Results 1 to 40 of 122
Threaded View
  1. #11
    Veteran Member Three Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    @walky - quick question, if I'm removing ALL the vacuum hoses should I plug both ports on the N112 or only the one that went to the combi valve and leave the other open? After looping the appropriate holes on the N249 should I also plug the 3rd port or leave it open? Looked through the thread and there isn't any mention of this if you're removing everything.
    Edit: Also wanted to ask, if you remove all the vacuum lines but would like to keep the function of the N249, where could you get a reliable vacuum source from? Would routing it to the TIP be your best bet?
    || Instagram @SAMM9690 ||
