Quote Originally Posted by Lambda13 View Post
Except that using a Magnum condom has negative side effects. Like having to go fishing and then making them take the fast way down a flight of stairs. The TR11 fit perfectly under the crash bar and took minimum modifications or maneuvering to make it fit.
Under the crash bar or behind the crash bar? There's no way it fit under it, the TR8 is 7.8" tall and barely fit under mine, compared to 11" for the TR11. And with the 3.5" thick core of the TR8 compared to only 3" of the TR11 the TR8 is going to have more surface area exposed to moving air than the TR11 since the portion of it that's mounted behind the crash bar isn't really getting much, if any airflow at all.
Then you have to take into account the fact that it's a larger volume container that has to fill with pressurized air before it gets to your combustion chambers, decreasing your pedal responce.
