Originally Posted by
OmaHahn
Don't you just need to turn off ASR, Anti Slip Reg? ESP is just for corning, Electronic Stability Prog. Just hit the ESP button once and turn off ASR.
Thanks to NPuter I manually changed my car to Dynamic via VCDS, vag-com on my 2009 3.2 V6. I don't have the ADS switch - computers & software is so cool - now the car has much quicker reaction, revs to redline under WOT, quicker shifts, etc. I'm going to try this launch technique today sometime! Does it matter if I'm in S1 (auto) or switch over to M1 (manual shifts)?? Thanks!
I'm not sure in your situation because you have ADS enabled, but the car is smart enough to, in "S", realize what you are doing and quicken the shifts.
indigoblue
I have stage 1 ecu upgrade from Evotech but unable to rev up to 3.5k rpm. Does stage2 change only variables for the new components or add something new to the ECU ?
As far as I know only Stage 2 removes the speed and rev limits. I could be wrong though.. also, I'm using APR software, not Evotech.
Highlander1010
Nope...forgot that. I'll have to try it again. I know how to turn ESP off (button), but what about ASR?
ASR goes off with the press of the ESP off button, but both ASR and ESP go off if you hold the ESP off button.
