Page 8 of 60 FirstFirst ... 6789101858 ... LastLast
Results 281 to 320 of 2386
  1. #281
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Quote Originally Posted by korben View Post
    Anyone ever figure out how to get the battery meter working on a 2013?
    On pre-facelift, it's on the third screen of the Car menu. I wouldn't lose a lot of sleep over this feature. Mine never reads anything but 100% making it a bit useless.
    I guess it might come in handy in a few years when the OE battery starts getting weak, but there'll likely be other clues that the battery is failing.
  2. #282
    Veteran Member Four Rings Saud's Avatar
    Mar 25 2012
    14' RS5
    VA/DC
    Just wondering how to put this codes in the car
  3. #283
    Established Member Two Rings korben's Avatar
    Jun 28 2012
    PA
    Quote Originally Posted by Leor604 View Post
    Just curious as the fix might lead to other more interesting things in the 2013s (such as the newly required bus settings for the interior lights).
    2013 Ibis White S4 | DSG | Sport Diff | Nav | B&O | Carbon Inlays | Adv Key | Nappa | 19" Peelers
  4. #284
    Veteran Member Four Rings mattchat's Avatar
    Feb 12 2012
    2014 Honda Odyssey - Touring Elite
    Calgary
    Quote Originally Posted by Stereodude View Post
    What is this supposed to do?
    I tried it on my 2013 with Advanced Key and nothing changed. It still beeps when I open the door and warns me to shut the ignition off before leaving the car. I'm guessing that's a different message to disable that hasn't been discovered yet.
    This is the one driving me nuts, someone figure this out for the 2013 and they'll be my hero. Jump out of the car to get mail or for other stuff and it drives everyone nuts....
    I also couldn't get the seatbelt ebrake fix working either. At least you can just push the brake pedal, even without a seatbelt on and it will dissengage when you push it down.
    2013 S4 - Monsoon Grey - 6spd - ADS - Carbon Atlas - Magma/Black Int.
    Mods: RS5 Red GT front and rear brakes, VMR v710 19x8.5 w/ Mich PSS (S), Audi Ti 19x8.5 w/ Pirelli Sottozero (W)
    AWE + RES DP exhaust, AWE Carbon S-FLO, P3, Eurocode Meisterwerk ASTS, eCode headlights w/ ZKW clear lense swap + Philips Xtreme
    KW HAS, Eurocode USS, Alu Kreuz, DEVAL C/F rear Valence, Black Op Front Grill w/ Chrome Combo, Folding Mirrors
  5. #285
    Veteran Member Four Rings ilspazzaneve's Avatar
    Jul 18 2011
    Until you 2013 guys figure it out, most of the nag warnings in the DIS can be cleared/shut up by hitting the reset button under the right stalk. It becomes second nature after a while....
  6. #286
    Feb 24 2011
    Derry, NH
    Quote Originally Posted by saud77alsaleh View Post
    Can you clarify your question?
    2016 Cardinal Red Mercedes Benz C63 AMG S
    2018 Navarro Blue Q5
    *HEX-USB+CAN VAG-COM Available for those in Northern MA/Southern NH: Will Mod for Beer!*
  7. #287
    Mar 28 2009
    Minneapolis, MN
    whisper them into the tailpipe
  8. #288
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    Bahahahaaaa
    WTB - Electric high flow fan kit - FORGE 007 DVs
  9. #289
    May 25 2010
    Vancouver
    With the engine off, of course
    Seriously, you need to get a VCDS cable and software from www.ross-tech.com, and then read through this thread and you'll be good to go.
  10. #290
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Someone mention that you can actually put ANY picture (800x480) as start-up screen on the MMI 3G/3G plus. Wonder how that's possible. I was only able to change it to whatever they had in the system.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
  11. #291
    Veteran Member Three Rings Maximum's Avatar
    May 27 2012
    My lounge
    Galt
    How do you change that in hidden menu?
    2012 S4 Prestige, Monsoon Grey, STaSIS exhaust/springs, APR Stage II+, RS grill, RS shifter knob, Roc-Euro intake, Ziza LEDs, CREE W16W Reverse LEDs. RS6 flat bottom wheel, MMI 3G+, P3 Cars guage, Passport mirror radar, LI, 034 trans mount & end links
    2012 Q5 2.0T Blaze Orange Matte Metallic, STaSIS Tune, exhaust & 20x10 rims, RS grill, 2013 lights, LED interior, ACCUAIR B8 Sports suspension
    2003 A4 Avant 1.8T silver
  12. #292
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by Maximum View Post
    Change MMI 3G splashscreen...
    Enable through the "hidden menu":
    - navigate to 'car/carcodingvehicle'
    - choose the model of choice in 'configuration line'
    - select 'Update Splashscreen'
    - restart MMI
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 21.9.0 (HEX-V2)
  13. #293
    May 27 2012
    My lounge
    Galt
    Thanks! I wish I knew what what else could be done in here! I'm afraid to touch anything.
  14. #294
    Mar 20 2009
    Copenhagen, Denmark
    Yeah, The Hidden Menu is undocumented, so unless someone (or your self) has found a useful feature, I thing it is better not to change anything - that isn't self-descriptive. And if you change any setup, then write the change down, so that you can reverse it again.
    Rene Larsen
  15. #295
    Established Member Two Rings rapper's Avatar
    Aug 17 2010
    New York NY
    Hi - Anybody tried this on a Q7? I really really want this vagcom....
    Set Audi parking system - Switch OFF Speed
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    I do not have module 10 but has module 76.
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
    Component: Parkhilfe 8-Kan H02 0100
    Revision: 00H02000 Serial number: 85131024010108
    Coding: 0221266
    Shop #: WSC 31414 790 00001
    VCID: 2C5DF7B98F10169
    No fault code found.
    2011 Q7 S Line
  16. #296
    Apr 26 2011
    2004 CVO Deuce, 2016 SR5 4Runner
    Long Island NY
    For the new 2013 MY, could someone confirm which buttons to press on the console to access the hidden menu? Is it hold the NAV and TEL buttons and to reset: NAV, TEL and center button? I have already vagcom'd and enabled it.
    TIA!
    My Phantom Menace...2011 S4 Phantom Black / MT6 / NAV
    EPL Stage 2 | Strat Intake | AWE Exhaust | JHM Short Shifter | Alu Kreuz | Eurocode USS with end-links | Lamin-X E-codes | Hoen H11 Endurance Yellow Fogs | Tunerdomes LEDs | 35% Crystalline Tint | 3M Clearbra |VAG'd
  17. #297
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    Car and Menu
  18. #298
    Apr 26 2011
    Long Island NY
    Quote Originally Posted by 13S4 View Post
    Car and Menu
    Is that to access the menu or to reset it? Or both?
  19. #299
    Established Member Two Rings Vandalrg's Avatar
    May 29 2012
    Boston, MA
    Quote Originally Posted by You-S4-It View Post
    To reset (reboot) the MMI in the 2013 you press Menu, the joystick button, and the upper right softkey at the same time. (This is in the manual for the 2013, surprisingly.)
    To enter the hidden menu you press and hold Menu and Car for roughly 5 seconds. This will only work once you have made the changes in VCDS AND rebooted your MMI.
    2013 Audi S4 - S-tronic - Glacier White - Black/Silver Nappa - Sport Differential - 19x9.5 BBS-CHR's - H&R OE springs - Alu Kreuz - Front/Rear sways
  20. #300
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Quote Originally Posted by Vandalrg View Post
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    Works!
    So you got video in motion workin on a 2013 S4 ? I thought the hack was disabled by Audi sometime in the 12 model year ?
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
  21. #301
    May 29 2012
    Boston, MA
    Quote Originally Posted by QuattroRocket View Post
    Yep, it works.
  22. #302
    Apr 04 2008
    Northland
    any way to adjust headlamps ON delay?
  23. #303
    May 03 2012
    NA
    I'm sure it is possible, but no one has figured it out yet. I've been searching for that too. They come on very early IMO.
  24. #304
    Feb 12 2012
    Calgary
    Any way to keep the DRLs on when the parking brake is on.....it just looks too cool to be off when I'm parked and engine is running for a bit.
  25. #305
    May 03 2012
    NA
    After doing the basics listed in this thread I think i'm going to sit down over the weekend and really get into it. There are so many possibilities that haven't been explored yet.
  26. #306
    Active Member One Ring Toadusmodus's Avatar
    Aug 29 2012
    1996 TVR Cerbera, 1968 Baja Beetle
    Kent, UK
    Good luck!
    If in your experimenting you can find any of the following, I would be most grateful!
    1. Increase maximum speed limit on electric folding wing mirrors. Mine will not fold if the car is doing more than 10mph
    2. Disable engine switch off when drivers door is opened and seatbelt un-done.
    Both are very annoying!
  27. #307
    Feb 12 2012
    Calgary
    I wish i had folding mirrors that i could complain about....we don't get that option across the ocean. The ignition is still on chime though.....argh. Can't wait for someone to figure that out.
    Quote Originally Posted by Toadusmodus View Post
    Good luck!
  28. #308
    Aug 29 2012
    Los Angeles Ca
    Im brand new at this. just got my 2013 car. You said in order to access the hidden menu , press and hold menu and car for 5 seconds. I get that but how do I make changes to vcds and what is vcds?? Sorry Again im brand new at this. And will this work for a 2013 a4 with the face lift?
  29. #309
    May 03 2012
    NA
    You will get grilled if you don't search before asking questions. Read through this thread. It will take you 20 minutes.
    Then Buy this cable:
    http://store.ross-tech.com/shop/VCHUC.html
    Then Download the software from there site.
    You can change all sorts of programmed features with the cable. You have to enable the menu within the Vag come software before being able to turn it on.
  30. #310
    Dec 23 2011
    2004 BMW R1150RT
    MA
    Quote Originally Posted by mattchat View Post
    Not a fix, but others have pointed it out and I take care of this without even thinking anymore. To shut off the annoying 'ignition on' warning when you open the driver door, just press the reset button on the bottom of the wiper stalk. At least our cars on this side of the pond don't shut off!
    current: 2013 Focus ST; gone: 2010 B8 S4 P+, Ibis, Stronic
  31. #311
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    Good luck!
    Hi,
    Not sure if 2 is solved by disabling the seat belt check that's already documented. My MY2010 car doesn't act any differently whether the door is open/closed or the seatbelt on and off. I did the "ignore seat belt check" as it's a pain when just shunting the car around on my drive.
  32. #312
    Feb 12 2012
    Calgary
    Quote Originally Posted by zulujams View Post
    I hear that.
  33. #313
    Aug 29 2012
    Kent, UK
    Quote Originally Posted by scottyuk View Post
    Hi,
    Unfortunately not, I have disabled the seat belt warning, but the engine still switches off if door is opened and seatbelt not in. Damn health and saftey gone mad!!
  34. #314
    Established Member Two Rings premek's Avatar
    Jun 22 2012
    S4 B8
    CZ
    hey guys hope I wont get grilled for asking this , but do I need to generate some kind of security code in order to acivate Video in motion ? or just simply do as shown via VAG ? thanks for help.. I searched a lot but either am blind or its not there...
    DSG, Ibis white on magma red, AWE exhaust with APR carbonio and stage II intake, Adams rotors with FERODO DS 2500 - Love my S4 !!!!!
    "You should never underestimate the predictability of stupidity."
  35. #315
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by premek View Post
    Yes, you need to generate the login code. Here you can read about how to do it: http://audienthusiasts.com/Articles_VIM.html
    Rene Larsen
  36. #316
    Jun 22 2012
    S4 B8
    CZ
    thanks a lot...
  37. #317
    Aug 27 2008
    Houston Area
    Auxiliary ventilation didn't work on my 2013 S4. I couldn't get the seat belt parking brake mod to work either. It said the security code was wrong.
    The remote / window & sunroof mod works along with a lot of other lighting related mods, lap timer, etc.
    This may be common knowledge now, but ... I have aux vent working on my '13 S5.
    Followed instructions here on the 1st page (or audienthusiasts.com), but had to add the step I've seen references to ... set carbus to Can Komfort...
    [Hidden menu] [car] [carbusassignment] [Auxiliary heating] -> Can Komfort
    Still toggles off, so you have to re-enable it every time. Would be nice if there were some way to have it always run for 15 min. Hoping this will help keep the AC system from getting stanky.
    By the way - when changing the Aux ventilation menu from 0 to 5 - what exactly does this do? Would values other than 5 work?
    Attempted the Battery meter - no luck. Anyone been successful?
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
  38. #318
    Mar 20 2009
    Copenhagen, Denmark
    Yes, after each timed run the timer is reset, and need to be reconfigured again - that's also what the Owners Manual says.
    No one know what the digits stand for - other then that 5 will give you the ability to change the menu while driving.
    Battery meter doesn't work anymore - or no one has yet found the correct coding. And it is the same in MMI 4G (the MMI in A6/A7/A8 and the new A3)
    Rene Larsen
  39. #319
    Senior Member Three Rings motorboatingsob's Avatar
    May 01 2012
    West Chester, PA
    HI All, don't beat me up here. I have searched my ass off and can't seem to find the codes for disabling my light warning after installing ecodes. Can someone please tell me what I have to change to get rid of the headlight failure warning? Thank you.
    2011 S4 | Pearl Black | Silk Nappa | 6MT | Sport Diff | Nav | ADS | B&O | SC Badges | 20% Tint | Tinted Tails | HID Fogs | int/ext LEDs | RS4 Pedals | STaSIS V2 Tune | Eurocode Shortshifter | APR Carbonio Stage 1 & 2 Intake | Alu Kreuz | E-Code Headlights | AWE Boost Gauge | AWE Non-Res Exhaust |
  40. #320
    Feb 12 2012
    Calgary
    Disable amber corner lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    You are basically unchecking the checkbox that sais north american vehicles, something along those lines. Oh, and you do have a VAG-COM cable, right? Just want to make sure. check the stickie, it has everything you'll need:
    http://www.audizine.com/forum/showth...-complete-list
