Originally Posted by
slowone11
So at stop light idle the iat is about 10 over ambient temp. Under load it drops to either even with ambient or a couple degrees under. I tried to record it but there was to much glare. It was 90 out and cruising temps tend to be about 5-10 degrees over ambient depending on what my rpms are. If im in 6th and not on throttle its 10 over....if im in 5th and light throttle its 5 over. Man i love seeing these temps. With my stock ic i was getting upwards of 120-130 at cruising in 90+ degrees ambient.
When stopping at a light, the IC isn't providing any cooling and your IAT should go significantly up. If you P3 was reading ambient, it could go up at a stoplight because of the extra stagnant heat from other cars and the road surface.
I will post my log from this am. Air temp was 75-77 and my IAT on the highway was around 82 then jumped to 108 when I parked and let the car run for a couple of minutes.
RPM is on the right axis.
Speed and IAT are on the left axis
The temp in my garage was 89, and I had the car running a few minutes before logging (with the garage door open)
