Page 2 of 7 FirstFirst 1234 ... LastLast
Results 41 to 80 of 249
  1. #41
    Veteran Member Three Rings CamrideA4's Avatar
    Jan 05 2011
    Raleigh, NC
    I just ran some logs:
    https://spreadsheets.google.com/spre...ptenc&hl=en_US
    Feel free to tell me if they're good or not. I know I have much less timing retard than I had before despite the temps. I was asked to log these groups from the thread on VWVortex, I don't know how to interpret the O2 or Injector timing stuff.
    2001.5 A4 1.8TQ Tiptronic - FrankenTurbo F4 - 440cc Green Giants - TT225 MAF - Borla exhaust - ST Coilovers - Malone Tuning - Garrett FMIC
  2. #42
    Feb 26 2010
    NOVA
    i should add i did buy that jetta harness, and i removed the 5th connector, and pretty much followed DIY. i removed a bit more wire but the result was the same. i got the new coils installed
  3. #43
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Quote Originally Posted by Jason@ECSTuning View Post
    OK, I just didn't want people to get the wrong idea that all that would need to be done is remove the 5th cylinder wire.
    With how inexpensive these harnesses are I just might have to pick one of these up myself!
    Jason
    You can also just buy an ATW harness to switch your coils to the newer style, then buy the 2.0 coils and adapters to make it work for an AEB. I know Tomat just bought a new harness instead of hacking up his old one to switch and delete the ICM as well.
    MontrealAudiClub
  4. #44
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Quote Originally Posted by terraflata View Post
    I might have a ATW harness availible in the next few weeks. Will be parting out my car soon.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
  5. #45
    Oct 02 2006
    Wadsworth,OH
    Awesome good info!
    Jason
  6. #46
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Buddy of mine put these on his GT3071 GLI and didn't notice a difference he thought I was lying. I said what are your plugs gapped to? He said he's running NGK Laser's or some shit that can't be gapped. I told him to come to my house because I have a couple sets of BKR7E brand new so we can try these out, so I gapped them to .040 and he went and did a pull....... He said big difference, smile on his face and a thumbs up. He bought the Red FSI coils for reference.
    My parts aren't here yet and I have to drop the block off to the machine shop but I'm about to order these with a few other things.
  7. #47
    Aug 04 2011
    OHIO
    ok those threads have to be super confusing. Can someone shead some light on switching from a aeb with icm over to 2.0t coils what all is needed?
    Can I use the ecs tunning auto coil pack wiring replacement and delete the icm then swap over to 2.0 coils with hold downs or what? Sorry this is not really clear and I read almost all 11 pages of crap over tehre and its not really cut and dry. Thank you for the help. I really would like to delete the icm but dont know what all parstsI am going to need to make this swap happen cleanly and its not something you can really start on and not have all the proper wiring etc to complete and be able to stop halfway in between you know. TIA
  8. #48
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    Have you looked at the audigeeks/Jeff's DIY?
    That's pretty much all you need.
    Ensure you have suitable heatshrink (size and temp!), be prepared to mess around with grounds. There doesn't seem to be much clarity on grounds but the easiest way is to just bridge everything and ground it at one point. But looking at the ME7 diagram will help.
    For example, I will be using the known ground point at the VC(pin 4 from each coil) as well as reusing the ICM ground to pin 2 from each coil. You'll see what I mean if you look at it and compare.
    *my idea may not work though!
    Wiring/splicing the cyl specific trigger and 12v constant should be straight forward.
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
  9. #49
    Established Member Two Rings SR-71's Avatar
    Jul 20 2010
    Burnaby, BC
    Quote Originally Posted by viceprp View Post
    SEARCH!
    LOL, Winston.Podi did a thread and gained 15whp/15ft-lb on a b6 gt2871 on 18psi.
    I'll be either running these or Aem pencil coils
    Nope, Winston has been running Okada coilpacks for a long time, way before these came out.
  10. #50
    Aug 04 2011
    OHIO
    gmx sorry but that again like others was in no way clear at all esp saying my idea may not work though how is that supposed to help man?
  11. #51
    Mar 01 2008
    '12 1M
    Sydney, AU
    You probably shouldn't do this.
    12 1M
    3090lbs
  12. #52
    Jun 30 2008
    Erie, Pennsylvania
    ^Truth. GMX's description is perfectly understandable if you have any concept of what you are doing here. There are 2 grounds for each coil.
  13. #53
    Aug 04 2011
    OHIO
    I know what needs done but again people say o you can use this replacement harness from ecs and then no you cant you have to mod it. Then ground these two wires through ehre but I dont know if my idea will work doing that. So For the average person who is not that expericend with it cant really have a clear understanding of what needs done. is that other write up good. yues very good but there ahve been mixed results and people saying one thing work and another doesnt and try this guess at this. not very helpful.
    I just thought with the support of major companies on here there would be some cut and dry answers. I called ecs as I live not to far from them and they are very clear over the phone etc. So I would suggest for anyone else that wants to do this call them first and dont get wrapped up and confused at the different ways/ tricks people on here are TRYING.
  14. #54
    Sep 12 2008
    South Central PA
    I found that the MkVI coils with Bosch F5DP0R spark plugs work the best on my car. I've ran 34psi, straight pump no meth, and had zero misfires.
    Bosch FR5DTC's worked great also. and their way cheaper than the F5DP0R plugs
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
  15. #55
    Mar 01 2008
    '12 1M
    Sydney, AU
    I'll be giving FR5DTC a shot too.
    Are you doing the conversion on your bro's B5, Dan?
    12 1M
    3090lbs
  16. #56
    Jul 20 2010
    Burnaby, BC
    Quote Originally Posted by Dan[FN]5857 View Post
    Flat-top MK4 coilpacks are best bang-for-the-buck when it comes to making power.
  17. #57
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by BTA4Q View Post
    I'm sorry there wasn't a step by step guide for you to follow. However, you must understand that this an electrical modification to the car that not even a dealer would do for you. The modification is not complicated, but it is detailed. Personally when I write DIY's I try to be detailed, but sometimes you can't lay it out word for word, splice for splice. There are multiple VIN splits on the B5 chassis, and multiple different donor harnesses you can use for this that require different and specific modifications. If I were to tell you for sure "the blue wire to the pink wire", and the Passat harness you got from a junkyard has a few different colors, what am I supposed to do about that? You plug-and-go and fry your ECU, then I'm obligated to feel bad about it because I told you the step-by-step.
    FWIW, I have successfully replaced the coil pack harness on an ATW with this harness (which I mentioned earlier in this thread):
    http://www.ecstuning.com/Flyer-Sprin...ance/ES477951/
    It worked out great, however none of the colors matched up, so you just follow the factory wiring diagram and double check your work. Car runs fantastic on MKVI Cali coils. I did take lots of photos, so I'll be doing a writeup on this at some point.
  18. #58
    Jun 15 2010
    ny
    here is a good diy for the aeb motors. http://www.passatworld.com/forums/42...elete-diy.html
  19. #59
    Sep 12 2008
    South Central PA
    Quote Originally Posted by gmx View Post
    yes, I'll be swapping his coil harness for a 4 pin, then I'm going to put my bolt downs with FR5DTCs in his car. figured that would be good since my bolt downs don't even have 200 miles on them and the plugs don't even have 150 miles on them haha
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
  20. #60
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    So how do know the optimal gap?
    For instance, I bought some new bkr7e's tonight, and couldn't decide what to gap them to for the best result... I have 2871r and oem coils (not 2.0) what can I log to find the optimal gap? Or what do you guys recommend I gap it at?
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
  21. #61
    Feb 03 2009
    So. Jordan
    I didnt read through all the posts, so i hope i dont get flamed if its been posted befor. But we're lucky enough to have IE here locally in SLC.
    http://www.intengineering.com/Integr...02226-1-2.html
    http://forums.vwvortex.com/showthrea...pter-Review-**
  22. #62
    Sep 12 2008
    South Central PA
    start at .035.
    work down by .003 if you experience soft misfires under full boost/load.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
  23. #63
    Sep 22 2008
    Minnesnowta (Roch)
    start at .035.
    Thanks, ill try that. Sorry for going off topic a bit. I love this thread. Hopefully I have enough spare cash to swing this mod soon.
  24. #64
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Guys,
    we have been asked to build some harnesses for AJL/AEB folk. How many of you would be interested in this?
  25. #65
    Jul 27 2010
    Queensland, Australia
    Pricing?
    If price is right, I'm in, and will spread the good news to other AJL boys here.
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
  26. #66
    Veteran Member Three Rings G-low's Avatar
    Feb 13 2004
    Ct
    interested $?
    97 1.8tqm T3T4
  27. #67
    Jun 29 2010
    Ottawa
    Quote Originally Posted by Issam@INA View Post
    Guys,
    Pricing? I would be interested.
  28. #68
    Feb 26 2006
    Earth
    For the entire kit i want it to be below 400 for the coil packs , adapters and harnesses
  29. #69
    Senior Member Three Rings BirdTurbo's Avatar
    Dec 19 2009
    b5 a4 qtm
    Arlington
    I would!
  30. #70
    Sep 12 2008
    South Central PA
    I have a brand new set of Issam's coil pack "adapters" or "spacers" or whatever you want to call them. Still in the sealed plastic bags. If anyone wants them, PM me. They're just taking up space on my desk lol.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
  31. #71
    Established Member Two Rings silvera4q's Avatar
    Dec 20 2007
    2001 Silver A4 1.8T
    Cincinnati, Ohio
    Im def doing this this week. Walky where did you order the red coils from?
    2001 A4 1.8t quattro, Mods:GIAC-X tuned, Short shifter, apr snub, custom CAI ,cat back 2.5" ss exhaust, custom carbon fiber interior parts,VDO Boost and Oil Pressure Gauges, yellow fogs
  32. #72
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by silvera4q View Post
    Genuine Audi Parts (.com) has the best price on the coils - same price for the Red ones and the Black Cali coils, it was $15.12 each. $12 to ship 8 coils to PA, which makes it still a better price than going to my dealer parts dept. Make sure to select Audi, not VW or you won't get that price.
  33. #73
    Dec 20 2007
    2001 Silver A4 1.8T
    Cincinnati, Ohio
    Thanks. I orded a set along with the spacers. Got the spacers in like 3 days. Now just waiting on my coil packs!
  34. #74
    Feb 26 2006
    Earth
    There is more discussion in the B6 forum guys. This would be better suited to continue over there no?
  35. #75
    Sep 22 2008
    Minnesnowta (Roch)
    Guys - i have 034IIc standalone tune, and i increased my gap to like .035ish (from .028) and i noticed a nice gain. I dont have 2.0 coils, but i think my spark might be super strong with the IIc. Is this a bad idea to run this big of gap with stock AEB coils? I havent noticed any blow by or anything, and seem to have better low end response
  36. #76
    Jun 30 2008
    Erie, Pennsylvania
    I thought stock AEB coils were the weakest of the bunch (and therefore the most reliable). It certainly works the coil a bit harder, but you can always upgrade later right?
  37. #77
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    does anyone know if the 2.0L coil packs fit into the AGN valve cover? as they wouldn't be able to be bolted down
  38. #78
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    When it comes time to purchase the ATW harness for my AEB, is it better to wire it in where the ICM is located, or should I follow the harness back further and replace as much of it as possible? Looking at the schematic on the DIY for the swap is a bit confusing, so Ive got a few questions, and wiring match up to what I got on paper. If it looks wrong, hopefully someone can correct me, or verify that its right.
    On the AEB schematic, it shows the wires before the ICM being crossed to the wires after the ICM to the AEB coils. On paper I took the wires before the ICM and matched them up the wires directly to the ATW harness. Here is what I have wrote down.
    Gray/Yellow from AEB to Brown/Black on pin 3 #4 ATW coil
    Yellow/Gray from AEB to Gray/Black on pin 3 on #3 ATW coil
    Red/Gray from AEB to Gray/Brown on pin 3 #2 ATW coil
    Green/White from AEB to Gray on pin 3 #1 ATW coil
    Black/Blue from AEB to Red/Green on pin 1 of all 4 ATW coils
    Brown and Brown/Yellow on pins 2 and 4 on all 4 ATW coils are grounds.
    The big thick Brown wire from AEB that supplied ground to ICM is no longer used.
    Hoping all that makes sense, and is right. Ive stared at the schematic for a while in the past and just couldnt get it, but hopefully I do now. On the grounds, is it better for them to have their own grounding points, or just one main point?
    1998.5 A4 1.8TQM My Build
  39. #79
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Can anyone shed some more light on the subject, and clarify my last post? It would definitely help out those like myself who have the ICM and want to upgrade to the 2.0 coils.
  40. #80
    Jun 30 2008
    Erie, Pennsylvania
    Yes, you've got the right idea. The 4 wires from the ECU need to connect directly to each of the 4 coils. No need to patch it through at the old ICM location if you can cut them before they get there. As long as you know which wire is for what cylinder, you're golden. Please note, that I did not check the wire colors in your above post. Just confirming your method.
