The two modifications you have to make are, trimming the fender where the turn signals are placed, and you will need to make a new wiring setup for the new headlights because of the different plugs between the old and the new.
The first modification: Trimming the fender. I used an air tool with a cutting wheel, it was fast and easy.
The second modification: Setting up wires and connectors to go from your old plug to the new plug. You will need to cut 6 pieces of wire. One side of the wire will need a female plug to plug into the headlight housing and you will need to use heat shrinkable tubing to place around the connector because the connectors are placed very close together, I also cut half of the connector to ensure they did not make contact with each other. The other side of the wire will need a round male connector to fit into the cars stock headlight plug. Check out the picture I have of the connectors I used, they worked perfectly.
The cars stock headlight plug
The new headlight housings plug
The female connectors used on the new headlight housing
And after a job well done.
