Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 122
  1. #81
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Anyone have a part number for this piece? It is the rubber grommet on the false firewall and I think mine is leaking:
    2021 SQ5
    2008 A4 Avant 6 speed
  2. #82
    Oct 30 2009
    Miami, FL
    Should be 8D0611743B.
    2018 S5 Coupe - stock for now
  3. #83
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by ballinb5 View Post
    May I ask why you think it is leaking?
    This is a check valve, which will hold vacuum pressure for a while after the engine is off. If you move the check valve around it will suck air into it (which sounds like a leak) since it holds vacuum.
    2001 Corvette (C5) Z06
  4. #84
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    I have eliminated all evap related crap under the hood, even that little square vacuum pump thingy under the coolant tank. what would be the effects if I eliminated the line going to the purge valve all the way back to the rear of the car? it starts at the purge valve, tucks down the passenger side wheel well, and runs to the rear on the bottom of the car next to the fuel lines? also, same question goes for the round plastic ball in the driver side fender (leak detection pump), all related lines that run under the car to the charcoal canister, and even removed the charcoal canister?
  5. #85
    Veteran Member Three Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    @walky - quick question, if I'm removing ALL the vacuum hoses should I plug both ports on the N112 or only the one that went to the combi valve and leave the other open? After looping the appropriate holes on the N249 should I also plug the 3rd port or leave it open? Looked through the thread and there isn't any mention of this if you're removing everything.
    Edit: Also wanted to ask, if you remove all the vacuum lines but would like to keep the function of the N249, where could you get a reliable vacuum source from? Would routing it to the TIP be your best bet?
    || Instagram @SAMM9690 ||
  6. #86
    Oct 24 2013
    girls MK4 1.8t
    United States
    some of the pics in the main write-up are not working.
  7. #87
    Dec 13 2010
    FL
    Quote Originally Posted by garytightpants View Post
    bcuz popular guy
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
  8. #88
    Jun 30 2008
    Erie, Pennsylvania
    Bandwidth on pics will reset on the 11th or so, I think.
    I'm working to move the pics to different accounts. But 'tis a lot of work to relink and all that jazz. And my 240k mile B5 is currently falling apart on me, so time is not easily had for such activities.
  9. #89
    Jan 22 2013
    00' A4 1.8Tq,01'Softail, 78' XS400E, 01' Blazer, 00' Passat GLX, 08' Caravan, 85' Sea Devil Cruisers
    Shirley/N.Y./U.S.
    Any1 have the pics for this awesome write up? I saved them somewhere but can't find them. I knew when I was ready for this, the pics would be gone. If not, I so hope ur B5 behaves long enough for u to get some free time, lol. Good luck with it.
  10. #90
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Just wanted to pop in and say:
    1 - pictures are working
    2 - thank you Walky.
  11. #91
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    There have been a lot of questions lately about doing Emissions system deletes on the B5 1.8T. User "absolutegtr" did a very nice writeup for the B6 1.8T guys here:
    http://www.audizine.com/forum/showth...simplification
    There is nothing quite like it for the B5’s. I hope this DIY writeup will stand in that gap.
    Goals:
    Simplify the under hood vacuum system.
    Identify specifically what does, and what does not cause DTC codes (and subsequent Check Engine Light illumination).
    Get rid of "all those check valves", after first understanding what they are for.
    Note 1: There are differences in the vacuum and pcv systems between almost every year of the B5. I will do my best to identify the differences. That said, most of the deletes discussed here will apply to the 2000+ cars. The 97-99.5 AEB emission system is already pretty simple as it is.
    Note 2: Since this is something I did a while back, it won't be a step by step type of thing. You can rip this crap out it whatever order you deem necessary and effective. Onward.
    For each system, We will first take a look at the factory setup and determine what exactly we want to remove. We will be going through the systems in a piece-wise fashion for those that only want to delete certain parts. The following will be covered in order:
    1. Secondary Air Injection system
    2. N249 (Electronic Control of Diverter Valve)
    3. Suction Jet Pump
    4. Vacuum Reservoir (constant vacuum source)
    5. Evaporative Emissions
    6. PCV refresh
    *If there are any errors in anything I've shared, extra information that should be added, or crap that I just plain got wrong - please do not hesitate to correct me on it. This is meant to be a resource for B5'ers, so your input is appreciated.
    i know the simpler, the better and all, but what benefits does this bring? i mean i will end up performing this mod so dont take this as hate or anything. i am just curious if there are economic or power benefits to this mod as well as simplicity/clean engine bay.
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
  12. #92
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    The main reason I did it was so I didn't have to mess with any of the pcv stuff when I changed my tip for a larger turbo. It is also less stuff to replace when t eventually deteriorates.
  13. #93
    Jun 30 2008
    Erie, Pennsylvania
    - Less points of failure.
    - Less blank staring at the engine bay when you're trying to find a vacuum leak amongst 914 hoses, clamps, and check valves.
    - Less to replace if you want to renew "everything".
    - Less to put back on if you took it all apart.
    - Less crap to rule out when it's not running properly (I mean...as if THAT ever happens).
    - Etc, Etc.
  14. #94
    Veteran Member Three Rings ipop07's Avatar
    Jun 09 2009
    Kitchener, ON
    - Etc, Etc.
    Been meaning to write and thank you for the work you put in getting this thread together. It literally saved my ass.
    First of all, the people who worked on my car cut stuff out and never replaced stuff with resistors or anything, my car was running like shit and been getting codes. There was so much crap that i didnt even know where to start to troubleshoot.
    This helped me cut out the unnecessary stuff and clean up the engine bay a little and then made it super easy figure out where the issues were and how to fix them...
    Definitely worth the time, especially if you have (like me) big turbo and a bunch of work done to it, this stuff just gets in the way really..
    '18 Golf R / '21 Atlas R-line / '09 A4 Wagon
    instagram: ipop07
  15. #95
    Veteran Member Four Rings Murph_129's Avatar
    Dec 15 2014
    Indianapolis, IN
    Quote Originally Posted by Rodgman15 View Post
    Quote Originally Posted by 99jimse View Post
    Here's a link to this guide in PDF format that I made.. Enjoy! :)
    Also if the file source above doesn't work. You can get it here
    -Murph
    11' A4 2.0T Quattro Premium+ Phantom Black - IE Stage2
    01' A4 1.8T Quattro Sport Silvaro - DazTuned Stage2 - SOLD
    IG: smurphy_iii
  16. #96
    Jun 30 2008
    Erie, Pennsylvania
    Wow, Steve. That's really nice. I'm honored that you took the time to put that together. Thanks!
  17. #97
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Should edit that into the original post, walky, I like it also.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
  18. #98
    Veteran Member Three Rings MarcMiller's Avatar
    Feb 22 2011
    Philly215
    I wanna do this but being from PA i don't think i'll pass my readiness part of my inspection.
  19. #99
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    Quote Originally Posted by MarcMiller View Post
    PM me I will explain my setup to you.
  20. #100
    Established Member Two Rings chaoticdopey's Avatar
    Sep 07 2015
    North Hollywood , Ca
    so mr walkie talky is this the same procedure for the B6 that already has a write-up or is there different hoses? Im in california and i want to delete all of the evap/sai system and im not worried about smog as i had it smogged with the GIAC X Tune and a lean condition with no cat and no check engine light and the damn thing passed, suprised the hell out of me, being in california they dont put cars 2000+ on the rollers, they just hook up their obd2 scanner and it checks the sensors and to make sure there is no cel on, but ya takes 2 minutes to smog your car now as long as its 2000+...
    2001 Audi A4 1.8t
    Catless DP
    Full 3'" Custom Exhaust
    XS-Power Tubular Manifold
    Kompresssed STG 2 Tune
    Stock k03s Turbo
  21. #101
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by chaoticdopey View Post
    B6 is different, and I think there's a similar DIY thread in the B6 section.
    You won't be able to delete EVAP & SAI and still be able to pass the OBD2 readiness check... Removal of either system (let alone both) will trigger the CEL unless you have a tune that codes them out and allows readiness to set properly.
    You definitely got lucky on the visual inspection portion, that they didn't fail you for having no cat.
  22. #102
    Sep 07 2015
    Quote Originally Posted by MetalMan View Post
    can i delete every thing without any drivability issues? not worried about cel as i will get that taken care of latler, i just would like to know what on the b5 i cannot remove that you can on the b6 as i just got the xspower headers and the combi block off plate...
    2001 Audi A4 1.8t
    Catless DP
    Stock k03s Turbo
  23. #103
    Apr 02 2013
    above top secret
    Can I ask if you remove the SJP lines would you loose the the few stroke of vacuum assisted brakes when the car is turned off?
    Anyway very nice write-up!
  24. #104
    Nov 04 2012
    Reno
    no, when I shut off my car I still have vacuum in the booster, and I hear it hiss when I disconnect it.
  25. #105
    Apr 02 2013
    above top secret
    Thanks. I wonder how that works since the brake booster no longer connects to the vacuum reservoir?
  26. #106
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    The brake booster has its own check valve, so it will retain vacuum for days without the engine being on if the lines and check valve are in good shape.
    Originally I removed the SJP in my car. SJP's whole purpose is to provide extra vacuum assistance to the brake booster when there is little/no vacuum in the intake manifold. Somewhat recently I reinstalled the SJP in my car and have noticed that braking force has increased in the scenario where I get on the brakes quickly after just getting off the gas. Previously the brakes would feel a little "flat" until vacuum was restored in the intake manifold.
  27. #107
    Established Member Two Rings 2stroke's Avatar
    Jun 01 2009
    SWEDEN
    Question
    Emissions system deletes on the VW/Audi 1.8 Turbo Engine.
    Goals:
    Get rid of "all those check valves, after first understanding what they are for.
    Note 1:
    There are differences in the vacuum and PCV systems between almost every year of the B5.
    Note 2:
    2. Suction Jet Pump
    3. Vacuum Reservoir (constant vacuum source)
    4. Evaporative Emissions
    I have a ( 2002 ) 1.8T ( 150 Hp )
    Engine Code: AWT ( European engine code )
    I would like to remove the SAI system because my SAI pump is seized.
    I would need some help with how to do this without getting error codes
    // Regards from Sweden.
  28. #108
    Nov 04 2012
    Reno
    Tune + block off plate + plug TIP
  29. #109
    Jun 01 2009
    SWEDEN
    Quote Originally Posted by RENOxDECEPTION View Post
    1. Can you elaborate on your answer in detail !
    2. What is TIP ?
  30. #110
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by 2stroke View Post
    2. What is TIP ?
    Turbo inlet pipe, airfilter intake tube.
    1998.5 A4 1.8TQM My Build
  31. #111
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Walk, in your PCV refresh list, the first link is broken. What was that link directed to? I see the second link is the T and the third link is the PCV Check valve, but what's the first link?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
  32. #112
    Jun 01 2009
    SWEDEN
    PCV Refresh
    Application Notes:
    The parts I show here are applicable for 2001+ only.
    As the vast majority of the interest here is the “PCV” system,
    I thought I should address what I did to freshen mine up “while I was in there”.
    When I pulled all this crap out, it was in quite bad shape:
    All busted up and leaking and such.
    Many people have decided to remove the PCV valve and the manifold connection to the PCV system and just vent it to atmosphere.
    I feel that is certainly applicable to high horsepower/Big Turbo cars.
    With a stock turbo, it is my opinion that simplifying and keeping the stock system working well is the best route.
    Quote Originally Posted by gtsingh91 View Post
    You will find all the necessary parts at 034motorsports.
    I have bought a complete PCV silicone hose kit including billet PCV check valve from 034Motorsport.
    ( https://store.034motorsport.com/volk...cv-system.html )
    Great Product
  33. #113
    Active Member Two Rings WyGuy1.8T's Avatar
    Oct 01 2012
    Built B5.5 passat, 92 Corrado SLC
    Pittburgh, Pennsylvania
    Old thread, but I figured it would be the best place to post my question. I'll post a picture below of my current catch can setup. I have the 034 silicone pcv kit, capped off the lower nipple off of the VC, and ran the Y coupler as normal. Would be make sense if I just ran a line from the block straight to the catchcan, then from the catchcan to the TIP, and just put a breather filter on my VC? Note: this car is not my daily and soon will be a stroker with a gtx 3076r and I want to simplify as many things prior. I already deleted a/c, SAI, and the SJP. I decided to leave the n249 and Evap in.
  34. #114
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by WyGuy1.8T View Post
    I'm sure othesr will chime in. I believe if you are routing the crank case to your inlet pipe and leave the valve cover vented to atmosphere, this would potentially allow unmetered air to enter the inlet pipe. If you are running mafless this would not matter.
  35. #115
    Nov 04 2012
    Reno
    photobuckettttttttttttttttttttttttttttttttttt, you ruined the internet!
    Anyone have the images to rehost on imgur? walky?
  36. #116
    Jun 30 2008
    Erie, Pennsylvania
    Yes. All the images are still there. I just need to rehost them all. Then relink them all. For all of my posts and DIY's. This will roughly take me the rest of my life. Thanks, Obama!
    I've gotten several requests for this DIY in particular, so I will start with this one. Keep bugging me via PM about it and I will get around to performing the 1 million+ clicks it will require to do this. lol
  37. #117
    Nov 04 2012
    Reno
    Imgur is bae ;)
  38. #118
    Jun 30 2008
    Erie, Pennsylvania
    OK, so I didn't relink all the images, but I did use the "embed fix" plugin (while it's working) to create a PDF of the page with all the images. Here is that link:
    >> PDF VERSION WITH PHOTOS - CLICK HERE <<
    *Special thanks AZ users bajohnson1984, Chucky1 and the rest of you guys for bugging me until I did something.
  39. #119
    Nov 13 2016
    SC
    Thank you kindly for doing this.
  40. #120
    Jan 28 2018
    will the removal of the suction jet pump throw any codes?
