Results 1 to 20 of 20
Hybrid View
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Compression check/test ... 80 PSI on each cylinder ???
    I just did a compression check on my engine just out of curiosity and I got around 80 PSI on each cylinder. That gets me worried now, I feel the car pulling strong though. I just hope I did something wrong I was in the rush, I'll repeat the test tomorrow.
    what i did:
    warmed up the engine
    disconnected the fuel pump fuse - 28(i believe) and engine management fuse - 43
    removed all the spark plugs and did only the dry test (did the test with WOT)
    I'll come back with the new readings tomorrow.
    Any thoughts in the meantime?
    - Chip
    034 Stage 2 ECU | 034 Stage 2 TCU | Wagner IC | IE Downpipe | ECS CAI Intake | Fuel-it e85 | Mishimoto Catch Can
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    That sounds really low man, anything less than 150 psi would raise an eyebrow. A fresh motor is going to see upwards of 200 psi. How many miles on the engine?
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Jul 26 2009
    DMV Area
    80k miles,
    as I said the engine pulls strong(or at least that's what I think), I hope I did something wrong measuring.
    I'm not sure if there's anything different in the procedure for our B7, but if it's the same as for B6 then my engine is about to die.
    - Chip
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by shiro1745 View Post
    80k miles,
    I think you should not have done wot during the test dry test does not mean wot it is just not adding oil to the engine in a wet test you squirt some oil into the cylinder I just did a lot of searching on compression testing and did not find one that said wot
    Jul 26 2009
    DMV Area
    Quote Originally Posted by martin0079 View Post
    it was my mistake, I didn't mean that dry test means WOT, I was trying to say that I did this test with WOT
    I will do the dry test again tomorrow along with the wet test (oil in the cylinders)
    I've spent a couple hours researching this before I did it, here is one of the DIY I found for B6, I figured it would be the same.
    http://forums.vwvortex.com/showthread.php?3521125
    - Chip
    Feb 29 2008
    Durham/NC/Southeast
    I would think an 80psi engine would smoke like crazy
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    it is off of vortex problem one hahahaits not a big deal I just never heard the wot bit before
    Jul 26 2009
    DMV Area
    I have never done this before and that was not the only source I used, I've watched several videos on youtube and read as much as I could in those two hours. I'm not saying you're wrong, I'm just saying what I've found was mentioning about WOT so that's what I did. But any advice is appreciated since I'm not an expert.
    - Chip
    Feb 29 2008
    Durham/NC/Southeast
    the general rule of thumb for compression testing for all 4 stroke engines is WOT and 8 compression strokes worth of cranking.
    Oct 14 2009
    Okinawa Japan
    8 compression strokes!!!! Never heard that, was always taught/shown 3 compression strokes?! I just tested mine cause Hpfp failure and I got 160-165 on each cylinder dry and like 170ish wet I think the spec is 160-220 is good to audi/Vw
    I'm not calling you out, just surprised. If a motor takes more than 4/5 strokes to get the compression than I would be worried and wouldn't really trust the results imho
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Jul 26 2009
    DMV Area
    I did 5 strokes but the last one did nothing so 4 would have been enough
    Edit: more strokes probably make sense if the pressure doesn't increase fast with the first three, there is a big chance then to have some bad leaks - this is only my logic here and it's based on what I've been reading about this today.
    - Chip
    Feb 29 2008
    Durham/NC/Southeast
    the more strokes is just used to give a maximum reading. If a cylinder is making only 80pis it will only read 80psi no matter how many times you crank it since we are dealing with pressure here not volume.
    Oct 14 2009
    Okinawa Japan
    True but I guess 8 just seems excessive + not good for the starter, by the third cylinder that puppies prolly pretty hot....
    -Shane Drake-
    >DRAKLOREs Build<
    Jul 26 2009
    DMV Area
    UPDATE: I just redid the test again today and got 175psi on every cylinder. It seemed the tool was loosing air through one connection, was not tight enough but wasn't really easy to see. I'm happy my engines still ok.
    - Chip
    Jan 24 2010
    Glad to hear that you solved the issue.
    Oct 14 2009
    Okinawa Japan
    With 80psi your car would noticeably smoke (like in plumes) and
    Would run like shit lol I was about to ask if you dis a wet test following but I'm glad you found the issue!
    -Shane Drake-
    >DRAKLOREs Build<
    Aug 27 2011
    Long Island
    were all plugs pulled?
    did you hold the throttle open when cranking?
    is the guage cheap?
    Aug 27 2011
    Long Island
    nvm... see you found the issue
    Jul 26 2009
    DMV Area
    Quote Originally Posted by Paulito View Post
    is the guage cheap?
    all plugs were out
    throttle was wide open
    it is a friend's tool don't know how much it was but looks cheap
    - Chip
    Jul 26 2009
    DMV Area
    Yes, I'm glad the engine is fine, I was a bit scared. Thank you guys for all the input!
    - Chip
