent from my LM-V600 using Audizine Forum mobile app
  2. #71282
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    What's the purpose of the baffle? My IE cover does not have one, but it' also not provisioned for a PCV valve.
    2019 SQ5 Prestige
  3. #71283
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by texasboy21 View Post
    Its designed like a factory one, so you can use a factory PCV setup with it. That's the main reason for testing it, no other billet cover has PCV provisions.
    For someone like myself with cold winters, be nice to have a billet cover I can run without the need of a catch can..
    But seems it needs a little tweeking, sadly. Nothing major, but not "bolt on" out the box. Waiting to hear back from the company this week.
    Not a big deal for me, but will turn a lot of people off from buying.
  4. #71284
    Apr 01 2007
    houston texas
    Quote Originally Posted by Jayz691 View Post
    Good stuff!
    2019 SQ5 Prestige
  5. #71285
    Jan 21 2018
    frackville, pa US
    Another Billet VC update:
    Ok, so the rubber/fiber gasket didn't work 100%. Seems theres just not enough screws to hold pressure across the whole plate. The whole mating surfase is not getting compression to the gasket. Even tried some(longer) hex bolts with washers, no go.
    So looks like ill just have to use a sealant...
    Good news on the n80 ports though. Thought they were too big, but after measuring/testing, theyre good. Only thing, the one on the IM side needs a little tapering on the end, to allow the clip to slide in all the way. No big deal.
    I also test fit coil packs, all good there0324241850a_HDR.jpg0324241857.jpg0324241857a.jpg0324241902_HDR.jpg0324241903_HDR.jpg
  6. #71286
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I?m still making progress, but nothing drastic. I ended up using a broken carbon hockey stick to mount my CTS Turbo FMIC. I?m running an aluminum rad cradle and it doesn?t have provisions to mount the FMIC (the rad is in the trunk).
    I still need to trim off the ends so the lights will mount and clean up then hardware, but I like it. I can start fabbing my intercooler piping, and the best part is the dry sump mandrel now has proper clearance. I can also access the dry sump pump to build pressure using a drill with the FMIC mounted.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
  7. #71287
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Finally did the wastegate spring mod.
    When Ive flashed the car back early 2015, I was regularly getting 22psi, and some pikes at 25psi (when the gauge flashed red when you hit 25psi).
    Im 99% sure, Unitronic advertised their tune @22psi in 2015, now it shows 19psi....
    Strangely enough I was getting 18psi-19psi ish since a year, car getting old.
    SPRING mod DONE : back ! 22psi and some pikes on heavy highway pull at 25psi.
    why I didnt simply adjust the rod? well, goold luck on a old car with no space. This bolt must be welded there.
    Also, this is NOT a 20 min job. The way the guy attach the spring in that thread, there's no way this will hold, no gap between the adjusting screw and the frame
    https://www.audizine.com/forum/showt...20-and-20-mins
  8. #71288
    Jan 21 2018
    frackville, pa US
    Ya need a long needle nose to adjust it, did it years ago when I still had a k03.
    Only issue is ya dont know what the actual spring pressure is now.
    Have ya done any logs to see what you get midrange vs requested?
    If the tune is requesting 18-19psi, ya font want 25psi..
    Don't think I like this idea, but oh well, lol.
    Curious what the spring pressure is now. If ya have an extra n75, and have some extra time.. Unplug your n75, and plug into a spare. Take it for a ride and so a boost logs, see what it hits..
  9. #71289
    Jul 01 2015
    Mtl
    this makes sense.
    however, many did this no issue. Ill do a log, but I dont have my previous logs when I was around 22psi all the time, so hard to tell if it request the same thing. I didnt change anything since 2015 on the engine. Still have same intake, same exhaust, same turbo, same gauges, same tune, dv+ (now refreshed because I thought it was the issue), new N75 (no change).
    My last item was the waste gate normal wear, where a lot of members reported.
    For now, it act just like before.
    ( I used : Century Spring C-219 Extension Spring 4-1/2" L 15/32" OD .041" WD 2-Pk)
  10. #71290
    Established Member Two Rings Phosphorust's Avatar
    Feb 03 2024
    2023 Subaru BRZ, 1993 Ford Bronco XLT, 2012 Ford Escape
    Massachusetts
    Hey guys. Long time lurker here in the B7 A4 forum. I've been restoring an Audi that I picked up for $1,300 in the worst condition it could possibly be in. I'd put everything I've fixed on it so far, but I'm limiting myself to a short story rather than a novel.
    Exterior-wise, I've got new headlights, an S4 front bumper, tinted side markers and taillights (yes i know people hate the smoked lenses but i like it), a trunk+rear windshield spoiler, and new to me Enkei wheels on slotted rotors. I just bought a C6 A6 honeycomb grille to cut up and drop in on my front bumper and already painted my crash bar gloss black. Once I do the grille upgrade, I plan on buying the honeycomb fog light trim too.
    Performance-wise, I've got a CTS Turbo Catless Testpipe, a Cold air intake, upgraded spark plugs and upgraded coil packs. I plan on Stage 2'ing it once I fix my turbo's coolant leak.
  11. #71291
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    That's a steal of a deal. How much did you ended up spending on it.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  12. #71292
    Mar 08 2011
    union, nj
    Keep it up, as these cars are getting older I think its more important to ensure you have a good running car before you start adding more power to it. Do your maintenance with due diligence and take it from there. Best of luck with your project.
  13. #71293
    Feb 03 2024
    Massachusetts
    Quote Originally Posted by 80sGuy View Post
    So far I'm in the hole about $3,500 total, including the cost of purchase. Most people would never ever touch this car in the state it was when I got it. 3 base line wheels, 1 S-Line wheel, and 3 of the tires had holes in them. My muffler is rotted away still and idk what to buy to fit with it now because I have a CTS Turbo Test pipe. For sharks and goggles I'll put below everything I've had to fix.
    • Starter
    • Starter relay
    • ECU cover (water was leaking into the driver side floor
    • Coil packs
    • Spark plugs
    • Wheels + tires
    • Brakes
    • Brake line flush
    • Brake calipers (rear)
    • Rotors
    • Oil change + filter
    • New battery
    • New power steering pump
    • Power steering flush (the guy before me put transmission fluid in it...)
    • A pulley wheel that spun a bearing and a new serpentine belt
    • Reconnected fuel pump underneath the rear seats (it was squirting gasoline into my car when I first started trying to crank it)
    • Wiper linkage
    • Needed a new front bumper
    • Needed a new hood
    • Needs new glass on the passenger side mirror
    • Needed a front crash bar
    • Needs a new head unit (im going aftermarket anyways)
    • Coolant inlet leak on the turbo
    • Oil return line leak on the turbo
    • New ceramic brake pads
  14. #71294
    Junior Member Two Rings
    Aug 24 2023
    B5 A4 1.8T quattro, mk3 Jetta Vr6
    So I have been meaning to make a thread on this actually. I also ordered a valve cover from them and told them the passages are not sealed. They told me this is not an issue and no one else has complained about that and they have tons of sales. I told them they need to be sealed and they just argued with me saying their engineers have looked into it and I'm wrong, and ghosted me. The fitting for the metal tube going from the VC to the turbo also wasn't even close to the right size, they sent me a new one that was closer but still not right but they ghosted me after this so I had to use tape to make it bigger. I also had to drill out another fitting to make the very small line on the other side able to fit into it. I ended up sealing the passages with RTV which I am very upset about but they won't respond for a return and also won't accept they need to make a gasket for this. Oh they also leaked their entire customer email list accidentally.... It would be really nice to spread this info lol I really need to make that thread.
  15. #71295
    Aug 24 2023
    431988657_395636626590957_454269895178817695_n.jpg My VC, it's too bad they don't want to work with customers when they mess up, because it's a great looking product.
  16. #71296
    Jan 21 2018
    frackville, pa US
    I wound up sealing it within a thing bead of RTV, which isnt a big deal to ne. Its the only way too really do its. I made a gasket out of rubber/fiber, but theres not enough screws to hold it tight enough to fully seal.
    The fittings were fine on mine, I just had to taper the one for the n80 line(IM side). But had to trim the PCV so its wouldnt hit on the sides. They either need a spacer, or have the face come out onother 1/4" or so. Its hits on both ends, where it curves.
    Sad thing is it would be so easy for them too fix, but I still am glad I got it..
    Edit:for some reason my pics won't upload. Ill post them when I can..
  17. #71297
    Oct 09 2007
    Miele S7
    More preventive maintenance for this 17 year old....
    Coolant Reservoir Cap:
    I started sensing some faint sweet smell around the front and under the wheel well. No sign of leaks anywhere but I can smell the stuff lingering in the air. I believe the cap is on its last leg of holding pressure and it best just to replace it. Guess what, no more faint smell of sweet coolant lingering!
    New (top), Old (bottom)
    Engine Oil Dipstick:
    Going on third (second replacement) and I'm getting tired of this. Keeps on breaking off on the grip, so this time I decided to lube some silicone grease around it. All the vital areas that travel like the mid guide, and grip on ring. This is safe and designed for o-rings and should be good enough, hopefully it'll hold up longer, if not indefinitely. It feels really good when pulling in and out.
    Last but not least, time to replace some important Sensors. Last month I replaced the Crankshaft Position Sensor (CKS) while changing out the nearby adjacent old leaky Oil Filter Housing. Now I think it is time to also replace the Camshaft Position Sensor (CPS). They both have pretty much the same symptoms and for 17 years old, going on 18 years it definitely needs to be replaced before it takes a dump on me! These sensors are often overlooked and/or ignored and when failed it can really leave you scratching your head (see symptoms below). Though the CPS is located on top of the cam/timing belt cover, positioning to the T30 torx bolt isn't as easy to get to as it looks due to limited space.
    Old part: tip looked all brown (not sure if it's original color from '07-08 part) and has a faint discoloration/burn mark.
    Done!
    Note:
    Symptoms of Camshaft Position Sensor (also very similar to Crankshaft Position Sensor)
    Poor Fuel Economy: A failing camshaft position sensor will provide inaccurate data to the engine control module. With the wrong information, your engine will not be able to run as efficiently as it should causing it to consume more fuel.
    Stalling: When the fuel injectors are not delivering the proper amount of fuel, the engine could experience stalling.
    Engine Idles Roughly: A rough idling engine could be caused by a failing camshaft position sensor. This issue is more evident when the engine is idling.
    Hesitation: Hesitation during acceleration is a common issue that you may experience with a bad camshaft sensor.
    Failed Emissions Test: When the engine is not performing properly, it will not be able to burn fuel efficiently. This can lead to increased emissions.
    Smell of Gas: Unburned fuel can make its way out of your tailpipe which can produce a noticeable smell of gas.
    Car Will Not Start: Over time, as the camshaft position sensor fails, the signal it sends to the engine control module weakens. When the engine no longer receives the signal, you will not be able to start your car.
    Engine Misfires: A failing camshaft position sensor can cause your engine to misfire.
    Transmission Shifting Problems: The data sent to the engine control module can stop the transmission from shifting properly. In some vehicles, there is a security feature that puts the car in “limp mode.” This helps to prevent major engine damage.
    Check Engine Light is Illuminated: When your vehicle is experiencing a problem, it will trigger the check engine light. The light can be triggered by a number of different reasons.
  18. #71298
    Jun 27 2011
    What Did You Do To Your B7 Today?..
    Replaced my oil filter housing gaskets today since my b7 had graduated from seeping enough oil to just be sorta damp under the engine to leaving oil stains on the street.
    After discovering that with H&R springs I can’t get my car up on my ramps, and screwing around with my small jack for 30 minute and finally giving up and moving to the large jack (which I don’t enjoy using since it’s so damn heavy) I finally dug in. Followed the diy on here and had watched the YouTube video beforehand just to familiarize myself.
    It went smoothly and I spent a good 30 minutes cleaning the housing and scarping the carbon buildup off of many of the passages. Then I was prying at the old gaskets which were crusty as hell and with a gentle tap the inner section of one of the coolant passages on the housing broke off.
    I was only planning on replacing the gaskets so I had a set of Mahle gaskets, but, given how bad the crack was, I didn’t see how that coolant passage would ever properly seal again. So I called up my local dealer and bit the bullet on a new $415 housing. So much for being thrifty I guess. On the plus side, it came with a new filter already installed, a new filter basket and new OEM seals. Small wins but whatever.
    Got that back in relatively quickly after spending 20 minutes trying to find the 4th housing bolt that had disappeared into the ether when I removed it. Of course the last little 10mm nut that held one of the brackets to another bracket fell like 10 times and that took another 20+ minutes of poking at crevices with my telescoping magnet until I got it on there.
    Hopefully this is the end of my oily engine bay (and the hot oil smell that follows my car around too). I’m be far more pleased if I didn’t need to buy a new housing but I’m glad it’s sorted.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  19. #71299
    Jan 21 2018
    frackville, pa US
    Damm!! $415, holy crap, lol. Man they've gone up, like everything I guess. Theyre $300 from ECS, but guess if ya couldn't wait, that don't matter...
  20. #71300
    Jun 27 2011
    Yea they’re ridiculous. Price was including tax, but yea I’d have been smarter to have just bought the whole damn thing ahead of time, but I’m just glad the dealer had one in stock. Would have sucked to be down a car while paying expedited shipping to hope to have it by midweek.
    Either way I’m just glad the job wasn’t too horrible. Expect for the tsunami of coolant and oil when I pulled the cooler off. Top tip, kids: don’t forget to drain the coolant first!
    -CP
    2017 Q7 3.0t
  21. #71301
    Oct 09 2007
    Miele S7
    It is always wise to replace the entire filter housing at such age, preferably genuine parts of course. Gaskets will not hold up long even if you were to replace them.
  22. #71302
    Jul 01 2015
    Mtl
    use Elring Curil T Liquid Gasket for this oil filter housing job.
  23. #71303
    Jun 27 2011
    Yea I had my reasons for trying to limp this old housing along for longer rather than buy a new one but ultimately I needed to get this fixed.
    And yea agreed on OEM parts only for this job.
    -CP
    2017 Q7 3.0t
  24. #71304
    Jan 21 2018
    frackville, pa US
    This is way its good the aluminum housing is working out. $100 vs $400... Till now, genuine was the only solid option.
  25. #71305
    Jun 27 2011
    TIL there is a cast aluminum version available on Amazon from MITZONE whoever tf that is. Is that the one you’re talking about?!
    Also, is it just me or has Tapatalk gotten so slow it’s nearly unusable?
    -CP
    2017 Q7 3.0t
  26. #71306
    Jan 21 2018
    frackville, pa US
    Yes, thats the one people are using. So far, good results. Since its new, it'll take time too know how durable it is, but it works.
    And AZ has been glitchy fot me, for a few weeks now. Slow, can't upload pics, PITA..
    I use the mobile app, on my LG phone.
  27. #71307
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Installed Milltek exhaust, Techtonics Tuning downpipe, and 034 Motorsport HFC. Deeper exhaust tone and turbo spools faster. I likey
  28. #71308
    Feb 15 2016
    Cambridge,Ontario
    Charles i'm a bit shocked at this .. you have ben around a long time. You KNOW that just replacing the gaskets is a doomed project right from the start lol.
    I guess its like soldiers that go to war, they have to think that they are the one guy that will beat the odds and survive ...
    RIP to this housing that didn't make it back ...
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  29. #71309
    Feb 03 2024
    Massachusetts
    Did the C6 A6 Honeycomb Grille mesh swap for the B7 A4 S-Line grille. Front bumper isn't fully on and hood isn't fully closed because I have to cut my new intercooler air channels so the driver side bumper mounting bolts will go through the holes properly.
    Check it out:
  30. #71310
    Junior Member Two Rings JON.TRU's Avatar
    Jun 30 2014
    03 rotated 35R widebody WRX / 06 Avant S.line
    Sandy, UT
    my RS4/Allroad inspired A4 S.line
    Fixed after a collision i had last month.
    250,000+miles
    B7 A4road by Jonathan Truong, on Flickr
  31. #71311
    Feb 03 2024
    Massachusetts
    Gorgeous car!
  32. #71312
    Established Member Two Rings chili dog's Avatar
    Oct 26 2018
    Sterling, VA
    Digging both cars above!
    Quote Originally Posted by JON.TRU View Post
    If you don’t already have it, the ECS rear diffuser looks great on a wagon.
  33. #71313
    Jul 01 2015
    Mtl
    250,000+miles
    sweet, avant with rs4.
    I dont have wider fender lip, but I run stretched tires !
    flush !
  34. #71314
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by oVeRdOsE View Post
    flush !
    Nice S-line avant. Is it a manual TI?
  35. #71315
    Aug 18 2009
    A Unicorn
    Portland, OR
    I can tell by looking at it that it's not a Ti (Silver roof rails and headliner)
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  36. #71316
    Jul 01 2015
    Mtl
    got it, it's manual, real s-line (2008), but no TI. Chrome delete and front grill blacked out.
  37. #71317
    Jan 21 2018
    frackville, pa US
    Oh, yeah, didn't look at the roof rails, just the trim..
  38. #71318
    Jul 01 2015
    Mtl
    I wish to have a TI, but the trim I have not bad. I like the silver rails with the silver wheels and front audi chrome logo and chrome grill bars. It fits the look imo.
    Not a unicorn, but well loaded. I miss : garage remote, rear heating seats, directional headlight ( but they are level). But I have navi, memory seats, bose system. 2008 came with rs4 pedals too OEM.
    Nice little package, I keep it clean, I dont ride it in winter time.
    stage 2 on meth and lwfw clutch kit. Enough to have fun.
  39. #71319
    Jun 27 2011
    Has anyone successfully recalibrated their speedometer? Mine reads pretty consistently 10% off on the dial and it’s annoying.
    Amusingly, the latest RNSE custom firmware enables a digital speedometer in the DIS and it’s dead on accurate compared to Waze GPS as well as those roadside “you’re going this fast” things neighborhoods tend to have near schools.
    It’s always been a bit off, even in my b6 but it’s a solid 10% and it’s beginning to really bug me. Any ideas? I’m seeing that VCDS doesn’t allow you to do it but do any of those VAG-Commander type utilities work?
    -CP
    2017 Q7 3.0t
  40. #71320
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    https://blog.goosmannlaw.com/risk-ma...of%2050%20mph.
    According to this, 10% is within spec unless there's a newer version of the regulation in place, Most manufacturers calibrate the speedo to read high so that they won't get sued because the speedo indicated a slower speed than they were actually travelling and they got ticketed. GPS should be pretty close to 100% accurate as it's calculating based on time and signals received and there probably isn't any speed related calibration regulation they need adhere to. if you didn't have a phone app or GPS device you wouldn't evenknow your speedo is off spec.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
