Results 1 to 6 of 6
    Oct 18 2010
    Edgewater, NJ
    Anyone ever remove seized swaybar end links?
    Tried to install my OEM RS6 rear sway bar tonight but hit a snag with passenger end link. The top nut came off no problem, but the bolt spins with the bushing. Nothing I tried worked, PB Blaster, screw driver in between, hammering the bolt loose...etc. Anyone else had this problem and get the end link off?
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    I've not actually looked at these on my car yet, so what I say might be way off base. However, if the bushing is rubber, maybe burn it out with a small torch and get new end links. Again, since I've not actually put eye's on these parts I could be way off base. But this is how I've removed seized bolts from rear shocks on cars before.
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    ^end links are made of plastic.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Oct 18 2010
    Edgewater, NJ
    I thought about burning off the bushing which is enclosed in a plastic surround. However the link is so close to the rear CV boot I'm sure I'll melt that off too if I tried
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Torch. Had to do it when I put RS6 sways in. I had metal links on mine. I ended up ripping the links off of the bushings taking the twisties a lot. Replaced with the plastic ones and didn't have problems after that.
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Oct 26 2010
    NW Georgia
    get a chunk of ceramic from a local pottery shop and used metal ties to affix it in front of the CV boot.
    William
