Question for the guys who have done the timing job:
Which cylinder is at TDC when the crank lock pin is in place?
Here's the reason: I'm working on my 2005 A6 4.2, which is pretty much the same engine. It bent the exhaust valves on the passenger side, when the cam chain tensioner decided it wanted to let loose with its plastic guide, throwing it into the exhaust cam sprocket, making it skip a tooth. (Seems to be one of the more common failure modes).
Heads resurfaced, valve job, new valve seals, new timing components, bolts, etc. Last night, I pulled the plug on the pan to put the 3242 crank holder in place, with #1 TDC. Except it didn't lock it in place. Huh. Yep, seated all the way. OK. Thinking I have the number 1 confused (passenger side, front cylinder, right??), I rotate the engine to what I thought was number 5 (drivers side, front). No deal there either. So I rotate to what I think is #8 TDC (Drivers side, rearmost cylinder), and sure enough, pin goes in, locks crank properly. Nowhere else.
The Bentley manual really is no help, as I can't find details -anywhere- except the term 'TDC ignition timing', for which I can't find a definition.
Based on the camshaft positions, this -seems- correct, as the cam lobes indicate that #8 is at TDC, just beginning the power stroke, and #2 is at TDC, just beginning the intake stroke.
Question is, is this correct?
Thanks for any wisdom,
Darryl
