Results 1 to 20 of 20
    Established Member Two Rings Boushard's Avatar
    Nov 06 2010
    B7 S-Line IW Mt QT 2.0T, 2003 Toy Echo(girlfriend car)
    Drummondville, Québec
    Thumbs down Edit: Boushard's B7 Problem(26-01-11)
    I got my first CEL tonight and I want to erase it
    Start the car and it feel like running on 2-3 cylinder, let it run a minute nothing change and a solid CEL light up. Stop the engine, wait and restart, still running poorly with the solid CEL and 30sec later flashing CEL. I turn off the engine and call the road assis.
    After a little discussion with the guy to plan the towing, I decided to give it another try, start the car and it running fine but still have the CEL on, make 20Km and everything is normal.
    There is a way to clear the CEL without Vag or another diagnostic tool, like remove the negative pole for a while and that's it!?!
    I think the CEL was cause by some condensation in my gas tank and the engine had take a little drop of water so now the water is "gone" I think everything is OK!!
    Jul 14 2009
    Pasadena
    Quote Originally Posted by Boushard View Post
    i have a hugggggge feeeling one of ur coilpacks is going out. go to the dealership for the recall on them
    IG: @matthewee
    Veteran Member Four Rings arce909's Avatar
    Oct 08 2008
    So-Cal
    congratulations!!! It's the first of many more to come...
    B7 A4
    Nov 06 2010
    Quote Originally Posted by itsmatt33 View Post
    I bought the car 2months ago with the Audi Certified Warranty (2years 20000km more), they should have done every recall and TSB.
    The car start after a few turn every time, even after that, so the coil pack should be the problem, I think!!
    So there is no way to clear the CEL without the stealer or a diagnostic/VAG-Com tool!?!
    Quote Originally Posted by arce909 View Post
    Thanks but that's not very helpfull
    Oct 16 2008
    South Florida - Ft Lauderdale
    No, you need the Vag Com
    Phil
    Veteran Member Four Rings glissoar's Avatar
    Oct 16 2010
    2010 Jk Unlimited
    virginia beach
    I have heard that when you go APR tuned you can clear CEL codes with a program they offer, I have APR stage 1 but I haven't really done the research to see if thats true or if you have to buy a program upgrade to get it.
    Nov 06 2010
    Thx Phil!!
    Will call a local shop claiming Audi/Volks specialist, will see if it's true!! :P
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    There is a reason the CEL comes on, don't just clear it until you read it.
    Nov 06 2010
    Quote Originally Posted by B72.0T View Post
    By clear it I mean read the code after I can clear it!!
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    I have had the same thing happen about 3 times this winter. There's a breather that freezes up on these cars if its really slushy or just gets damp and once you turn the car off it gets cold and freezes. When I've had it happen, I just let the car idle (spitting and popping and what not, car shakes a little) for about 5 mins (pretty much until the CEL turns on) and then turn it off and let it sit for another 5 minutes so the heat that was generated at start up can thaw out the breather. Start it back up and no problem. Then head over to autozone and have them clear the misfire codes. I took it to the dealer the first time around and they replaced the breather but it happened again the very next day so I'm pretty sure there's not much one can do about it. Just depends on how warm out side and how damp the breather gets followed by drastically dropping temps after the car is turned off. I thought about having the dealer look at it again but I figure since it happened the very next day after getting a new one there isn't much they can do about it. I'm no expert though. Just thought I'd chime in with my experiences.
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
    Nov 06 2010
    Good to know, I was thinking that is because a take the car in a heated garage with a near empty tank and the outside temps was -20c!! But the freezing breather sound good!!
    Do you remember the exact code of missfire that pop, just to inform myself when I take the car at the garage tomorrow for clearing the CEL!!
    Nov 08 2010
    I don't remember the exact code's but I know that I had misfires on all cylinders.
    DTM_B7_S4
    Nov 06 2010
    Quote Originally Posted by RAudiB7A4 View Post
    Roger!!! ;)
    Thanks for the op
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    I had to laugh when I saw that
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Established Member Two Rings daudic's Avatar
    Jul 06 2009
    2007 A8l. 2003 TT Roadster. 1985 Yamaha Vmax!
    Lancaster/Ohio
    Quote Originally Posted by glissoar View Post
    APR stage 1 cel clearing can be done if you pull the cruise control toward you and hold it for 5-10 seconds. At the same time, turn the key to ON but don't start it until the dash light flashes.
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    lmao x2
    Nov 06 2010
    The CEL was Off when I drove to the garage so took it anyway just to be sure.
    Result:
    -Random Missfire 000768
    -MissFire Cyl.1 000769
    -MissFire Cyl.2 000770
    This one was a surprise
    -Pressure drop between turbo 004759
    For the Missfire this should be a water puff that's it, the plug are clean, except one with little dirt on the porcelain!!
    For the pressure drop, the guy said this is probably the Oring that make the seal between the DV and the seat. If this is the DV I'll take the car at the dealer for a replacement!!
    Thanks all for the advise and comment, problem Solved!!
    Nov 06 2010
    Instead of starting a new thread I'll update this one!!!
    This afternoon, start the car to go work, everything is normal. Let the car run for a couple of minute to let the oil reach the head, still fine.
    Put it in gear and when I reach 2000rmp a thick white smoke came out the exhaust everytime the car is in load, when I release the gas no smoke.
    Bring the car to my local Audi garage(not dealer) to vag-com, Throttle body and O2 sensor bank 1 and 2 internal resistance to high. Between the time the smoke came and I arrive at the shop no more smoke, even on load. The engine temps as reach the normal point!!
    Anyone have a clue of what is coming of my exhaust!?! Have a appointment at the dealer Thursday for my oil change and to sort out this thing.
    Ah and no CEL poped out.
    Can anyone have ever post a vid of a blown DV, have a weird noise when a release the gas
    Active Member One Ring BELLISSIMO's Avatar
    Aug 17 2009
    Streetbikes, Snowmobiles, Pit bikes and Samurai's
    Chardon Ohio
    Sounds like condensation.... Your fine.... Its just moisture that forms in your exhaust from teh heating/cooling process.....
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by BELLISSIMO View Post
    this
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
