Results 1 to 28 of 28
    Feb 09 2012
    Wellington, FL
    Drag mode sequence for Tiptronic
    I know many have already demonstrated this technique before....but I noticed that there is a specific sequence for enabling it on my car....and I am sure many others are thinking that their car doesnt have drag mode because of this.... well heres a quick video illustrating my procedure. This run was a 5.4 second run to 60mph!...the tranny really shfts quickly and the revs stay below 6k to keep the engine in the powerband.....THANK YOU AUDI!!!!.....
    BTW....the car is stock other than a stage 1 93oct flash.
    Jul 07 2009
    Lebanon
    Thanks for the info; will give it a try in my A5.
    When you say full throttle, did you press the pedal past the click?
    SOLD: 2010 A5
    Active Member Four Rings Auditude2.0T's Avatar
    Jan 01 2008
    Long Island NY
    It's called power braking, every automatic does this.. It's loading up the torque converter lol
    Jun 15 2009
    2007 Audi A4
    IL
    Quote Originally Posted by Wah View Post
    It means pedal to the metal buddy!
    Sent from my SGH-T959 using Tapatalk
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    "Drag Mode"?....better known as Launch Control....no? Hasn't this been covered a million times before?
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Feb 09 2012
    Wellington, FL
    Quote Originally Posted by Auditude2.0T View Post
    its not really "Launch" control, and the point of this is not actually the launch(or power braking)..which any car with a converter can do.....its more for the transmission to shift early and quickly....the shifts are very crisp and early in this mode unlike normal shifts. During normal shifts there is a slight delay in power delivery that occurs during the shift to soften the event, in this "drag" mode the computer uses a different shifting strategy to maintain constant acceleration by making the shifts VERY hard and fast....I wouldnt call this "launch" mode because the car launches the same regardless....but the transmission shifts completely differently.
    Quote Originally Posted by Crucible35 View Post
    as I said in my original post " I know many have already demonstrated this technique before" but there is some confusion as to wether or not this strategy works on every B8 Tip..and I discovered a sequence needed to access this mode on my car....so I would imagine many people havent been able to do this for the same reason....not because they dont have this mode on their car, but because they werent following the sequence to engage the mode....which is as follows:
    1. from a complete stop put the shifter in "S" or sport mode.
    2. hold the ESP button down until both ASR and ESP are completely off (roughly 4-5 seconds)
    3. hold foot brake very hard to prevent car from rolling
    4. mash the gas pedal to the floor(past the click) and wait for rpms to climb as the car builds boost
    5 release the brake as the revs reach 3000+rpm and HOLD ON!...
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    I thought my thread on this covered the topic pretty thoroughly.... Including what was needed to do it.
    http://www.audizine.com/forum/showth...launch+control
    Feb 09 2012
    Wellington, FL
    Quote Originally Posted by Miles M View Post
    The problem is you did not outline the correct sequence of steps to put the car into Drag mode
    While this is mostly true, the car has a program hidden in as well that quickens the shifts and allows you to run up to about 3.5k rpm without the brake slipping.
    ASR/ESP Off and put it in Sport. Foot firmly on the brake and go to full throttle. Wait about 3 seconds and woosh.
    ...if you dont put the car in S-Mode BEFORE disabling ASR/ESP(completely)... my car wont activate the mode....and will shift sluggish as usual.....it was bothering me because before I discovered this I couldnt figure out why sometimes it would work and sometimes not....And one other thing I noticed....the quick shifts will only occur if you come to a complete stop before accelerating....if you try to just accelerate from a slow roll the shifts are delayed and sluggish again until you stop completely and launch.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I can't believe I just found this out, awesome!
    Feb 22 2009
    Ottawa
    Does it work on all B8, i.e. 2010+, and also the 8 sp?
    Does it stay in that mode if you keep driving it, or does it only last for one run, or until you stop etc.?
    I remember that the 2009 A4 Car & Driver review had a 5.7 0-60 but all subsequent reviews were more like 6.3-6.5, and they never mentioned doing these acrobatics. So I wonder if this is only doable on a 2009, if they stumbled on it by accident, or if they forgot to do it in later reviews.
    Apr 05 2011
    Pacific Northwest
    Yup...that's Launch Control folks.
    Highlander's Build Thread
    Jan 14 2010
    Georgia
    Quote Originally Posted by belzebutt View Post
    I noticed while doing it today that if you load up and then kinda let off without starting completly over, like taking your foot back off the brake and then back on it wouldn't go up in revs as high. While trying to do it again was only revving to 2k started again and went back up to 3k. I'm stock so I figure that could be in part why it did that. oh and I have an '09.
    Jul 12 2010
    Q5 3.0T
    good job
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Is it just me, or is anyone else worried that little bits of the tranny will come spewing out the tailpipe doing this kinda thing? Not sure if this applies to a CVT, which I do not have btw...
    Feb 09 2012
    Wellington, FL
    Quote Originally Posted by Cabal_san View Post
    haha!....I seriously doubt this harms the tranny.....I would be more afraid of breaking and axle or the like.... these trannies seem like they can handle quite a bit of power.
    Senior Member Two Rings millerns's Avatar
    Jan 13 2010
    I didn't know about this either - pretty cool. Miles' thread is helpful too but I'm with some of you, could this be bad for the car? Obviously if you do it a lot it could do some damage, but what about the occasional push? Maybe issues with the brakes? Idk, just throwing this out there for people to ponder
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Sep 02 2011
    TO
    Quote Originally Posted by BoostCrzy View Post
    You seriously doubt that torque-braking and extra hard shifts are bad for the tranny in the long run?? Are you serous???
    Jun 15 2009
    2007 Audi A4
    IL
    Fyi when i had a rental 2010 A4. I masses around with the transmission like that. It was cool for few times until something snapped and made a harmful sound. The car never shifted right to the 2ND gear. So i would be careful about that, and not do any damage to your cars. These transmissions are not cheep to fix or replace!
    Sent from my DROID BIONIC using Tapatalk
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by quickaudi07 View Post
    thats pretty scary
    Feb 09 2012
    Wellington, FL
    Quote Originally Posted by MonzaA5 View Post
    ....dont get me wrong...I know its not good to launch the car like this all the time over and over...but once in a while shouldnt be an issue...and usually in automatic transmissions its best to complete the shift as quickly as possible to prevent excessive wear on the clutches from slipping between gear changes....
    Jul 07 2009
    Lebanon
    I've given it a shot last night and the revs climb to 4k before launching forward like a rocket. WOW!
    In my case however I would say that this is described as launch control as shifts were not short, gears would change very close to redline. Awesome feeling nonetheless.
    SOLD: 2010 A5
    Apr 04 2011
    Jacksonville
    I can't believe none of the "Wizards of smart" here have not said this yet.......but isn't this just a band-aid for a LACK OF HP? :) j/k
    2011 Ibis White Ti, Premium +, APR Stage 2 ECU, APR Full Dual Exit Exhaust, Carbino, dyno corrected 248BHP-376 lb/ft, 40% 3M Crystalline "7 window" tint, 90% 3M Crystalline Windshield tint, 90% 3m Crystalline Sunroof tint, Curt 1.25" trailer hitch, stock Ti 19x8.5 et43 wheels (28lbs each), Wheel Spacers 5mm ft/10mm rr (effectively et38 ft/et 33 rear), Michelin Pilot SuperSport 255/35/19
    Feb 09 2012
    Wellington, FL
    Juat revisiting this.....Love my car....no problems yet after 12,000miles...... I am wondering if any of the Vag-Com gurus have located the alternate transmission shift modes/schedules in order to permanently activate this performance mode?....
    Feb 13 2004
    Silicon Valley, CA
    I could be wrong, but I think VAG cannot access the TCU. It is similar to the ECU in that it is pretty isolated and the first time you tune it, you would need to pull it from the car.
    Kevin - Moderator, Audizine
    Feb 09 2012
    Wellington, FL
    hmmmm....perhaps... either way its a cool feature...I wonder what the intended purpose was for this alternate program.
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Awesome, I am going to try this in the AM.
    Aug 27 2012
    Earth
    I tried it this morning! Freaking awesome! It also works in manual mode as well..
