Results 1 to 15 of 15
    Established Member Two Rings JHaag13's Avatar
    Dec 09 2008
    2005 Harley Dyna Wide Glide
    Grand Forks, ND
    negative what???
    My B7 is sitting outside on this cold weather up in Grand Forks. I have a few questions about oil stabilizers and oil for being in the cold. I'm running Motul sae 5w40, I let my engine run for a good 10-15 mins at the minimum before lifting off. With that being said I was curious if people are running oil stabilizers to help with the cold. Reason being my car was shaking last night and making funky smoky smells directly out of the exhaust. I just put a full tank of 92 octane in and it seems to be sounding better... I let it idle for a good 20-30 mins after and filled it and no studdering. But, last night she died on me right as I pulled into my driveway. So would the reason be that my car was shaking cause I had a quarter tank left and my fuel line was freezing? Bad oil? Coil? There is no check engine light. I'm going to get my oil changed today or tomorrow so hopefully I can get some good feedback on if oil stabilizers will help. Thanks..
    Established Member Two Rings Ghostrider's Avatar
    Jan 31 2007
    86 Alfa GTV6, 91 Toyota HDJ80 Land Cruiser, 2005 Miata, 2020 Miata, and Lexus GX 460
    Charlotte, NC
    I don't use oil stabilizers here in NE Missouri, but it does get cold- not as low as you do. However, I would suggest you go to a thinner weight oil, try 5W30.
    Dec 09 2008
    Grand Forks, ND
    Yeah I was pretty amazed if my gas line was already freezing at that point. I had a good 100 miles to go!
    Established Member Two Rings Boushard's Avatar
    Nov 06 2010
    B7 S-Line IW Mt QT 2.0T, 2003 Toy Echo(girlfriend car)
    Drummondville, Québec
    DOn't have stabilizer Here in Quebec and it's pretty damn cold these day.
    Warm up the car a couple minute and drive it bellow 2k RPM until the temps warm up and everything is fine till now, touching wood!! Got a bad start Monday, here is the story :
    http://www.audizine.com/forum/showth...?highlight=CEL
    Like ghost rider said you can go with more fluid oil grade but more 0W40 not 5W30. If you go with the 30 at normal temps the oil will be more liquid that's not what you want. You want fluid oil at cold temps that's what the 0W grade do!!
    Anyway keep us updated with the oil change!!
    Senior Member Three Rings eccarlino's Avatar
    Oct 06 2010
    as far as oil, would you saw 0W40 in the winter, 5W40 in the summer ?
    2014 Audi S5
    APR Stage II | APR Pulley | P3 | AWE Ex. Black Diamond 102 | AWE Non-Res DPs | RocEuro | RS5 Grille | EuroGear CF Lip | H&R Coilovers | H&R Spacers (10f/15r) | Gloss Black Roof | 15% | Sport Diff | Nappa | CF Inlays | Manual | Glacier |
    http://www.audizine.com/forum/showth...r-14-S5-Modded
    Dec 09 2008
    Grand Forks, ND
    looking like maybe an oil leak under the passenger side.. i saw some oil on top of the passenger side of skid. any suggestions? valve cover? seals?
    Audi A4 B7 Dolphin Grey Quattro, APR Exhaust, 034 HFC, 9500i Escort Radar Hardwired w/ Remote, KW V2 coilovers, GIAC x-chip, Forge Diverter Blow-off valve w/ adjustable spacer, Alpine double din, TypeR 12", Polk dxi components, LEDs, APR Snub Mount, APR Carbonio, 35mm Front Sway, 28mm Rear Sway, Dayline Headlights 5000k, S-line converted, converted titanium, Sti coilpacks
    Established Member Two Rings Satyroi's Avatar
    Jun 24 2009
    2018 Audi A4 PPlus/Sport/Blk Optics | 2007 Audi A4 2.0T Ti 6MT (RIP) | 2002 VW GTi 337
    Philadelphia, PA
    Check your PCV valve. Could the source to your problems?
    Nov 06 2010
    Quote Originally Posted by eccarlino View Post
    Probably try this at the next oil change, but yes 0W40 in winter and 5W40 in summer!!!
    Dec 09 2008
    Grand Forks, ND
    can the pcv valve be updated to the TT if theres any difference? I've had the pcv go out on me once already so this is probably it once again..
    Dec 09 2008
    Grand Forks, ND
    going to check my catch can.. lol that may have some answers as well
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    It's not clear to me that your problems have anything to do with the oil you are using. Also agree that for easier starting a 0-40 weight engine oil would be the way to go in your climate for winter and 5-40 in summer. Stick with the 40 weight though because the cold weather will not much affect the engine operating temperature when warmed up. I've heard of gas and/or diesel fuel stabilizer but can't imagine that a oil stabilizer would be recommended. also, idling a car for more than a few minutes is not recommended in any weather conditions and I'm not sure I understand what you are trying to achieve with these extended idling anyway. Easy driving after a 1 to 2 minute warm-up should be sufficient. Unless your gas had a tremendous amount of moisture in it I doubt the gas line was freezing, especially after running for a while. A bottle of gas line antifreeze (mainly isopropyl alcohol) should fix that problem if it is still a concern after fixing your other problems. Doesn't sound like a big problem but good luck sorting it out.
    Veteran Member Four Rings Kubus's Avatar
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    I don't use any stabilizers here in Quebec either. Was -22C (-8F) here this evening and it started fine. Still running 5W40.
    Nov 06 2010
    Quote Originally Posted by Kubus View Post
    You probably had hard cranking too, but start the first time!?!?!
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    Quote Originally Posted by Boushard View Post
    First time, about 3-4 seconds of cranking. But starts like a champ.
    Nov 06 2010
    Same thing here, but died after 20sec with the battery icon, restart and all good!!!
