Results 241 to 259 of 259
Threaded View
    Veteran Member Three Rings Papa_Dios's Avatar
    Jul 01 2010
    fl
    Another 5 Speed swap
    After having the car for a few months tranny took a dump on me which meant 1)Sell the car (for basically nothing) 2)Deal with the hassle of a part-out 3)Drop in another TIP tranny (uhhhh no) 4)Do some research and swap it out for a 5 speed. I already have everything ordered and I will update with pics as things arrive. I am using biketsais' guide for the most part mixed with a little commmon sense. His guide is A+ and I will attempt to supplement it a bit.
    With biketsai's help I was able to find out that my rear diff (4.11 gearing) needed to be swapped out in favor of the 3.89 (from a 5 speed). You should do this at the same time as the tranny since everything is already out of the way (exhaust/driveshaft etc). You will also need a driveshaft from a 5 speed. While I don't know 100% if it is necessary to swap the diff it's better to be safe than sorry.
    Everything I have is coming from a 99.5 with low miles. I'll post a list of everything I purchased and from where later on. I will also post up the steps I took (starting with dropping the diff and driveshaft AKA d/s). The dropping of the exhaust is pretty straight forward (so if you can't handle that aspect I would reconsider doing this swap)
    For now here are a couple of pics of what has come in so far.
    Brand new 5 speed axles (front) I dont think rears are necessary-correct me if I'm wrong.
    Diff and d/s
    More to come soon......
    *Sorry mods move if necessary*
