Results 1 to 40 of 259
Threaded View
  1. #11
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Yeah the bolt on the driver side just above the axle will be longer then the others, long like the starter bolts.
    It is longer because the spot that it goes thru on the bell housing is thicker vs the rest of the holes on the bell housing. You will notice this once you get the transmission down or look at the manual bell housing.
    Picture taken from Chris's thread.
