Results 601 to 640 of 721
Threaded View
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    GabeRossi's Build Thread
    Hey there Audiziners, I am currently in the process Building my B5 A4. I am going with a Precision Turbo 5858 DBB, the power goal for now is 400FWHP+ and 600HP when I build the head. Running an AEB 1.8 motor... Usp Motorsports is going to be supplying the parts, install, and tuning. I will be updating this as everything goes along. Thanks for looking!!
    **UPDATED: 3-30-15**
    Car is making 460whp on E85 @28PSI
    Mod List
    Engine:
    AEB 1.8L
    JE Pistons 8.5:1
    Integrated Engineering Rods
    ARP Head Stud Kit
    Main Bearing Set
    Rod Bearing Set
    Thrust Bearing Set
    Knock sensor
    OEM Head Gasket
    Crankcase Gasket Set
    034 Solid Motor Mounts
    034 Transmission mounts
    034 Snub mount
    Usp Motorsports custom catch can setup
    Turbo/ECU:
    Pag-Parts Turbo kit(Manifold,Hardware,Lines,Fittings,Gaskets,Intak e)
    Precision 5858 Dual Ball Bearing Turbocharger all v-band
    Eurodyne Maestro Tuned by Chris Green @ Usp Motorsports
    Forge 007 DV
    Tial MVS Wastegate (38mm)
    Precision 600hp core w/ custom Usp Motorsports Inter-cooler Piping
    3in MAF/Harness
    Greddy Profec B SpecII Electronic Boost Controller
    K&N cone filter
    Fueling:
    E85
    Bosch 044 In-Tank Fuel Pump(feeds surge tank)
    ID 1000cc Injectors
    Radium Surge Tank w/Walbro 400E85 Built in pump and fuel pressure regulator
    Lines and fittings
    Integrated Engineering Fuel Rail
    Fuel Rail Spacers for ID1000's
    Exhaust:
    Custom Usp Motorsports 3in Down-Pipe/3in Down-Pipe back exhaust all V-band
    Magna-Flow Muffler 3in single
    Drivetrain/Transmission:
    Clutch Masters 725 series Twin Disk Clutch w/custom pedal stop
    USP Motorsports Metal Clutch Slave Cylinder
    Raxle - Drive Axles
    JHM Shift Linkage
    JHM Weighted Delrin Shift Knob(knurled)
    AWE DriveTrain Stablizer
    Suspension:
    ST Coilovers
    Stern Adjustable Upper Control Arms
    Brakes:
    ECS OEM BBK Audi A8 Rotors(slotted), OEM Audi TT Carriers
    Hawk Performance Ceramic Brake Pads
    Usp Motorsports Stainless Brake Lines
    Interior:
    Black door cards with Carbon trim
    Corbeau Racing Seats
    5 Point Corbeau Racing Harness
    Custom VEI Vent Gauge(boost and AFR)
    x2 10" Punch subs with 840W amp
    Exterior:
    OEM B5 S4 Front Bumper
    OEM B5 RS4 Grille
    Depo Ecode Black Housing Headlights with HID
    Removable Paint: Nogaro Blue AutoFlex High Gloss
    Wheels:
    (Street)Team Dynamic Pro race 1.2 18x8 with Nitto INVO Tires
    (Track)Stock 15” Wheels with Mickey Thompson 24.5” Drag Slicks
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
