I didn't check either but it seems like you got the right idea.
Except, the big brown wire needs to be grounded at the VC (because that's where most likely you will ground the coils).
The ATW/later cars had 4 sep grounds coming from the ECU harness. This, in my view, is equivalent to the ICM big fat ground wire. So, essentially you have this ground (I've seen referred to as TTL), then the grounds for the coils themselves which typically end up on the VC in the same spot on later cars. Jeff, in his DIY, grounded all at the same point, and till this day, he still recommends doing this for simplicity.
He crossed the wires because thats how it corresponds to each respective cylinder. You will see this on the schematic he posted as well.
I'm not using the ATW/1.8T harness except I'm using 034's replacement harness designed for the B6. There are 4 extra pins for grounds. I will just be routing the fat wire and directing into those 4 pins. Everything else is the same. For ref, check here:
http://www.034motorsport.com/docs/1....structions.pdf
I'm referring to pin 2 collectively.
pin 4 is what you see grounded on the VC typically from the factory. pin 2 comes from ECU and where I will be connecting the existing ICM gnd wire.
